Question about Brother DCP-9045CDN Laser Printer
Printer is Borther DCP9045CDN - printed B&W pages are faint down the right hand side despite new toner cartridgesnad attemtp to clean laser windows
  • 1,719 Answers
If the Toner Cartridges are OK, the faint image is certainly due to the dust/ toner dust on the optics inside the printer, which reflect the lase beam forming image on the drum. The lase beam gets partially blocked due to dust and as a result the image is faint. There are mainly two parts responsible. (1) The mirrors (s) lenses.
So, it is recommended that you carefully clean the optics of the printer (lenses & mirrors) from front as well as back and edges of the rotating mirrors (if present). You may use cotton swab or a very soft, lint free cloth for cleaning. Apply some glass cleaning liquid (only) if it is required. Hope you would be able to fix it.
Hope it helps! Good Luck!
CreativeTECH
Posted on May 27, 2011
  • 91 Answers
You need to replace The drum unit Or fuser unit.
Oki b410d printer has a new toner cartridge however it is still printing inconsistently on the page?
Open the lid. Mounted under the lid you should see a horizontal bar which is actually the laser [LED]. Once your toner cart has emitted, enough loose toner has accumulated on the laser that it can no longer draw on the page correctly. Using something soft and barely dampened with water [use a soft cotton cloth, NO PAPER PRODUCTS, no dirty rags, etc] and wipe gently from L to R to remove the loose toner. Turn to a clean section of the cloth and do it once more. GENTLY! No pressure, do not scrub it, or you can damage the laser. Close the lid and print something. You should be back to good now.
Oct 04, 2014 | OKI B Office Equipment & Supplies
My samsung scx-4200 printer prints very faint on the left hand side
removed the toner and shaken it and then replace it.then it prints normally. or problem not solved you have to replace new toner.
Aug 05, 2012 | Samsung SCX 4200 All-In-One Laser Printer
2 of our Lexmark E250dn printers have both developed the same issue over the span of a few weeks where printing appears more and more faint towards the right hand side of the page, we have tested the...
If the Toner Cartridges are OK, the faint image is certainly due to the dust/ toner dust on the optics inside the printer, which reflect the laser beam forming image on the drum. The lase beam gets partially blocked due to dust and as a result the image is faint. There are mainly two parts responsible. (1) The mirrors (s) lenses.
So, it is recommended that you carefully clean the optics of the printer (lenses & mirrors) from front as well as back and edges of the mirrors. You may use cotton swab or a very soft, lint free cloth for cleaning. Apply some glass cleaning liquid (only) if it is required. Hope you would be able to fix it.
If you are familiar with the process of printer repair etc, you can do it yourself. Otherwise, the printer requires cleaning/ servicing by a professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 01, 2011 | Lexmark E250d Laser Printer
Ink on left hand side of page very faint
First make sure that the print cartridge has enough toner. If the toner is OK, it is most likely be due to dust/ toner dust accumulation at the laser reflecting mirrors inside the printer, which partially blocks laser beams and results in faint print. Therefore the printer requires cleaning/ servicing by a professional.
CreativeTECH
Apr 07, 2011 | Dell 2130cn Laser Printer
There is a faint background shadow covering the
remove toner/drum unit from the printer. remove toner from drum unit and shake toner cart. side-side to loosen toner inside. On top front of the drum unit there is a purple/blue button that will slide right-left. Do this a few times to clean the wire. If there's a lot of loose toner, take a vacuum and clean carefully. Put everything back inside. With front door still open, hold GO/Control button down until all lights have lit, then let go, close front cover.
If you still have the shadow over the page, it's most likely the toner cart and you need to buy a new one (or recond.-refill) at someplace like Office Depot or Staples.
Jan 20, 2010 | Brother HL-2040 Laser Printer
Our Laser printer doesn't print on the left had side of the paper--well, very faint--the right side is just fine. I just replaced the cartridge. What is the problem?
If your printer prints like this:
657b300.jpg with the any color printing faintly down the page, then the problem is with the developer blades in the imaging unit. What happens is there are metal blades that meter the amount of toner that gets put on to the drum that makes the image on the paper. The toner is made up of fine particules of plastic. As the printer prints, some of this toner collects on the edge of the developer blades causing less and less toner to make it onto the page making the print look faint.
To correct this problem, you either need to buy a new imaging unit or clean the developer blades. There is a document on the internet that gives a detail instructions on how to do this, but, the link no longer works. I have a copy of this document, I will try to post it if people are interested.
Jan 15, 2010 | Samsung CLP 300 Laser Printer
My Samsung CLX3160 prints very faintly (colour & b/w)
I have instructions on how to clean the developer blades. It should fix the faint printing that you are experiencing. It is posted in my Tips section.
Jan 08, 2010 | Samsung CLP 300 Laser Printer
I have fitted a new toner & drum, reset the drum but the printing is still very faint
try to clean laser glas - pull out the drum unit put your hand in the upper side - clean the glass
Sep 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother DCP-9045CDN Laser Printer Logo
178 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
