Question about Datalogic Touch 65 Light barcode scanner 901151422 Handheld Barcode Scanner
Trying to use datalogic touch65 pro with quickpos. Will scan a barcode, then it will come up with an error the next time you scan an item. Once the error is cleared it scans again for 1 item, and then just keeps repeating the cycle. Also it will not read in wordpad.
Noggin
  • 944 Answers
SOURCE: Datalogic Heron D130 (Barcode Reader) Header setup
Whether or not you can set this feature depends on which interface type you are using if you are using wedge interface then the procedure is described below: The extended Header/Terminator keys for Wedge Interface users can be customized by defining them through a simple keyboard setting procedure. For example, the Numeric Keypad keys can be set for use as Headers or Terminators by substituting the default extended keys using this procedure. The type of computer or terminal must be selected before activating the keyboard setting command. Press and release a key to set it. Some characters may require more than one key pressed simultaneously during normal use (refer to the manual of your PC or terminal for keyboard use). The exact sequence must be indicated to the reader in this case pressing and releasing the different keys. Example: If one has to press the "Shift" and "4" keys simultaneously on the keyboard to transmit the character "$" to the video, to set the "$", press and release "Shift" then press and release "4". Each pressed and released key must generate an acoustic signal on the reader, otherwise repress the key. Never press more than one key at the same time, even if this corresponds to the normal use of your keyboard. Press "Backspace" to correct a wrong key entry. In this case the reader emits 2 beeps. Note: "CAPS LOCK" and "NUM LOCK" must be off before starting the keyboard setting procedure. "SHIFT" must be repressed for each character and cannot be substituted by "CAPS LOCK". Check page 31-33 of the "heron reference manual", downloadable near the bottom of this link page; http://www.datalogic.com/_vti_g2_dwnlDett.aspx?idCF=1&idC=44&rpstry=13_ Hope this helps :)
Posted on Mar 22, 2007
  • 279 Answers
SOURCE: Scanner isn't scanning all the time
It doesn't sound like a power issue. Most likely it either needs cleaned, or it needs the laser recalibrated or replaced. Try cleaning the glass for starters, and then hold the scanner about two inches from a white piece of paper. You should get a solid, bright red line. If the line is distorted you need to recalibrate the laser. If it's dim, the laser unit is going out. The laser can be replaced, but I don't know if it's one of those things where the part plus labor costs more than replacing the scanner.
Posted on Aug 28, 2007
SOURCE: Enter function
Hi Lee,
It can be done by programming the scanning the 'Send Enter Key' barcode twice, from the owners manual.
eg
Scan the barcodes -
Send All Data, Send Enter Key, Send Enter Key, Save
Posted on Oct 17, 2007
rdiodoro
  • 13 Answers
SOURCE: problem with datalogic magellan 1000i barcode reader
hi
the cable is USB?
if you have usb cable, you read the manual paper "default".
if you have cable rs232 you must install on a PC emulator "softwedge". Open icons and set a comm. Prefer you answer. bye Roberto
Posted on Dec 17, 2008
  • 58 Answers
SOURCE: PSC 6000 Plus not scanning
There are a few questions:
What kind of cable do you use?
USB, SERIAL, PS2
What kind of computer?
Normal computer or Laptop?
Then...
When you recieve the scanner like new you always have to program it.
First you do
Reset to factory defaults.... Never do this with working scanners
then
you have to program it.
First the Connection type
and then if needed a computer type.
After that you usually have to scan a suffix.
This means when you scan a barcode it needs to do something after.
normally it doesn't give Enter after you scan.
That is what the suffix is for.
and then you scan additional symbologies to scan
Like Code 39, UPC A etc. etc.
It needs to be programmed with the manual you recieved.
if you don't have it you can download here.
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
go down in the list to quickscan 6000
and programming manual.
please don't print all the pages. only what you need.
If you need more help i will hear it.
good luck.
Posted on Jan 09, 2009
How can read 2d barcode?
go to: www.scanning.datalogic.com/sitefiles/mg1000i.aspx
or
www.barcodesinc.com/cats/barcode-scanners/hands-free.htm
Feb 24, 2011 | Datalogic Magellan 1000i Hands Free...
When scanning green light goes on beeps and nothing else happens.
Here's a link to the page where you can download all the manuals, software, etc for that unit. You might need to cut and paste it into your browser's address bar. Godd luck!
http://www.scanning.datalogic.com/sitefiles/gryphonlgd4300.aspx
May 20, 2010 | Datalogic Gryphon L GD4300 Barcode Scanner...
Datalogic QS6500BT barcode scanner and 2D codes
Usually some symbologies are disabled at default.
i think you need the manual and scan the barcode to enable it for scanning.
the links is:
https://easeofaccess.scanning.datalogic.com/public/marketlit/Send.aspx?file=R44-2816A
it's chapter 6-191 or page 279 in pdf.
you have to begin with scanning "Start" en end with scanning "END"
becarefull with printing this page and not the whole manual. there are 336 pages.
good luck
Jan 16, 2009 | Datalogic QS6500BT Barcode Scanner -...
Problems with very small Barcodes
Default settings set a global limit of 4.
You can set the global minimum code length by following the instructions in the user manual on page 24:
1) Start
2) Set Global Min Length
3) Scan the number on page 303: I.e. '0' followed by '3' to set length to 3
4) Set
5) End
Jan 09, 2009 | Datalogic PSC QuickScan QS6500 Handheld...
Beeps instead of reading the barcode
Hi Richiet Seems liek it has not been detected into the system or has gone faulty. I would first wonder is ot a new item ? If so try reinstanning it on the system you are using, If it was an older item do the same but maybe look atthe fact that it could be faulty in both instances. YOu always have a warrenty with manufacture and by law they will have to give you full technical support on the item
Mar 07, 2007 | Datalogic D100 Handheld
Datalogic Touch 65 Light  barcode scanner 901151422 Handheld Barcode Scanner Logo
46 people viewed this question
Top Datalogic Computers & Internet Experts
Paul Bade
jackcity
jackcity
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
