Question about Brinkmann Grilling
Do all grills take the same regulaters does a four burner take the same as a 2 burner?
    Brigadier General:
  • 4,736 Answers
For the most part, yes. The size of the regulator is based on what the maximum BTU Output of all the burners (Main Burners, Side Burner, Rotisserie Burner, etc) would be, if they were all turned to high at the same time. To keep the cost low, most manufacturers use the same hose/regulator assembly on all their grills, regardless of the number of burners.
Hope this helped you and Happy Grilling!!
Posted on May 27, 2011
  • Rich Landrum May 27, 2011
    Glad I could help you. Thanks for the 4-Thumbs Up Rating. I really appreciate it.
Genesis Silver B Grill: grill won't heat past 350 or so. put a new regulat...
An odd thing with many propane gas grills is how the regulator functions. If the tank is opened too fast the regulator over-adjusts and delivers no gas. Try this: Turn tank off and open all burner controls. This should clear the line of any gas. Close burner controls and open tank very slow. Now lite and temp should go up.
May 17, 2010 | Weber Genesis Silver B Grill
Gas flow
Your regulater connected on tank has a shut down safety inside of it. disconnect tank hookup, then reconnect, always open tank valve slowely when you open to fast regulator thinks there is a leak and starts shutting down valve to slow leak. Opening slowely will solve your problem.
Aug 17, 2009 | Weber Genesis Silver B Grill
Not enough gas going to grill
Check the flexible hoses from the burner valves to the burner, as well as the orifices on the back of the valves where they attach to the flexible hoses. Spiders love to build webs there. Be sure the flexible tubes are fully seated on the back of the valves when you reassemble them to prevent a possible fire hazard.
Jul 03, 2009 | Grilling
Cal flame gas conversion
hi my name is mark, there are several possablitys why it can not be converted, one could be the orifice is pressed in manifold, another is it might require a different burners with air shutters and a regulater. it was problably designed for propane only, to save cost.
Mar 13, 2009 | Cal Flame 5-Burner
Glas flow will almost shut down once i turn on the second burner
hi my name is mark, let me see if i understand your problem. you light the 1st burner and get a good flame. you light the 2nd burner with the 1st burner lite and it starves both burners of gas. if this grill is a lp grill and you have propane in the tank. the regulater is the problem.
Feb 22, 2009 | Kenmore 16228 Grill
Please help
have you cleaned the burners? if they are not clogged your regulater is the problem and should be replaced asap. don't use the grill until you have replaced the regulater if that is the problem.
Sep 01, 2008 | Char-Broil 7000 Quick Set Gas Grill
Regulator freezing up
did you replace the regulater with a manufatures replacement for you grill or did you use an after market one? the reason i ask is because propane is very cold in liquid form and if your regulater allows more of the liguid to go to your burners than it should the moisture in the air will contact the outside of your regulater and freeze up on it. excessive propane would not change the color of the flame, however the i would check the burners to make sure that there are no blocked holes this would cause this to happen as well you are still safe to use the grill but cleaning the burners is a good idea. also there is a rating on the regulater make sure it matches the old one you replaced it with........good luck
Aug 31, 2008 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Cant get the burners to stay lite.
Spiders like to create little hidey webs in the tubes of propane grills and stoves.
Take it apart as much as you can and blow compressed air through all of the holes and apertures. You can either take it to the gas station and us the $.25 air machine or buy a can of compressed air at your computer store.
Apr 13, 2008 | Grilling
Grilling Logo
137 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
