Question about Dell OptiPlex GX260 PC Desktop
I have a dell gx260 all my web video sound like chipmunks , media player works fine and i did all the troubleshoot test and it works just fine . The main problem is the web content all sound like chipmunks any ideas. Success101
  • 592 Answers
Hi.
This is usually caused by a missing codec, so the computer tries to compensate, and the results aren't always acceptable.
I would download a codec package called K-Lite codec pack, it has every codec needed.
Here is a link for it.
http://www.codecguide.com/download_k-lite_codec_pack_mega.htm
Click on the direct download selection there on the page, and it will download an installer with all the codecs.
Run the program after it is done downloading, and then after running it, reboot your computer.
There is a selection for 64 bit on the page as well, in case you are running 64 bit operating system.
Once rebooted, your chipmunk audio problem should be resolved.
I hope this helps you out, and have a good day.
Posted on May 27, 2011
Step three says connect to computer. I plug the green speaker prong into the green port on my sound card. I get windows sounds, but no sounds from CD or videos online. Any ideas?
Many applications (like web page videos, media players) have their own volume controls, separate from the main windows control. Since you can hear other sounds, I would guess that the volume is lowered/muted on these applications. To check this, look for a slider bar or speaker icon on the web page, or the media player. Adjust slider up, and also check for a a mute button (often a red circle over the volume control). Adjust and re-test, and you should be good to go.
Sep 12, 2011 | Dell OPEN BOX AX510PA Multimedia Speakers
CAN YOU FIX HOW OPTIPLEX GX620 DELL DESKTOP COMPUTER HAS SOUND ONLY BUT WOULD NOT SHOW VIDEO ON MOVIE PLAYER?
Go here and download the codec package. You decide if you want the player or not (a check box).
http://www.free-codecs.com/download/k_lite_codec_pack.htm
This will fix most of your video display problems. Good Luck.
James
Apr 17, 2011 | Dell OptiPlex GX260 PC Desktop
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
My dell optiplex 360 model pc have built in speakers .I installed all the yhe audio drivers and analog drivers but no sound output .In the time of Using media player and video files only the video . No...
The optiplex 360 does come with internal speakers(it's in the spec sheet as optional), we bought them for our entire IT department and they worked fine on XP and vista, but when we put 7 on them, we can't get the internal speaker to work.
Oct 27, 2009 | Dell OptiPlex 360 Desktop Computer
My Dell GX260 won't display any video
the problem is that thease are revamped pc from dell and thay only accept max 512 mb per slot it wont reconize the 1 gig. i have experince on this a friend has 1 to.
Jun 29, 2009 | Dell OptiPlex GX260 PC Desktop
People in any videos I download sound like chipmunks
If you are using Media Player, open media player, click on View, then Enhancements, choose Play Speed Settings, move to the bottom left of the screen and select Normal, it will be between Slow and Fast. Let me know if this helps
Apr 13, 2009 | Dell OptiPlex GX150 PC Desktop
Problem installing ATI Radeon X1300 256mb in Dell Optiplex GX260
Hi edward,
I'm looking at the specs of your dell and of the video adapter.
It appears the Power Supply in your dell may to under powered for the video card.
According to dell's website the largest psu that ships with that unit is 250 watts while the radeon x1300 needs a minimum of 250 watts to run and assuming you have the 250 watt version you need to take into consideration that the psu is also powering your CPU, memory,fans,hard drive/s and other components on in your system so 250watts just isn't enough.
You may want to contact dell and see if there is a larger psu that you can purchase. I would recommend one at least in the 400 watt range.
I hope you get it straightened out I certainly know how frustrating it can be to not be able to use new hardware.
Let me know how it works out.
Sean
Mar 16, 2009 | Computers & Internet
Dell Inspiron E1505 no sound in web browser
I must tell you that this is not an issue with the drivers or the web browser or the computer. This could be possible that volume button on the video while on web browser is mute or lowered....
Please check.....
However you can try to watch the same video online on other computer, just to isolate the issue....
Nov 12, 2008 | Dell Inspiron 8500 Notebook
Lost resolution windows vista upgrade on GX260
Hi all,
I tried numerous solutions for this issue and none of them worked except this one. I tested it with Vista Ultimate and don’t know if other Vista versions have the same drivers but here’s what worked for me:
1. Right click ‘Computer’ then left click ‘Properties’ to open up System window.
2. Click ‘Device Manager’
3. Click ‘+’ on ‘Display Adapters’ and you should see the drivers for your video. Right click and select ‘Update Driver Software...’
4. Select ‘Browse my computer for driver software’ and click ‘next’.
5. Click ‘Let me pick from a list of device drivers on my computer’
6. Untick ‘Show compatible hardware’
7. Select ‘Intel Corporation’ then select ‘Intel 82865G’. Click next.
This will install the drivers. No they are not the same drivers for the hardware but they work a treat!
May 05, 2008 | Dell OptiPlex GX260 PC Desktop
Music at chipmunk speed
try reseting it, look on the back of the mp3, and it tells you how to reset it.
Nov 05, 2007 | RCA H100 MP3 Player
Dell OptiPlex GX260 PC Desktop Logo
220 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
