Question about Indesit W 123 Front Load Washer
Washing machine W1121 indesit washing machine wont wash what ever progamme you put it on it just keeps spinning until it returns to the progamme number it started on and then does nothing. I have cleaned out the filters at the front
I have the same problem can u solve this it starts to fill then drains and the knob starts to spim on my indesit W1121
Posted on Sep 20, 2008
Did you reset the machine after you checked the filter? if not put the selector switch to any of the stop positions the switch on wait till the on/off light flashes rapidly , then switch off and try again.
Posted on Aug 16, 2008
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
WASHING MACHINE WONT DRAIN OR SPIN
did you get a solution as i now have this problem
Jun 08, 2010 | Washing Machines
Going through wash cycle but not spinning
my indesit starts to wash then comes up with 3 falshing lights and just keeps leting in water if i put the machine on with nothing in it it goes the wash until it gets to spin then starts to spin and agian starts letting in water
Mar 26, 2010 | Indesit W 123 Front Load Washer
Washing machine wont stop it has been going from last night
turn off at wall and unplug .after a few minute's plug back in and try and reset machine by putting dial on one of the dots switch on the red light should flash 3 times and switch off .I this works try and put machine on again a spin only will do if the same problem returns you probable need a new pc board . cost about £55to 90pounds before fitting .
Feb 11, 2010 | Indesit W 123 Front Load Washer
Indesit programmer has a mind of its own
I have LG Washing Machine WF-S6607 when I START after 5 Second it will be stop and alarm to come up on Rinse MODE. what I do?
Oct 17, 2009 | Washing Machines
Indesit WIE127 Washing machine which flashes error code F08 when it goes to spin. Can this be fixed. What do I need to do to mend it?
I HAVE THE FAULT CODES FOR SOME INDESIT MACHINES THEY ARE ONLY SUPPLIED TO THEIR ENGINEERS BUT A MATE OF MINE WORKED FOR INDESIT/HOTPOINT (ONE COMPANY NOW) UP UNTIL A MONTH AGO , HOWEVER ,THEY ARE AT WORK & I WONT BE IN UNTIL FRIDAY IF YOU CAN HANG FIRE UNTIL THEN I MIGHT JUST BE ABLE TO HELP YOU OUT!
Jul 30, 2008 | Indesit Washing Machines
Indesit w143uk
these machines are a problem! the dial clicking round can be a component fault - ie pump etc - or a module fault. from what you describe, fault could be with the pump. an easy way to check is to power the pump up independently and see if drain works ok. (i assume you have checked the filter) after that, check continuity in the heater as well. if both of these are ok, you are faced with a module fault
Jul 21, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
470 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
