Just put new batteries in remote sensor but now cannot get it to transmit to base station
    Brigadier General:
  • 8,546 Answers
Have you looked at the manual?
The specific product you're inquiring about is not showing in your post. Name the make and model first, then we'll look for the manual. Then (maybe) find a solution. You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Google search: "(product) manual"
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Or look on eBay, usually much cheaper if available.
Posted on May 27, 2011
Bought inside/outside wireless weather station. Inserted batteries as directed. Inside works, outside temps don't register at all.
Make sure that the channel (1,2,3) agrees between the sender and base. You might try a different channel due to interference. double check batteries. Then -- remove batteries from remote and base. Then put batteries in remote first (should be next to base) then insert batteries in the base. Be sure channel is in agreement between the units. Sync can take a minute or longer.
Apr 16, 2018 | Measuring Tools & Sensors
How to set up taylor `model 1731
  • Indoor (32°-122°F/0°-50°C) and outdoor (-4°-140°F/-20°-60°C) temperatures. Lower outdoor temperatures achievable with lithium batteries; Indoor and outdoor humidity. Includes temperature and humidity trend indicators; Daily min/max recall for temperature and humidity. Features a calendar and clock with alarm; The wireless remote sensor transmits up to 200 ft. The base station and wireless remote require 2 AAA batteries each, not include. If you want essay related topic you can go for custom essay writing service will get better result.
New Generation Custom Essay Writing Service with Intelligence EssayCaptains
Feb 06, 2017 | Taylor Health & Beauty
How do I reset the main unit of my weather station. I just put new batteries in the sending unit.
  • Remove all batteries
  • Install batteries in sending unit. Allow time for sending unit to begin transmitting temperature
  • Install batteries in main unit. You should see outside temperature displayed
Jan 10, 2017 | Measuring Tools & Sensors
Outdoor sensor won't work. Tried changing battery, no luck. Been trying this on and off for weeks. Any suggestions?
Some brands of Wireless thermometers need to have the base station reset to synchronize with the remote sensor. You would need to take the batteries out of both the remote sensor and the base station and then re-install all the batteries in both units (or three units if you have more than one remote sensor)
Each Manufacturer has their own procedure, La Crosse needs the procedure I described on many of their older systems. They may have changed it on the newer systems because I HATED resetting everything every time I change one set of batteries.
Feb 18, 2016 | Measuring Tools & Sensors
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Replaced batteries, outsid temp. does not display
Jan 05, 2016 | Taylor Measuring Tools & Sensors
Why is there a red blinking light on outside sensor? This is only 2 weeks old and new batteries were put in then.
The red blinking light, I believe is indicating the outside sensor is transmitting the outside temperature data to main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
My weather station is no longer recieving an outdoor temperature reading. The barometer is working fine, as is the indoor base station. Both were given new batteries at the same time, and the set up i
hi,
does the outside humidity working ?
if yes - the outside station is transmitting but the temperature sensor is faulty,
if no sensing is available from the outside station, it look like the outside station is faulty . (this is common because of extreme weather change.
notice that the pressure sense is done in the base station.
regards ,
Daniel
https://www.rylwy.com/
Nov 23, 2017 | Measuring Tools & Sensors
Acurite Manuals
Remove new batteries from the indoor station. Carefully remove batteries from the remote sensor, then reinstall. Reinstall new batteries in the indoor station. DO NOT TOUCH ANYTHING FOR AT LEAST 10 MINUTES. You should see the outdoor temperature displayed and can then proceed with other settings.
Nov 03, 2013 | Measuring Tools & Sensors
No signal
Check the batteries, antenna and location of the base station in relationship to the sensors. Check each sensor's batteries and locations (not near large metal objects and high enough to send signals. Move the base station close to a window facing the remotes...
Dec 31, 2012 | Measuring Tools & Sensors
 Grubhead
Grubhead
