Can DNA be taken from cuts of hair or does it have to contain the roots Also can it be taken from a stamp or envelope which has been licked and for how long can it have been there before its no good
  • 17 Answers
Http://answers.yahoo.com/question/index?qid=20100728234025AAy4VRU
http://wiki.answers.com/Q/How_do_scientists_get_DNA_from_a_strand_of_hair
Posted on May 27, 2011
What's easier to get a DNA sample of?
Out of the two blood is the easiest, fingerprints do not typically yield DNA unless skin is left behind, and live cells are again fastest and easiest. Saliva is just as good as blood and can be found many places people do not even think about such as, cigarette butts, drinking glasses, chewing gum, postage stamps, sealed envelopes etc.
Jan 04, 2017 | Books
Are there human DNA in hot dogs
Yes, looks like it, but DNA screening is so sensitive, it could be one hair minced up, or a few flakes of skin.
http://www.bing.com/search?q=human+DNA+in+hot+dogs&src=IE-SearchBox&FORM=IESR02
Oct 27, 2015 | Dogs
I don't know how to put an envelope in to print it out.
Please follow the steps below on how to print on an envelope:
  • The print side of the envelope is faceup.
  • The paper guides rest against the edges of the envelopes.
  • You print the envelopes with Landscape orientation. Note: If you are mailing within Japan, then the envelope can be printed in Portrait orientation with the stamp in the lower right corner or in Landscape orientation with the stamp in the lower left corner. If you are mailing internationally, then print in Landscape orientation with the stamp in the upper left corner.
  • You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so your envelope is correctly positioned.
I hope this information has been helpful. Thanks.
Oct 22, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Remove date/stamp from pictures already taken
Once the stamp is on the picture it's just like any other element of the picture. You can try to remove it using a photo editing program, the same way you might remove a telephone pole growing out of someone's head, for example. There is no magic feature that will automatically recognize the pixels making up the stamp and recover what was there originally when the picture was taken.
Sep 05, 2009 | Samsung S850 Digital Camera
How do you print an envelope
Stamps .com sends you blank sheets of stamps, you insert those sheets per the instructions and print stamps to apply to the envelope.
Aug 27, 2009 | Panasonic Workio DP-3030 Printer
I have a Lexmark C510, how do I print a business envelope?
You can load up to 10 envelopes in the standard tray. Try a sample of any envelopes you are
considering using with the printer before buying large quantities. See Loading envelopes in the
standard tray
for instructions on loading envelopes.
When printing on envelopes:
To achieve the best possible print quality, use only high-quality envelopes that are designed
for use in laser printers.
Set the Paper Source in the Paper Menu based on the source you are using, set the Paper
Type to Envelope, and select the correct envelope size from the operator panel, the printer
driver, or from MarkVision Professional.
For best performance, use envelopes made from 90 g/m2 (24 lb bond) paper. You can use up
to 105 g/m2 (28 lb bond) weight for the 250-sheet standard tray or 105 g/m2 (28 lb bond)
weight for envelopes as long as the cotton content is 25% or less. Envelopes with 100%
cotton content must not exceed 90 g/m2 (24 lb bond) weight.
Use only new, undamaged envelopes.
For best performance and to minimize jams, do not use envelopes that:
Have excessive curl or twist.
Are stuck together or damaged in any way.
Contain windows, holes, perforations, cutouts or embossing.
Use metal clasps, string ties, or metal folding bars.
Have an interlocking design
Have postage stamps attached
Have any exposed adhesive when the flap is in the sealed or closed position
Have nicked edges or bent corners
Have rough, cockle, or laid finishes
Use envelopes that can withstand temperatures of 170°C (338°F) without sealing, excessive
curling, wrinkling, or releasing hazardous emissions. If you have any doubts about the
envelopes you are considering using, check with the envelope supplier.
Adjust the width guide to fit the width of the envelopes.
Load only one size of envelope at a time in the tray. Envelopes may only be loaded in the
standard tray. Load them with the flap down and the flap to the left of the tray.
A combination of high humidity (over 60%) and the high printing temperatures may seal the
envelopes.
Loading envelopes in the standard tray
The recommended stack height is 10 envelopes; however, in normal environments as many as 15
envelopes may be loaded. In high temperature or humidity environments, only seven envelopes
should be loaded.
1 Pull the standard tray completely out.
2 Squeeze the length guide tabs together as shown in step 2 on page 42. Slide the guide to
the correct position for the size of envelope you are loading.
3 Squeeze the width guide tabs as shown in step 3 on page 42. Slide the width guide to the
correct position for the size of envelope you are loading. Notice the size indicators on the
bottom left of the tray.
4 Push the envelope stack aid tabs toward each other. They snap into place.
5 Flex a stack of envelopes back and forth and then straighten the edges on a level surface.
Press down the corners to flatten them.
Fan the envelopes. This prevents the edges of the envelopes from sticking together and helps
them feed properly.
6 Load envelopes flap side down with the stamp area and flap on the right. The end of the envelope with the stamp area enters the printer first.
7 Insert the standard tray.
Feb 26, 2009 | Lexmark C510 Laser Printer
Help
Hi, solution for your envelope
10 envelopes The print side of the envelopes faces up.
The envelopes are loaded vertically against the right side of the paper support.
The stamp location is in the upper left corner and printed with landscape orientation.
NOTE: For Japanese customers: If you are mailing within Japan, the envelope can be printed with portrait orientation with the stamp in the lower right corner or with landscape orientation with the stamp in the lower left corner. If you are mailing internationally, print landscape orientation with the stamp in the upper left corner.
The paper guide rests against the left edge of the envelopes.
You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so that your envelope text will be correctly positioned.
Oct 25, 2007 | Dell 810 All-In-One InkJet Printer
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
