Question about Garden
Saw just cut out while i was ripping timber, i gone to restart it again and it wont pick up speed, i start/stop and sometimes it doesnt start you get a buzzing coming from the motor, its almost like it wants to start but can, other times it will start and go slow then stop, blade is spining free with no jaming,
  • 2,239 Answers
This not sound sound good, if there is a circuit board with over load protection and soft start this may well be at fault, it could also be a motor issue, this is a job for an electrcian.
Posted on May 30, 2011
My saw stops rotating during cutting
does the motor stop? If not the gears are worn between armature and spindle. If it does stop you could be applying too much pressure trying to cut with a blunt blade or there is an armature fault.
Apr 24, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
My car cut's when am driving,it stops pulling,when i step on the accelerator only the rave counter moves the, speedometer doesnt move.when you stop for sometime again it picks up
If it's an automatic, I think your transmission is gone. Done. Done in.
If the engine wants to roar, but the legs won't move, well, it's the transmission. When the fluid inside it gets hot again, the gears start slipping.
That's my take on it, humphrey, but of course check the fluid level and quality or appearance and smell, you know, before you do anything. If it was real low on fluid, like over a couple of quarts or even one, you might get lucky and keep it full and not have any more problem. If the fluid is real dark, dark brown or dark red, and has a distinctly burnt smell, ...that's very not good. The fluid should be clear and red or pink in color. Have someone confirm or not if your transmission is bad. good luck.
Nov 26, 2012 | Cars & Trucks
My original blade broke so i bought a new blade from wickes 10tpi now when i use it i saw on the line i have marked but on the other side of the 2x2 it is about quarter to hallf inch out how can i make...
There are good blades and there are cheap blades. Good blades are straighter but less tolerant of poor technique and so tend to break, cheap blades can and do bend far more. You can keep the blade straighter by not forcing the blade through the work and allowing it to cut at it's own rate and by experimenting with the speed settings on the jigsaw. It also helps if you pick the correct blade for the job: 10tpi is a bit too coarse for ripping a timber batten along the grain but fine for rough cutting chipboard. Also, it's difficult to keep the foot of the jigsaw absolutely level on 2x2 which adds to your problems.
Aug 15, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
I have a Dewalt model 7730 radial arm saw. When the on button is pushed the motor starts off real slow as if it is under a bind or load but after a few seconds it picks up speed and seems to turn at full...
most probably it is bit of timber on the bottom of the saw assembly...
1. switch off the saw
2. remove power plug
3. remove screw and clear protector assembly
4. remove centre panel (as to changing the blade)
5. remove blade and clean dust furrow below it from all debris
6. re-assemble in reverse order
7. mount safety protector assembly
7, connect power cord
8. start in shor burst and switch immediatelly off, after blade stop spinning, check blade assembly if not wobbly.
this should solve your problem.
if you find this advice useful, please do not hesitate to leave comment and give me your vote4 fo rme, thanx!
Aug 02, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Wood feels like its "pinching" between blad and fence
Possibly the problem is the wood itself. If it is burning both sides of the kerf then it is probably that your kiln dried wood is picking up moisture on the outside from the environment which causes it to bow inwards as it passes the saw. I have even had this problem with plywood. Just keeping timber in an unheated workshop for a while can cause the problem but after a few months it should equalize and the problem disappear at about 15% moisture content. (kiln dried timber should be nearer 10%)
Cut part way along a plank and then mesure the kerf at the end of the plank and at the front of the cut. if it is significantly narrower at the plank end then that is your problem.
These hard woods you mention are always a problem to cut on domestic saws at usually a maximum of 2000 watts . I use a 4500 watt motor in my saw and it will still complain at dry oak, ash and maple etc. especially if they are moving a bit as I cut them. Before I retired I had a panel saw half as powerful again as that and still those hard woods could cause trouble.
Jun 01, 2010 | Craftsman 10" Table Saw
Cutting 19mm oak veneered mdf with my new 28v
check to see if u can increase the speed, or try on a thinner piece of wood. or even try a new blade with more teeth.
Aug 13, 2009 | Dewalt DWS520SK Track Saw Kit with Short...
Cut off question
Here a few examples: * 5 inch trim saws, usually with a fine-toothed blade and often with the blade located on the left side of the motor, for easy viewing of the blade path. These are available in 120V, AC models, and rechargeable battery models in various DC voltages. * 6 1/2 inch saws, as shown in the illustration above, used for cutting to length nominal lumber for construction, as well as ripping lumber, and cutting plywood or composite material. * 7 1/4 inch saws, often call skillsaws, from the name of a major circular saw manufacturer, Skill. These are the backbone of the construction industry, used for cutting lumber up to 2 1/4 inch thick. They are used for cutting framing lumber to length, and ripping lumber. They also have a number of optional blades which can be used for cutting composite materials, concrete, ferrous and nonferrous metal sheeting, pipe, tubing, and even cold-rolled steel bar stock. * 8 and 10 inch saws, used for cutting to length larger lumber or timbers, up to 4 inches thick. These are heavier, more cumbersome tools used mostly in industrial work. * Worm-drive saws have a gearbox with a worm-geardrive, and are found in 7 1/4 inch models which are most commonly used for ripping lumber or cutting plywood decking or sheathing. They typically have the blade on the left side of the machine, to make watching the blade path easier when cutting parallel to the edge of a wide sheet of plywood.
Aug 27, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
