Question about Uniden DECT15805 Cordless Phone
How do l change volume level and ring tone please
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
In standby mode use up-arrow and down-arrow on the handset or the volume+ and volume- on the base to change the ringer volume.
While on the phone, use the same buttons to change the volume.
If you need a manual, you can download one from the manufacturer's web site at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580om.pdf
Posted on Aug 29, 2011
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
To increases volume
first of all u can increase volume during call by pressing right button (middle one). but i think ur phone is set to max and u dont hear much - in this case probably some "metal dust" sticks on your speakers membrane - open case clean speaker gently or replace with new one...
Feb 07, 2011 | Nokia 1600 Cellular Phone
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How do I turn off the ringer volume??
I found this at hp website.
Adjust the volume
setting is Soft.
1 Press Setup.
2 Press 4, and then press 6.
tones.
4 Press OK.
Feb 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Volume on the phone/speaker/ring is very low
You can change ring tones by pressing the flash button until you get the ring you want. When you get the ring you want press the set button.
May 24, 2009 | Innovage Speaker/Caller ID* LCD Touch...
GE 28851 base handset #1, will not save ringer tone or volumn I selected. Brand New.
As it turns out, the primary base handset did save the newer selected ring tone and volume level setting.
However, the base maintains its own ring tone and volume level setting from factory.
Therefore, the base will present its own settings along with the handset setting during an incoming call.
So, one has to lower the volume of the base (in non-talk mode). The base should display in window: LO.
Then, only the ring tone and volume level selected for handset will be presented during an incomiong call.
How did I do????
Ken
Jul 09, 2008 | Uniden Cordless Phone
Uniden DECT15805 Cordless Phone Logo
130 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
