Question about Samsung SyncMaster 913N 19" LCD Monitor
My SynMaster 913N seems impeccable when it has not been on for a long period. When I turn it on, it works for some time - half hour. Then I get this message: "Not Optimum Mode Recommeded Mode 1280 x 1024 60 HZ" But I've already put mode on these values. So what kan I do?
  • 2,574 Answers
You can see this message when the signal from the video card exceeds the maximum resolution and frequency that the monitor can handle properly.
When "Not Optimum Mode","Recommended Mode 1280 x
1024 60Hz" message comes up, disconnect the cable from the computer while the monitor is still
powered on.If there is a message coming up on the screen or if the screen goes white, this means the monitor is in working condition.In this case, check the computer for trouble.
Try to change the screen refresh rate ..to 60Hz .>http://support.microsoft.com/kb/311403
Also visit the link below:
repair-samsung-lcd-monitor.html
Posted on May 27, 2011
  • Samsung Master
  • 3,530 Answers
Welcome to Fixya
Boot the computer to safe mode (hit F8 while computer booted up and then selected "safe mode"), changed the display resolution to 1280 x 1024, accepted change (screen reflected this) and then rebooted normally.
Thank you for using Fixya!
  • Samsung Master
  • 2,098 Answers
Hi grsi,
This kind of symptoms must be isolated between the monitor, computer(video card), and VGA cable.
First ensure the cable connection from your monitor and the computer. You must swap/try another cable as much as possible. If the unit still persist, try your unit to other computer to isolate the video card from fault. If the symptoms does not appear in other computer, this was caused by the video card on your computer. You must pull-out this card to the mother board and clean the lead.
Let me know if the symptoms still there...
Jdvillanueva
Samsung monitor goes blank after working perfectly for a period of time.
Have you checked monitor settings Carl? Some are set to sleep after a certain period of time. Mine was set to sleep after 1 hour (unknown to me) until I reset it. =)
Dec 06, 2015 | Samsung 933BW 19 inch Monitor
Why does my receiver start stop producing audio output half an hour after turning it on?
Most likely is an intermittent solder connection opening up as set warms up.
May 09, 2012 | B&K CT600
When i come back to my sync master 2233rz monitor after leaving it alone for atleast an hour, half of the screen goes bezerk and the only way i can fix it is by restarting my system , please tell me what i...
Hook a spare monitor to your computer, if okay! the problem is in the SynMaster, but if both show the same it indicates a video graphics card problem in the computer, Hook your SyncMaster to the computer and change the video cord from the computer to the monitor just to be sure. If no change! it is time to replace the monitor "the LCD panel is defective" not cost effective to repair.
Mar 23, 2012 | Samsung SyncMaster 2233RZ 22 inch 3D LCD...
Programing
You posted under Leviton 6124 programmable timer.
If this is not your timer, add a comment
Leviton 6124 manual:
http://waterheatertimer.org/images/6124-manual.pdf
If you have different timer, look at link below to help identify timer.
Leviton Timers:
http://waterheatertimer.org/Leviton-timers.html
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Dec 02, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Syncmaster 913v not optimum mode
I just resolved this problem for my SyncMaster 913N.
It seems to be a known issue, however it can take quite some time for the problem to occur. In my case about 3,5 years, so well out of warranty.
Short term solution: unplug your monitor from power. The switch on the front is not good enough. Pull the plug and leave it for an hour or so (all night if you can). Good chance the monitor will work next time you power it up.
The problem will is likely to come back..
Permant fix requires some basic soldering as per this video:
I just managed it and it has been ages since I soldered a resistor so you may very well be able to do it. I spent $25 on tool and part and saved me from buying a new monitor.
Mar 20, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Decora 6124H Timer
Jan 04, 2010 | Leviton 6124H 24 Hour LCD Programmable...
Syncmaster 181T periodically shuts down
monitor ACER 17" S/N #ETL460C148710572-B4045 just off for minutes at a time. Please solve this.
Nov 12, 2009 | Samsung SyncMaster 181 T 18.1" LCD Monitor
Wont start mornings when warm starts good for a few times then wont again an also got i think engine management light come on in the dash when runing it comes on an off about half an hour apart
hi you need to get a reading off a fault code reader to find out what is causing the light to come on the engine manament light works off detecting not an individual fault it has to recieve this fault on 3-4 occassions before the light comes on if it doesn,t recieve a fault reading in a certain period of time it will presume the faults been fixed and the light goes out but 30 min period seems not enough time to for a reset the fault code reader should be able to store the fault code even ifs its not happening at the time but would be better if you can get the reading while the light is on yates210456
Oct 01, 2008 | Mitsubishi Passenger Cars & Trucks
Sasung 913n monitor
Same here. The unplug/inplug of the monitor seems to be the workaround. For now, I boot up Windows with the 913 unplugged and connect it after a couple of minutes when Windows has booted up. As mentioned before, this bug only happened to me after shifting to a PCIe card, Nvidia 6600 LE driver.
Dec 29, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung 913n
can anyone tell me were i can download drivers for samsung 913n monitor please thanx carlos
Dec 17, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung SyncMaster 913N 19" LCD Monitor Logo
80 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
