Question about Samsung Televison & Video
Hi, I have Samsung UE46C7000. Everything was working fine and after a month of usage suddently HDMI stopped working. I have 2 HDMi cables, one for SKY tv and another for Blue-Ray, on both sources I get meesage: Signal not found. Sky is working with the old, scart connection. Please advise thanks
markevans
  • 148 Answers
SOURCE: LG 42LC2D-EC NO SOUND ON HDMI
your setting for source of the audio is probably defaulted back to original setting in receiver. reassign audio input and problem may go away. it sounds like its not in the tv. i assume you have a receiver and are not trying to listen with speakers in tv. is this correct? if you are not using an amplifier, you may need to go to the tv menu to make sure the audio source is selected as the hdmi input. should take a bit to read thru the manual, but it ought to show you how to accomplish the correct settings.
let me know if it does not.
good luck
mark
Posted on Dec 23, 2007
SOURCE: no sound through ps3 hdmi
on ps3 go to settings sound and change sound out put to hdmi you will see 3 different options
Posted on Nov 07, 2008
  • 197 Answers
SOURCE: lh300 sky box works with scart but wont work with
on your tv, have you selected the correct mode on your source button? eg, AV1, AV2 , PC, and HDMI
Posted on Oct 04, 2009
SOURCE: tv flashes when changing channel on sky hd box
Hi I have the same problem I got my TV replaced just today got brand new even better model. and guess the problem is still there.it's not individual,it must be in the whole series. if you have a solution mail at hajjid@yahoo.co.uk
Posted on Nov 12, 2009
  • 16 Answers
SOURCE: just connected sky via hdmi through denon 3310 and
ensure that HDMI is selected in your sky settings.
you would not need an amp at all just to view sky, only if you were routing sound to say a surround system.
Are you only getting no sound from the tv? or are you getting sound via the amp but not from the tv?
Posted on Nov 22, 2009
Hi I have a Samsung ht 350 home cinema,everything works fine good sound and everything but the only thing I don't understand is when I connect hdmi from it to the tv the Samsung goes in to prot mode??
Could be a faulty cable. Try changing the HDMI cable. Either that or the output from the TV is excessive. Check that the TV to make certain the HDMI output is the right kind.
Feb 14, 2016 | Samsung Audio Players & Recorders
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
Feb 09, 2016 | Sony Televison & Video
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
I have a samsung tv and samsung blu ray i have my dvr in hdmi 1 and my blu ray in hdmi 2. when i first turn on my tv and blu ray it works fine but if i switch to cable the back to blu ray it says no...
First, HDMI is not a perfect hook-up solution. Cable box connections via HDMI are notorious for being problematic. The best thing you can do is contact Samsung and get the latest firmware for your TV.
Samsung Customer Care: 1-800-Samsung (1-800-726-7864). If this does not resolve the issue, connect the cable box using Component cables instead of the HDMI. Component cables are HD also. I hope this was of some assistance.
Apr 07, 2010 | Samsung LN55B640 LCD TV
HDMI - no output Samsung P1600 BD
the hdmi output generally needs activating through the menu system. im assuming you havent already done this.
connect it with whatever cable works and navigate through to the menu system to select the hdmi output.
failing that it might be the hdmi cable is an older cable not capable of supporting ver1.3
Feb 07, 2010 | Samsung BD-P1600 Blu-ray Disc Player
No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
May 26, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Display not working
how down the power button until it beeps twice. that will restart your settings for the display. once it beeps twice then turn the system on and change the default settings back to your hdmi settings. what happened was when you transferred the ps3 to composite the settings changed to accomodate that but when you switch back to hdmi it doesnt change back. the only solution is to hold down the power button untill it beeps twice. normaly 3 seconds.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
43 people viewed this question
Jerry Greenberg
Jerry Greenberg
