If the tv remote is the original TV remote, it won't control the converter box (if this is an digital-to-analog converter). If it is another remote, then maybe. It depends on the remote and when it was programmed.
Most remotes are limited to codes for devices released at least 6 months before the remote was programmed. Thus is your TV remote was programmed in late 2006, then it may have the right code. Some universal remotes support the converter boxes; others don't. If you provide additional information on the remote, I may be able to give you more specific details for your situation.
I hope this helps.
Cindy Wells (any tv that requires a d-t-a converter box was built before any plans were finalized for the converter box.)
Allow me to try and assist you based on your situation.
Most FREE channels went digital, more and more will disappear from the RF spectrum as digital moves into play. This tv is by far not digital thus it uses RF "radio frequency" that is transmitted from a tower to your rabbit ears then converted into the tv to make a picture and sound.
Here is a suggestion that you may consider, will not break the budget. Radio Shack carries a digital set top box that hooks to a antenna thus down converts the digital to analog for you so you can enjoy far more then 6 channels without having to pay the cable man or satellite tv company for your local stations.
Here is a link to the box I am talking about http://www.radioshack.com/product/index.jsp?productId=3150939
This box will help you get those channels back, will get you watching more TV.
Now for the remote issue, This box comes with a programable remote that will work for your tv so it kills 2 birds with one stone. You could also order one from remotes.com or 1800-remotes if you like.
We do hope this information does help you with your problems.
Thanks for using Fixya.com
