My outdoors ac unit fan blades won't turn without me helping it, with a stick. The unit does have power. You can hear it working. Also, I replaced the motor and blades and capacitor and contractor all 2 years ago. They still look in great shape now.
    Guru:
  • 683 Answers
Sorry to say but it sounds like you have a bad run capictor.
Posted on May 27, 2011
My Lennox ac is making a very loud buzzing sound and the fan blades are not turning. We replaced the dual capacitor and that seemed to fix the problem for a couple of days, now it's doing the same...
Fan motor is probably bad, if it is under 5 years old the parts are under warranty. Do not run the unit for very long without the fan working as it can damage the compressor.
Aug 23, 2011 | Heating & Cooling
I have a carrier 38eh060330 outdoor ac unit. the fan does not work. I just hear buzzing, but I can turn the blade by hand. from the internet i learned that this is usually caused by a bad capacitor. there...
A capacitor only costs a few bucks. The condenser motor may tell you what MFD of capacitor to use. What you could do is 1. kill the power to the condenser 2. open up the electrical panel on the side 3. trace the motor wires to locate the capacitor. As you're tracing the wire, you may run across a low pressure sensor on the refrigerant line also. This would be a good start to diagnose where the problem is. If you're really going to be doing this, you should invest in a good multimeter.
Aug 11, 2011 | Heating & Cooling
I changed out the capacitor in my outdoor AC unit and it still won't work. There is a slight humming noise and I can see the contactor pull in and out when the thermostat turns it on. Could my fan...
I would start by inspecting the contactor make sure you are getting full voltage thru it to your fan and compressor. Usually there is a capacitor for the fan and one for the compressor. Make sure they are getting proper power and that capacitors are good. check amp draw and go from there,
Jun 24, 2011 | Heating & Cooling
My ac central air is blowing air but not cold
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device known as a "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning compressor. Another good device is called a "5-2-1" kit.
Jun 22, 2011 | Goodman CKL36AR36 Air Conditioner
My outside Kelvinator central ac unit will not turn on. I hear a faint humming noise coming from it so it appears that it is getting power but won't turn on. My fan in the house will turn on and...
Its possible that the contactor that closes to start the outdoor unit is not pulling in and passing power. You are hearing the coil humming since it is getting control power. Also first check that breaker for outdoor unit is not tripped
Jun 22, 2011 | Heating & Cooling
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Jun 17, 2011 | Heating & Cooling
The fan wouldn't start for the condenser unless I turned the blades with a stick so I replaced the start capacitor and it still won't start without turning the blades with a stick. It runs fine but...
This problem could be caused by a bad motor run capacitor. Please see our If your motor capacitor is not the problem, then more than likely you need a new motor.
Jun 13, 2011 | Ruud UBHC Air Conditioner
We have Goodman AC unit...not sure what kind. It has blown VERY cold until the last few days where it would stay a little above where I had it set. Then yesterday I realized it was incredibly hot. My...
If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning systems.
Jun 11, 2011 | Heating & Cooling
The unit is not communicating between the Furance and the AC
Then it is not communicating with the thermostat. When you turn it to cooling and the fan comes on, then the thermostat is communicating
with the furnace.
If you have 24volts between Y and C then it is communicating with the AC Unit. If you go outside and remove the electrical panel(shut off power
to outdoor unit) you can still hear the contactor being pulled in.
If you cannot hear that you need a new two wire from furnace to outdoor unit
Jul 16, 2010 | Ruud UAMB024 Air Conditioner
RV A/C blower not working and keeps kicking out
If blower not working, and yoou hear a slight "Hum" with fan only on, try this. With power off to AC. Go up on roof, and slide a stick through opening on side near rear, and try to get to fan blades at rear of unit. try to spin the blades a few times, even if it only goes a little at a time. Unless you want to take all those screws out & remove cover to get at it better, but watch for wasps under there. Give fan a couple of full rotations, then have someone turn it on to fan only & see what happens. If fan finally works, let it run for a few minutes on fan, then try cool & see if it all comes together again. Let me know.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
