Question about Sunpak 6600DX Tripod
Broken screw on top and plate. - Sunpak 6600DX Tripod
  • 8,404 Answers
Go to the hardware store and get an "Easy Out" and the proper size drill bit. This is a simple procedure and the salesman or woman, can explain the process to you ... You may want to take the tripod with you.
Simple.
Thanks for your question.
Posted on May 27, 2011
Giottos MT-8170 center top plate 3/8" screw broken, can the screw or plate be replaced?
You unfortunately can replace the screw; however you can find a new plate at www.tripodquickrelease.com. They carry Giotto quick releases.
Dec 25, 2012 | Giottos Photography
How do we get rid of the UL code on our Kenmore Oasis Canyon Capacity Top Load Washer? It stops on the final rinse and spin cycle with nine minutes left.
Thwere is a switch under the lid that will not spin the tub, if the lid is up. This may be bent or broken. Lift lid and shine a flashlight down the slot underneath the protrusion on the lid. you should e a'plank' across the hole. No plank the swithch or the ;Plank" is broken. Most likely the plank, or actuator.needs replaced.
To replace , and or check the actuator, you have to remove the top of the machine. On a Kenmore here are 2 screws at the top back of the washer thaqt hold down 2 metal plates that go up to the back of the control panel. When the screws and plates are removed you can pry up the top of the washer with a stout screwdriver. after removing the top you can un screw the safety inlerlock, that's what I call it, and check for the bent/broken actuator or broken switch. If all looks okay then you need to take an ohm meter and check for continuity through the switch. Place one test lead at each end of the switch, removing and marking the wires on the switch. Press the actuator and you should see less than 5 ohms on the meter, if that is okay, then it gets more involved.
Let me know
Jan 17, 2011 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
I needed to replace climate control unit on1997 Grand Am GT. Concerned with how to remove the cluster face panel w/o breaking it.
Let me know if this helps out.
Heater & Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the screws securing the cluster trim plate to the instrument panel.
  3. Tilt the top of the cluster trim plate downward releasing the clips that mount the bottom of the trim plate to the dash. Remove the trim plate.
  4. Remove the screws attaching the accessory trim center plate to the dash.
  5. Tilt the top of accessory trim plate downward releasing the clips that mount the bottom of the plate to the instrument panel. Remove the plate.
  6. Remove the screws attaching the control assembly to the dash.
  7. Remove the control assembly from the dash.
  8. Disconnect the control assembly electrical connectors.
  9. Remove the control assembly.
To install:
  1. Install the control assembly.
  2. Connect the control assembly electrical connectors.
  3. Install the control assembly attaching screws.
  4. Push the mounting clips into place and roll the top of the accessory trim plate upward into position.
  5. Install the screws attaching the accessory trim plate to the dash.
  6. Push the mounting clips into place and roll the top of the cluster trim plate upward into position.
  7. Install the screws attaching the cluster trim plate to the instrument panel.
  8. Connect the negative battery cable.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 40; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Jan 23, 2011 | Pontiac Grand Am Cars & Trucks
SINGER CG 550
If the plate is moving up and down eithetr the teth are set far too high pushing the plate up or the teeth are set too far forward, I would go for the first, if the teeth are coming up well above the slot they are too high, they should be set so that when you look alongside the plate you can just see the top of the teeth, you can adjust the teeth by adjusting the screws underneath the machine where the teeth are.
Mar 03, 2010 | SINGER 7470 Sewing Machine
Left hinge is broken on HP officejet 6210
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Nov 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hinges for top cover for HP officejet 6210- Q5820A
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
1993 dodge 3500 wont come out of fifth gear
ONE OF THE SHIFTER FORKS HAS BENT OR BROKEN AND THE TRANS IS STUCK IN TWO GEARSYOU CAN CHECK THIS BE REMOVING THE FLOOR CONSOL AND THE BOOT , MAYBE EVEN THE FLOOR PADDING UNDER ALL THE YOU WILL SEE A PLATE UNDER THIS AREA REMOVE SCREWS AND PLATE. THEN YOU CAN REMOVE THE TRANS TOP AND SEE IF THE FORK ARE BENT OR BROKEN
Aug 22, 2009 | Dodge Ram Pickup 3500 Cars & Trucks
Replacing broken handle on filter queen vacume
It is always best to have a cirtified & Authorized Service Tech or Center do the work and only with genuine Filter Queen parts and supplies. Both can be found at 800-344-1840 or in Iowa 888-637-4692
If a Authorized Tech can not come out,
  1. Always unplug unit from electric outlet.
  2. Remove top like you were changing filters, also the crown.
  3. Remove cap under handle.
  4. Remove 3 screws from SN plate then remove plate.
  5. Seperate upper from lower.
  6. lift cardboard piece and Silencing Filter.
  7. Now you can remove the 4 screw that hold the handle.
  8. Repace handle and reverse the above steps.
FQ Master
1-888-637-4692 in Iowa
Your Authorized Filter Queen Service & Supplies
Apr 04, 2009 | Filter Queen Majestic Canister Vacuum
Removal of filter module
the wash spray arm unscrews, then there are 5 torx 20 screws removing the top filter plate, under there is anohter 2 torx 15 screws allowing you acess to the chopper assy
Apr 08, 2008 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Removing the plastic top service plate
if the motor is running and the blade is not turning here is a rubber coupling that has probably broken.the blender will need to be pulled apart and that part will need to be replaced . it is designed to absorb sudden shocks if something hard is hit and has broken rather than burning out the motor. there are two other torx screws holding the rest of the plastic parts after the switch assy is removed by uncliping it .
Nov 18, 2007 | Bamix Gastro 200 Handheld Blender
Sunpak 6600DX Tripod Logo
Top Sunpak Photography Experts
Tony
Jay Plesset
richie46
Are you a Sunpak Photography Expert? Answer questions, earn points and help others
