Question about Refrigerators
My amana refrig keeps thawing and refreezing everyday. what is wrong
  • 430 Answers
Can you refreeze a thawed turkey
Refrigerate when thawed, keep frozen whilst frozen, never refreeze any meat or poultry.
Nov 24, 2013 | Refrigerators
I have an Amana SD125F-L refrig-freezer. The rubber tube which carries water from inside the freezer wall to the ice maker tray frequently freezes solid with ice. After thawing with a hair dryer, it...
Hi Jan, the problem is a bad ice maker water valve. Pull the refrigerator out and look for the plastic water line that's going to the tube that's freezing. Follow that tube to the faulty water valve. The problem is, its leaking water slowly to the ice maker and it freezes up . Easy fix : Good luck
Appliance Repair Tucson, AZ
Refrigerator Repair service 520-888-7039
Aug 15, 2013 | Amana Refrigerators
Is it safe to refreeze meat, such as venison steak after it has completely thawed?
Refreezing
Once food is thawed in the refrigerator, it is safe to refreeze it without cooking, although there may be a loss of quality due to the moisture lost through thawing. After cooking raw foods which were previously frozen, it is safe to freeze the cooked foods. If previously cooked foods are thawed in the refrigerator, you may refreeze the unused portion. Freeze leftovers within 3-4 days. Do not refreeze any foods left outside the refrigerator longer than 2 hours; 1 hour in temperatures above 90 °F.
Sep 04, 2011 | Refrigerators
Frezeer was unpluged by accident. All mear thawed out. Is it ok to refrzeethe meat and eat it later.
Is it safe to refreeze food that has thawed completely?
although there may be a loss of quality due to the moisture lost through defrosting. After cooking raw foods which were previously frozen, it is safe to freeze the cooked foods. And if previously cooked foods are thawed in the refrigerator, you may refreeze the unused portion.
If you purchase previously frozen meat, poultry or fish at a retail store, you can refreeze if it has been handled properly.
(Source: Freezing and Food Safety)
Charlie
Feb 10, 2011 | Refrigerators
Where is defrost timer on amana arrccb
The ice in the ice tray freeze together as if they melted for a time then refreeze. It appears to maybe be a defrost problem. Can I adjust the defrost cycle on My Amana Bottom Freezer Refrig?
Nov 01, 2010 | Amana ARB224RCC Bottom Freezer...
My Whirlpool side by side keeps freezing on the regular side.
your damper door is most likely frozen in the fully open position,thaw it out if iced up,then adjust cold control to see if it closes,the door is inside between the refrige and freezer compartments,also if this happens again check the door seals to make sure they are sealing good and not letting in warm air that can condense and refreeze this door
Jan 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer thaws then refreezes
I was going to suggest that maybe it is a self defrost issue not shutting off when it should but sine you mentioned this knob, it suggests a thermostat out of calibration - I can rule out circuit problems since you can manually turn on compressor by turning the knob to a cooler position - you will need to have it serviced and change the thermostat which is not cycling whne it's supposed to.
ALSO - do not refreeze foods in your freezer that have thawed ! Throw them away !!! Normal freezer temps should not be warmer than 10F, the normal temps are 0F, and optimal recommended temp -10F (for hard ice cream) and to allow better recovery in case of power failures.
Refrigerator section no warmer tan 40F.....optimal recommended 34F.
Oct 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Aug 13, 2009 | Refrigerators
I have a Conia fridge/freezer. The freezer is working fine but the fridge part is not getting cold at all.
In some cases like you have, you need to unplug the unit and let it thaw out. Store you freezer food in an ice chest or else where to keep it frozen.
If the unit has self defrost, the defrost cycle refreezes and blocks the circulation of the refrig area. Make sure all frost and water are removed before plugging the unit back in.
Mike
Jul 29, 2009 | Televison & Video
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
