Question about Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Problem
My desktop is connected via LAN and is working properly but wireless doesn't. It's connected, I can acces to web based configuration but not web bages.
This appears only when i'm using my desktop. Otherwise wireless laptop can acces web (pages) normally.
My modem and router were working well, and then my router has stopped working
Posted on Sep 02, 2008
Key phrase
First, go to this site - 660HW Series ZyXEL - and download a manual for the ZyXEL P660HW-D1.
Quick start guide
Download Library
Next, hook up the router to your computer with a LAN cable. Open a browser and enter 192.168.1.1 into the url address window. The default login is 1234. Then configure the wireless settings - see pages 6 & 7 of the guide.
Feb 20, 2014 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router. Which settings need to be changed to turn it into a repeater and connect with my main broadband router.
Can't use a router as a repeater in a wireless sense. You could set it to AP mode and run an ethernet cable from a lan port on your other router to the WAN/uplink port on the Zyxel. If it doesn't have AP mode then you could have it in gateway mode run have a different subnet on the Zyxel with DHCP.
Oct 29, 2011 | Zyxel P660HW-D1 Router
My Zyxel P-600 series modem is connected to my desk top. Can i get a wireless connection to my laptop?
Yes you should! Download a manual for your router and read how you start the wireless LAN. I think you login to your router by writing 192.168.1.1 in the URL window in a web browser. Password is 1234 as default. Be sure to encrypt the AP with WPA so that your neighbours dont use your internet conection.
Aug 25, 2010 | Zyxel P660HW-D1 Router
Have a laptop connecting physically to zyxel p660hw and want to connect a new laptop wirelessly! its asking for a security key, is this the wireless key on the front of the router? if so it doesnt work!...
There's nothing wrong you just need to know this.
Default IP address: 192.168.1.1 Default admin username: <blank> Default admin password: 1234 Administration: Web-based (LAN)
Remote configuration (WAN)
Telnet / CLI
Windows application
If you need to know anything further you are most welcome to comment back. Since you are able to connect physically thats why I'm not providing much in details as you seem to be network specialist.
May 15, 2010 | Zyxel P660HW-D1 Router
Ethernet to router connectivity issue
The correct way to do the connection is by plugging the Desktop to one of the Ethernet ports and any wireless device over the wireless network.
Dec 01, 2009 | Zyxel P660HW-D1 Router
No connection via Ethernet between Zyxel P-660HW-D1 and PC
Hi Friend,
Before Connecting your internet we must check in ur system.
1.Go to Start---->Run------>type cmd----->in the black screen type ping 127.0.0.1
2.check wither its getting reply or request
3.If u are getting reply then ur system is perfect i.e., your NIC Card is installed properly.
4.check wither any proxy is enabled in the LAN settings.
go to browser--->tools---->internet options(Options)----->Connection--->Lan Setting--->there should noy be any tick mark in the boxes
Now we can check the connectivity,
1.Connect the PC from the Router Lan Port and the modem connectivity to the Wan Port of the Router.
2.Assign the Ip address as obtain ip address automatically
Right click networkplaces--->properties--->Lan Connection Properties---->double click the internet protocol(Tcp/IP).In the next box u must select the Obtain Ip address automatically
3.Now u switch on the modem after 30 sec switch on the Router.
4. Launch your web browser.
5 Type "192.168.1.1" as the URL.
6For administrator access enter the default admin password 1234 to configure the wizards
and the advanced features.
7 Click Login to proceed to a screen asking you to change your password or click Cancel
to revert to the default password.
8 If you entered the admin password, it is highly recommended you change the default
admin password! Enter a new password between 1 and 30 characters, retype it to
9.Then u can configure the ip address
Regards,
Ayyasam
May 29, 2009 | Zyxel P660HW-D1 Router
Router cannot connect to belkin g usb adapter it worked fine yesterday and today nothing!
Make sure to install the USB adapter's driver and utility. If it's installed, you need to use the Belkin WLAN Utility to connect to the wireless network. You should be able to find the signla coming the router and you can connect to it
May 07, 2009 | Zyxel P660HW-D1 Router
P660HW-D1 Router not working wireless
Problem with the Zyxel P-660?   I experienced:
1. laptop would see the wireless 660HW briefly and then it would disappear.   2. laptop would not see wireless at all. 3.  same issue with desktop when using USB wireless 11g dongle 4. no problem on wired connection (ethernet)
EASY solution!   if Zyxel is set to scan for a channel it will want to work on channel 13 nearly every time in a busy environment.
HP laptops and many receivers cannot recieve on 13 -  highest channel is 12.
Pick on setting for the Zyxel which matches an available channel on your receiver.  Problem solved.
Nov 20, 2008 | Zyxel P660HW-D1 Router
Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Jan 01, 2008 | Zyxel P660HW-D1 Router
Zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Nov 22, 2007 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Logo
456 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
