Question about HEWLETT-PACKARD HP Compaq Asus Motherboard Desktop Board Narra3 5189-1661
Mother board supply is intermittent - HEWLETT-PACKARD HP Compaq Asus Motherboard Desktop Board Narra3 5189-1661
  • A Miller May 27, 2011
    As I understand it, you are having trouble receiving mother boards from your supplier??? Have you discussed this with the shipper?
  • HEWLETT-PACKARD Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on May 27, 2011
Can I use Transcend 4GB DDR3 1600 RAM instead of 4GB DDR3L 1333 RAM in BiostarJ1900NH2 mother board
No, Biostar advertises that you should use low voltage memory on this board. My experience that when 1.5 volt memory is installed in a 1.35 volt system, it is not reliable. (Intermittent Crashes.)
Dec 13, 2015 | Transcend Computers & Internet
Computer power supply does not work
Need to know how old a computer it is as over the years the power supplies' use different methods of starting.
On newer computers the power supply is connected to the mother board by a 20 or 22 pin connector. The power button on the computer is just a momentary switch to start the computer. Make sure the large connector is firmly seated in the mother board. If you are comfortable with doing that have someone else check it. You do not want to damage the connector or mother board. You need to have some sort of anti static device conntected to your body to avoid any static discharge that could damage the mother board.
Feb 09, 2014 | Antec TruePower Quattro 850-Watt Power...
Bought barebones(B69-9005)hade trouble installing win 7 kept saying no signed driver,. called them , they sent me soft ware for driver install. started dowloading then stoped. now monitor just reads no...
If it has onboard video it may be a bad video cable or messed up pin on one af the connectors. If it is a installed video card the cable could still be one problem but also try pulling the video card out unplugging the power supply cable from the mother board for about 20 seconds or so. Then reslot the video card into the mother board and plug the power supply back into the mother board and see if that helps. I have also had to take the small flat battery out of mother board for a second or two to make it reset. If you decide to do the battery thing make sure the power supply is unplugged from mother board. Good luck.=)
Sep 19, 2010 | Computers & Internet
New power supply does not work...is it the motherboard
well there are two ways to to figure out which item is broken first you can hook up the power supply and test the pins in the plug with a voltage tester to see if it has power. I do not recommend this approach if you are unsure of what you are doing the voltage coming from a computer power supply is very dangerous. the second thing you could do is attach a different power supply to *********** board if ti works the mother board is good and it your power supply that is busted. Also make sure to check the back of the power supply and make sure it is set to 110 and 220 voltage because this can cause your power supply to not function correctly. It will be a little red switch on the back that says 110v on one side of it and 220v on the other.
I hope this helped.
Thank you,
Norse
Jul 03, 2010 | EliteGroup L7VMM2 Motherboard
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
Curly one
Hi
there is way to find out
First ,disconnect all power cable and data cable from hdd,fdd,and remove all pci devices.
Now you have to check your pc mother board not touch to your pc case.
Second, check heat sink on cpu is mount properly check ram also.
now check on button if it is ok push it to on.
if now occouring same problem.
change cpu and check
if the problem is not solved you mother board is faulty.
Jul 30, 2008 | Dell OptiPlex GX520 PC Desktop
Computer shuts down y by itself
remove ur power supply socket from the mother board short the pin green and black in the connector if the smps start no problen with the power supply then the problems lies with ur mother board wiring or fault in your mother board if your mother board has secondry power fix it correctly to mother board sock et with has 4 pin if its not working cousult a chiplel engineer the fault lies in the power supply of the motherboard
Dec 02, 2007 | EliteGroup 945GZT-M (V1.0) Motherboard
Motherboard
One of the greatest factor in intermittent shutdowns is because of heat issues. try to check the fans if they are all spinning. if all fan's are ok then you only need to replace the motherboard. here's a manual that might come in handy http://support.dell.com/support/edocs/systems/dim5100/en/sm/index.htm
Hope this helps.
thanks
Nov 13, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
HEWLETT-PACKARD HP Compaq Asus Motherboard Desktop Board Narra3 5189-1661 Logo
67 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
