Question about Logitech Computers & Internet
Logitech mouse left button does not work - Logitech Computers & Internet
  • 92 Answers
That is a circuitry problem. You can try this following procedure if you can. --unscrew and open your mouse casing. --you need a tester (VOM) to test the wiring continuity. If one of the wire is open connection you can replace it with a new USB or PS2 connector. If all the wire is shorted, proceed to the next step. --Check if the microswitch is ok by testing the pin connection using the tester. Microswich has 3 pins, test only the soldered pins. When you press the switch, it might be shorted. If not, replace it with a new microswitch.
Microswitch and USB/PS2 connector are available in all electronics shops.
Posted on May 27, 2011
Once in a while my Logitech TrackMan Mouse won't left click
usually this is a sign of the button getting clogged or worn down from use. Best bet would be to get a new mouse, gaming mice have very high quality buttons ;)
Aug 25, 2013 | Logitech Computers & Internet
Loss of control over my mouse.
Hi Arsenal,
My Logitech cordless occasionally does the same thing. On mine it was caused by a build up of gunk over the optical sensor. Once I cleaned it, it functioned normally.
I know it doesn't make sense as far as the buttons. I'm just sharing what worked for me. Hope it works for you.
Best regards
Mike
Jul 29, 2010 | Logitech Cordless Mouse
Logitech cordless desktop EX110 model the exact problem is mouse
Reload the software that came with the mouse, If you didn't get software, go to the Manufacture's web site and reload it from there.
Jul 07, 2010 | Logitech Cordless Mouse
MX600 Logitech laser cordless mouse, left button stops working
Just found a temporary solution (fixes the immediate problem, but it does return):
Turned the mouse off held down both buttons, turned it on, let go of both buttons. When you let go, it works again.
Jul 02, 2009 | Logitech MX 600 097855036162
Logitech MX Revolution Left Click Button Broken
I have a Logitech Revolution MX 5500 Bluetooth mouse (part of the Logitech MX 550 desktop set.)
In my case, uninstalling SetPoint and re-installing solved this exact problem.
Mar 23, 2009 | Logitech Cordless Desktop MX 5500...
Logitech LX8 Mouse back button quit working on AOL
This has been a long time problem with Logitech and Aol. If your mouse software allows you to edit your mouse buttons, change the back button to "keystroke" and enter the back arrow key on your keyboard as the command. Alt left arrow also works. While you don't appear to have a forward button, Aol users who do, would change it to "keystroke"...Alt right arrow.
Mar 09, 2009 | Computers & Internet
Left button of G5 laser mouse wont work
If you are talking about the left mouse button not on the sides, your mouse may have some buildup in the mouse on the sensor that says it was being touched. if you remove the screws and blow it out with a can of air, it may resolve the issue if not i would check the warranty and see about getting it replaced if there is no warranty. If you are talking about the mouse buttons on the left side of the mouse, you need to install the software from the following site. http://www.logitech.com/index.cfm/441/135&cl=us,en
I would follow the instructions and update the firmware and then install the setpoint software as well. If it still doesn't the mouse will need to be replaced.
Mar 06, 2009 | Logitech G5 Laser Mouse Mice
Right button doesn't work; single click with left button
You can probably repair this yourself if you are technically inclined and careful.
There is a tutorial here showing how to disassemble the mouse: http://www.vk2k.com/Logitech-MX1000-Battery/
The microswitches for the buttons can be opened if you are very careful, and then you'll have to clean the contacts. Regular rubbing alcohol should work fine. Be careful not to lose any parts when opening the switch.
If the switch contacts have corroded, you may have to replace the contacts or the entire switch. You may be able to take a similar switch from another mouse (many manufacturers use similar switches). SWometimes there are MX1000 or similar logitech nonfunctioning mice being sold on eBay for parts.
Good luck
Mar 03, 2009 | Logitech MX1000 Laser Cordless...
Logitech downloads for V220 logitech mouse
You can get it HERE. Choose the correct operating system to download your driver.
Jun 21, 2008 | Logitech Cordless Mouse
Computers & Internet Logo
65 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
