I have a esp office 6100 series all in one printer, it is connected to a fully functioning phone line - I have checked everything is working. Each time I try to send a fax I dial the number it dials 3 or 4 numbers then gives me the tone for an incorrect number and tells me I have dialed incorrectly please try again. I do not dial incorrectly and when I plug in a phone to the line it works perfectly am perplexed can you help? thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 37 Answers
Most likely the fax is incorrectly set up as an extension in a multi-line system rather than a single "telephone". probably the fax injects digits such as a leading zero. the setup needs to be corrected.
Posted on May 27, 2011
My kodak esp 6100 keeps on showing error code 3806?
Disconnect power cord, let it set 30 sec, reinstall cord. If problem still there pull out the printheads and reinstall, may have to do this a few times, if problem still there may need printheads.
May 07, 2014 | Kodak Office Equipment & Supplies
Hola, me compre una impresora Kodak ESP office 6100/6150, me imprime las fotos en color rosa tirando a lila; me podrian ayudar por favor??? gracias
HOLA TENGO UNA KODAK ESPOFFICE 6100, LA CUAL NO PUEDO INTALAR EN WINDOWS 7 NI EN WINDOWS 8 NO PUEDO UTILIZARLA POR FAVOR ME PUEDES ASISTIR PARA PODER INTALARLA DESDE YA SE LOS AGRADESCO
Jul 12, 2012 | Kodak Office Equipment & Supplies
I was recently given a 5300 all-in-one printer.I want to replace the ink cartridges. I bought ink(kodak) and want to make sure it is correct before I open the box. I bought an ink combo pack for an...
You got it right - the Kodak EasyShare 5300 All-in-One uses 10 series Kodak cartridges, and
since your box says 10B+10C, it has (2) 10-series cartridges in it - one 10-series Black (10B), and
one 10-series Color cartridge (the 10C).
The 10 Series Ink cartridges are compatible with:
EasyShare 5000 series (your All-in-One belongs here)
ESP 3/5/7/9
ESP 3200/5200/7200/9200 Series
ESP Office 4100/6100
Reference:
http://store.kodak.com/store/ekconsus/en_US/list/Ink_Cartridges/10_Series/categoryID.53666600
Mar 18, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a MacBook Pro connected via USB to a Kodak ESP 5 A-I-O. I've been having problems getting the scan function to work at all. So I upgraded the ESP 5 firmware & drivers to the latest available for...
Hi. To make sure that the product hardware is functioning correctly, use the product to make a photocopy. If you cannot make a copy, this solution will not help resolve the issue.
Solution 1:
Follow these steps to restart the product and the computer. NOTE: Make sure that the product connects directly to an electrical outlet and not through a surge protector or power strip.
  1. Shut down the computer.
  2. Press the Power button to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the Power button to turn the product back on.
  6. Try the scan again
Solution 2
1. Replace the USB cable.
2 .Try the scan again.
Solution 3
Fully uninstall and resintall the software and driver of Kodak printer
Workaround:
Try installing the printer to Windows XP environment just to prove functionality and test incompatibility issues. Might be your printer is icompatible with MAC OS. This will also prove if printer is working or not.
Jul 10, 2010 | Kodak ESP 5 Printer
Not printing
When printing from the microsoft word document, make sure the printer selected is right. By that, i mean the default printer selected in the printers icon under the control panel should be HP OfficeJet 6100 series and not HP OfficeJet 6100 fax.
So the reason why this message comes up " scanner failure ". is you are either selecting a wrong printer when printing from microsoft word document or probably the printer port is not selected right.
To check the printer port.
Click on start-->control panel-->printer & faxes-->right click on HP OfficeJet 6100 series--> select properties-->Select the top tab called ports-->
Check the ports selected here.
If you have a USB connected printer it should be your printer model with USB settings.
If you have a wireless connected printer it should be your printer model with wireless settings like IP address.
Apr 29, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hi. I have a Xerox M20i. The fax machine will ring, but then immediately hangs up. I have reset the memory and the DIMM chips as suggested by Xerox. The phone line works as the machine can fax out. Help...
Is your phone line in the " line" jack and not the ext jack?
If the line is digital it will do that.
If the phone line voltage is low, the line current low that will also cause the problem.
In your fax settings. Is ECM turned ON.
Is Junk Fax OFF.
Secure Fax OFF.
Delay Fax OFF.
If your phone line is weak, it will cause that problem.
Jul 13, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Can only get dsl if i use landline
Hi, Rob just studied ur problem.Iam a tech which handles this kind of issue. I talk to verizon,at&t,bellsouth,qwest daily for such issues. Well i can suggest u onething u can get the efficient speedstream 4100 series modem which comes with a 1 yr warranty. And also checkout with verizon clearly abt ur distance from the central office.Bcos might be ur dsl circuit may be not technically feasible i:e NTF. For further clarifications plz get back to me.
Jun 07, 2007 | Westell Wirespeed LiteLine 6100...
53 people viewed this question
k24674
