Toshiba dvr17kb,load vcr tape in and loads for 5 seconds the the machine turns off
  • 517 Answers
Good day!!
At first move..try to wiggle/move the wires of your toshiba if that move didn't work try to check the plug if it is plug in accurately maybe it was just loose then if this move does not work out then please message me/comment me.
Thank you!!
Hope to help you...
Posted on May 27, 2011
Recorder switches off when I put a vcr tape in machine.
The loading mechanism is not working properly. When that happens many units are programmed to shut themselves down.
Mar 10, 2016 | Toshiba rd xv48dt
Toshiba VCR
Check this link it has some solutions that you can try in removing the tape inside the VCR http://www.fixer.com/no-eject.html
Hope that helps...........
Sep 12, 2008 | Televison & Video
Shuts off when trying to play or record
This could be due to the VHS tape sticking on the tape reel, that triggers the overload and the shutdown. Try fast forwarding if possible.
Nov 01, 2017 | Emerson EV787 VHS VCR
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
MINI DV TAPE WON'T LOAD
First power off the unit, then remove the DV's tape housing , power up the unit, and allowed the mechanism to go back to the unload mode, make sure that the tape posts are at unload mode. then unplug the vcr back again, put back the tape's housing in the load position (tape in) power the vcr back on and push eject button to reset tape mechanism.
Jan 16, 2008 | JVC HR-DVS3 Mini DV/S-VHS VCR
OWNERS MANUAL
from the manual:
turn on tv & set to video input mode. REMOVE erase protection tab from tape. Load tape & DVD. THEN ON YOUR REMOTE:
1. press DVD (DVD indicator lights up).
2. Press REC MODE/SPEED & choose your speed.
3. Press VCR (VCR indicator lights up)
4. press DUBBING
5. select YES
6. to stop dubbing, press STOP
good luck!
Oct 13, 2007 | Toshiba D-VR4 DVD Recorder/VCR
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
