Question about Directed Video Mobile DVD Player with 9" Widescreen Overhead LCD Monitor - OHD901 Car Video Player
I have just recently bought a new car and a Directed DVD ohd901 player came with it. I am able to turn the dvd player monitor on, but the moniter is not recognizing the dvd player as an input source. It says either, 'AV 1' or 'AV 2'. The dvd drive is able to pop out from the player, and the monitor will still work. The whole playing device is connected to another that allows me to play two more video sources to the monitor (these im guessing are the two AV sources) Thanks William
blueextc3221
  • 15935 Answers
SOURCE: Dircted mobile video
Is it FM Modulated or direct connect?
Is it on the proper station?
Did u buy used or have installed?
Could be many reasons. Has to be troubleshot in person.
Posted on Dec 22, 2008
  • 52 Answers
SOURCE: I just installed a Directed OHD700 Car DVD Player.
Some in car dvd players wont play on screen with car turned on. I wired a switch to the remote line to bypass. Wiring is defintly the issue
Posted on Mar 24, 2010
SOURCE: directed video ohd1021... have to turn sound up to hear on fm
i need the power supply if your interested on selling it ill buy it
Posted on Sep 08, 2010
rockmeister
  • 2047 Answers
SOURCE: We have a directed Video
When the DVD stops spinning this happens because the motor which is responsible for spinning the disc has either gone bad or the sensors which trigger the unit to spin the disc is faulty. Usually when this happens the lens of the unit usually gets affected.
To fix this first you have to open up the unit and test if the motor is still functional if it is then the sensor will have to be replaced to enable the unit detect the presence of a disc and roll. After this has been done then you have to try it to see if the lens is intact before you mount the unit back.
But basically the problem with these units is that when one part gets affected it affects numerous other parts so usually i advice get an expert to look at it so a complete repair job will be done and you wont experience an issue of the unit playing but without sounds.
Hope this support has been helpful?
Thank you for visiting FixYa.
Posted on Jul 17, 2011
bugoy31
  • 1238 Answers
SOURCE: I purchased a used car
Good day kvanhook!!!
That cables should be connected properly in each corresponding colors (colors by colors).
Then tell me what will happen...If that cable connection did not work just add a comment..
Thank you!!
Posted on Aug 15, 2011
How to load dvd in moniter
Unless you have an all-in-one computer, there is no dvd player in the monitor.
Mar 11, 2014 | Samsung Computers & Internet
Can i play an iso file in my standalone dvd player
No. You can't play .iso files in any standalone DVD player.
Mar 15, 2012 | Pioneer AVH-P4000DVD Monitor
I can not get the sound to go through the radio
Turn on FM modulator in OH monitor from the menu screen. Set station on screen, tune stereo to station.
Sep 24, 2010 | Directed DEI AutoMate OHD1021 Overhead LCD...
I just installed a Directed OHD700 Car DVD Player. Audio works fine but no picture. just white screen. What can be wrong?
Mar 24, 2010 | Directed OHD700 Car DVD Player
Monitor says protect
my kvt512 shows PROTECT on the moniter, how do fix it?
Feb 15, 2009 | Kenwood KVT-512 Car DVD Player
Directed 9" Model OHD901 Power comes on, lights will come on, screen shows AV1 & AV2, but will not switch to DVD screen, and will not play dvd.
Preliminaries: (call Directed if these fail at 1-800-274-0200)
Make sure the disc format is supported - not HD, not Blu-Ray, and not an unfinalized burned disc
Make sure the lock switches are firmly in place
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off.
Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE)
Press the (SOURCE) button on the remote or momentarily press the POWER button on the left
side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting:
DISC does NOT Play
Parental code is set lower than than allowed by the DVD mounted.
Ensure the disk is mounted in the player with the correct orientation (shiny side up).
The disk is warped.
The player cannot play certain formats (see the beginning of this manual).
The region code on the DVD does not match the player.
Moisture condensation has occurred within the player. Leave the unit on and the disc access cover
open and try again after about 30 minutes.
The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came
with your disc authoring equipment.
May 23, 2008 | Televison & Video
Directed 9"Model OHD901: Power comes on, lights work, screen shows AV1 and AV2, dvd will not play at all
or
SOURCE (MODE)
DISC does NOT Play
The disk is warped.
Component conecters
alright...those are Component Connectors...your DVD, and VHS will not work with that Monitor at all.
The Best and Cheapest Option...is to Buy a "Modern" DVD Player...which almost every single one Has Component Connectors.
On your Current DVD, VHS...ECT. The Red and White is Audio respectively, and the Yellow is the Video.
On a Component However the Red, Blue, and green...are all Video. You will need to use your "Current" Red and White Audio Jacks from your DVD and VHS Players on your New Monitor, and New DVD Player.
As Far as VHS is concerned...if you Buy a DVD/VHS Combo...you should have a S-Video Jack on Both the Monitor, and the DVD/VHS Player...Buy a S-Video Plug.
With that you will be able to watch both DVD's, and VHS Tapes without issue
Nov 26, 2007 | MegaVision MV220 Monitor
SOUND NOT GETTING ANY
it may seem obvios but take the dvd player out of the dashboard and check all connections.if this fails you may have to take it to a audio specialist to check if the internal amplifier of the unit is functioning correctly.
Feb 25, 2007 | Directed OHD1040 Car DVD Player
Car Audio & Video Logo
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Mark Skinner
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
