Question about Canon imageCLASS D320 Digital Copier
The red alarm light keeps blinking and as we open and close the right it make continuous noise at the bottom of the paper tray for 30 seconds and it don't catch the paper
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Canon Expert
  • 259 Answers
The better call the technician.
because I think there is some gear has broken/loosen.
but first you can check it. perhaps that is just a rubber(pick up roll) was slick.
so can not catch the paper.
Posted on May 27, 2011
Printer pulls one page all the way thru w/o printing anything on paper and then pulls 3 to 5 pages all the way thru and then 1 page thru and paper gets stuck in middle...then red light comes on and blinks...
check for low ink level it need to replace the color or the black cartridge click on the printer status to see what cartridge is near empty, or you can check for pending job right click on the printer then open it if you can see that it has a pending job delete it all
Aug 09, 2011 | HP Photosmart 7450 InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Printer makes noise and doesn't print. The triangle sign is lit up.
The printer displays an orange blinking attention light which will not clear.
This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1.Insufficient power.
Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2.There is a paper jam in the printer.
Click here for information about clearing paper jams from the HP Web site at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00230694.
3.The top cover is open.
Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4.No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick.
Perform the following steps to load tray 2.
a.Pull the tray out of the printer and remove any paper.
b.Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
c.Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
d.Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
e.Slide the tray back in the printer.
5.The tray 2 paper level indicator is stuck.
Click here for instructions on repositioning the tray paper level indicator (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00276974).
6.If the printer comes back to a Ready state, print a Self-Test/Configuration page.
If the printer is not in a Ready state, proceed to step 7.
a.Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
b.Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7.If the attention light is still on, perform a cold reset.
A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
a.Turn the printer off.
b.Press and hold down the green GO button.
c.Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
d.Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
e.The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
This is generic information for HP laserjet printer,
if you still have problem, please leave the printer model and make as comment and we may hel you
Rnj VINODKUMAR
Oct 17, 2009 | Office Equipment & Supplies
THE ORANGE LIGHT IS ON AND NOT PRINTING
Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Oct 02, 2009 | HP LaserJet 1320n Printer
Ip 5300 error b200 10 blink orange-green
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Sep 26, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
I have a HP LaserJet 1320n printer and it will not print. An orange light keeps flashing by the triangle with an exclamation point in it. I printed a test page and it was okay. It will not print...
Possible Solution to your issue!
Feb 23, 2009 | HP LaserJet 1320n Printer
Sharp FO 6700 Plain Paper Laser Fax
No there is no configuration page. The red blinking light means you have no paper under your blue tray or the paper empty sensor is broke. To identify the noise open the lid then close it, if you hear the noise while the fax is warming up then most likely you have a bad gear that meshes with the fuser drive gear, although it could also be the toner or drum. If it's not the toner or drum I stongly recommend a service technician , he should be able to provide an exit tray.
Oct 05, 2008 | Sharp FO 6700 Plain Paper Laser Fax
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Red and Green lights are together blinking continiously
I had this problem. The cancel button was stucked. Open the toner tray and slighly push the button side top-cover up. It released the cancel button for me (actually I was trying to open the top, but it worked). The cancel button was released and the blinking red-green stopped. Printer now working.
Mar 03, 2008 | Samsung ML 1610 Laser Printer
Won't feed the paper
the problem with your machine maybe that the default paper size programmed into your machine. My guess is that it is set to legal size{ 81/2x14} Get your owners manual out and see how to program the paper size in the user settings sections.
Jan 18, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageCLASS D320 Digital Copier Logo
101 people viewed this question
old marine
old marine
