Question about Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
I have a single DS603H dishwasher. When I press start it just beeps a couple of times. Nothing happens, it does not start or anything.
  • 490 Answers
This means the machine still thinks the draw is open so ofcoarse will not start, the sensor that detects the draw being shut is on the left hand side of the unit when u pull the draw out u will see 2 little clear squares on the side up the top near the control panel make sure they are clean aswell as the recieving end on the cabinet is clean as they r simple infrared sensors so if the beam of light is obstructed it wont think it is shut as the beam of light comes out of the control board and bounces off a light refracting prism and then sends it back to the board so if the beam cant return it wont start if they are all clean then you r looking at replacing the main control board as the sensor is contained within it
Posted on Oct 21, 2011
How can I restart my dishwasher
Press and hold the start button for a few seconds. The dishwasher will drain and reset
Aug 30, 2016 | Bosch Dishwashers
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
I did everything except this time now it says "
Try a Restore
PS3 Recovery Menu
  1. Place the PS3 in standby mode
  2. Press and hold the power button for a couple of seconds, you should hear a beep
  3. Keep a hold of the power button for a couple more seconds, the PS3 should shut back down to standby mode
  4. Once this happens, press and hold the power button again for a couple of seconds, waiting for 1 single beep.
  5. Ignore this beep and keep it pressed until you hear 2 consecutive beeps, release the button.
Try restoring the file system (Option 3), then repeat with rebuilding the database (Option 4).
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
Won't turn on
Try just pressing the selection pad, without pressing start/cancel and close the door. That has worked for me a couple of times.
May 05, 2010 | Frigidaire Professional Series 24 in....
Why does it continously beep? Why is it starting up by itself? Even after turning off? When you open the door it shows a light on rinse, when it was set on normal.
Not sure if your dishwasher problem has been fixed yet.
The continous beep and the rinse light on means the flood switch in your single drawer built in dishwasher has come on.
There is water leak inside the housing under the drawer. Turn the power off at the mains breaker and pull the drawer out as much as possible. Get a few towels and dry out the bottom of the dishwasher under the drawer. Use hair dryer if well.
Turn the power back on and see if the problem disappears. Sometime too much foam in detergent can also cause it but mostly it can be due to drain hose been kinked or gasket leaking.
Post a comment to let me know what you find.
May 02, 2010 | Fisher and Paykel 24 in. DS603H I Built-In...
My Trionr XL dishwasher will not run. I push the
It sounds like your dishwasher might be locked. You unlock the dishwasher by pressing the "heated dry" button for three secs. and then releasing it, that should do it.
Jul 04, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
F1 showing on screen, however we don't have a manual and can't seem to stop it
You should be able to find a user manual here: http://www.fisherpaykel.co.uk/admin/pdfs/pdf_usecares/527974A_FP_DD_ugm_GBw.pdf. F1 is a flood warning. You might want to have a little poke around the bottom of the cabinet and see if there's anything that might have upset the flood switch. A.
Mar 03, 2007 | Fisher and Paykel 24 in. DS603H I Built-In...
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Logo
140 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
