Question about Swift Science & Laboratory
Model 880 Swift Binocular Zoom Microscope Each zoom element consists of 2 co-axial tubular brass lens units, the outer of which rotates and in which there is a spiral groove. A nylon-headed screw, fixed to the inner unit, allows this unit to move up and down to alter the image size. Each zoom unit has a ring flange securing it to the main body and a number of small grub screws seem to allow minor adjustments. The inner retaining piece for the nylon screw has come loose and can be seen inside the inner zoom unit. My main question is whether this lens element can be detached from the body and how this can be done in order to secure the nylon screw into the spiral groove holding it to the inner unit. If you can also help me source a technical manual and a schematic parts diagram I would be most grateful. Kind regards, Chris Micklethwaite
  • 45 Answers
SOURCE: problem with MF-02 binocular microscope stage
I think your problem lies in the way the stage is limited upwards. On top of the stage, right behind it where it slides against the arm, there should be a little screw.  This screw limits the movement of the stage to a certain point upwards.  If the limit exceeds the adjustment gear and its opposing track, then the stage just goes up one notch and then it clunks down.  If you screw it down the stage is limited further down, if you screw it up it's limited a bit higher.  The point of this screw is to prevent objective and slide damage.  Try adjusting this little screw a bit further down and see if it still 'clunks' when you turn it up.  After that we may work on properly adjusting it.  If not, please post again with whatever detail you can provide to aid you with this problem further.
Posted on Jun 09, 2008
mistersony
  • 320 Answers
SOURCE: Loose Manual Focusing Lens Device
There is a bulletin (E31529192) that describes your exact problem and recommends replacing the screws with new different screws to prevent this from happening again. The front section around the lens assembly is only held by 3 screws so access isn't a big deal, just be careful if you try this because there is a cable connected to the microphone that is easy to damage. The new screws are part number 3-056-559-01. Be sure to rate this solution. Thanks!
Posted on Nov 01, 2008
Gryfox
  • 216 Answers
SOURCE: nikon dx swm 18-55 mm
This is a very common problem. It sometimes happens without cause, sometimes by tightening or removing a filter. There are a couple of keys that keep the front lens from rotating while zooming that are very thin and easily bent. They have to be removed and straightened, and the rear piece you see floating has to be reinserted. It's about a $40 job and half-an-hour by a local independent repair shop. Expect to pay Nikon twice that.
Posted on Jan 04, 2009
SOURCE: EF 24-70 lens droop...
The zoom creep is an easy fix for Canon. I really do not recommend trying to tighten it yourself, since that would void your warranty.
It is usually free to tighten the zoom ring.
/Chris
Posted on Jan 19, 2009
SOURCE: 25-30 year old Bamix M100 - 240V 100W
Those small plastig bungs do come out, you will need a fine probe to prise them out then you will see 2 philips head screws which hold it all together, not sure how you will tighten your shaft though, looks like it might be moulded into the plastic retainer, good luck! on mine the motor bearings are seized,
regards,
Dave Pary.
Posted on Mar 18, 2009
How do find a replacemnt bulb for this tasco 750 x zoom microscope?
contact tasco.
try ebay for a month (search various combinations of keywords). notify by email.
21.january.2015
Aug 02, 2014 | Tasco 750 Monocular Microscope
Tip
Digital cameras tip : zoom
Zooming is addition important application with digital cameras - there are two kinds of zoom: optical zoom and digital zoom. An optical zoom agency is one that relies on the lens itself accumulative the ablaze advancing in, so that what is abroad appears beyond and afterpiece in the consistent image. An digital zoom agency is one that takes the consistent angel and magnifies it afterwards the fact. Needless to say, an optical zoom agency is abundant added important than a digital zoom.
on Dec 23, 2010 | Cameras
Please Help. I have a Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX. I occasionally remove the front lens element assembly to clean the inner lens element as it gets dusty. The front lens element assembly...
Hi,IF I were you I will search the eBay for a same lens as " parts only " which means lens does not work but you can use the some parts of it ..There are a lot on ebay..one example is below URL..pls visit both..
Brand name services always do this..Since you were doing unauthorized repair ,they do not like it..
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Item condition:For parts or not working
http://cgi.ebay.com/Nikon-Nikkor-18-200mm-ED-AF-S-3-5-5-6-READ-/200635517251?pt=Camera_Lenses&hash=item2eb6cf0943
parts;
http://photography.shop.ebay.com/Lenses-/3323/i.html?_kw=Nikon&_kw=parts&_dmpt=Camera_Lenses&_stpos=&gbr=1
Jul 29, 2011 | Nikon Zoom-Nikkor 18-200mm f/3.5-5.6G...
Can you change a 3200 swift mono head with a binocular head and where can i find one
Yes, or providing they still make it. The monoc head is just held on with a thumb screw, and you can usually buy just the binocular head itself. You will most likely have to get the part through one of Swift Optical Instruments many distributors or dealers, but if you call Swift directly they will be able to direct you in the right direction: (877) 967-9438
Jan 27, 2011 | Swift M4002D Binocular Microscope
Zoom lens loose in tasco binoculars
Best to take this to a repair agent as there are inherent problems in trying to fix these by yourself. Main one being zoom registration between both sides of the binocular.
Jan 28, 2010 | Tasco Zoom 16-72140-1 (7-21X40) Binocular
No zoom function on a kalimar power zoom scope,
larry389's so-called solution is not a solution... just an opinion to which each individual is entitled... even when not correct! I've used a Zeika Opt. Co. Power Zoom Binocular No.25361 for over 25 years since inheriting them from my father who purchased them in early 1970. To say the least, treated carefully and with respect for the delicate instrument that they are, they've been wonderful and still work perfectly fine. Perhaps Larry's experience is based upon handling them like junk and, therefore, reaping what he has sewn.
Jan 21, 2009 | Optics
How to achieve full zoom with a Nikon 55-200mmf/4-5.6G ED lens?!
1) What camera body are you using?
2) I do not understand your assertion that it automatically zoomed in. Zooming is a manual function. The automatic functions of your lens pertain only to focusing on of the subject so that your picture is sharp and ensuring that the correct amount of light is admitted so that you have a correct exposure.
3) Are you sure you were turning the zoom ring and not the f-stop ring? The zoom ring is labeled 200 on one end of the scale and 55 on the other. It is also the widest ring on the lens barrel. When you rotate it, the physical length of the lens will lengthen as you rotate it clockwise (viewed from behind the camera) and shorten as you rotate it counter-clockwise.
4) For reference, at 200mm the angle of view on your lens should be 10 degrees and at 55mm about 40 degrees.
Dec 27, 2008 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
May 27, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Zoom
Lens probably got off its track. you need to take the front case apart and pull out the 3 lugs at the base of the outer lens. YOu should ba able to manage to get the outer lens off, dont worry about breakin git as the stuff is made of heavy plastic. If you get it off, see if the inner barrel rotates smoothly. YOu will be actig on a small motor so youll feel a little resistance, but it should be fairly easy to rotate. Lube the helical tracks with heavy white lithium grease and put the outer lens back on making sure to align the tracks, press the lugs back in and reassemble. worth a shot. I did mine and was successful. See my folder on the C8080 http://picasaweb.google.com/pishta68/8080lens/photo#5199141246863292738
Apr 24, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Science & Laboratory Logo
928 people viewed this question
Top Swift Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Swift Science and Laboratory Expert? Answer questions, earn points and help others
