Question about Hotpoint Aquarius WMA42 Front Load Washer
Hi. I used my washing machine with the transit bolts still in place as there were no obvious instructions saying to remove them. I stopped it after at most 2-3 minutes though. WIll it be damaged or will it be ok? Thanks.
    President:
  • 842 Answers
The transit bolts are there to stop the drum banging about and denting the chasis when it's being transported. Provided that you haven't run it through a rough spin cycle then the chances are that there is no damage whatsoever. You're not the first or last person to do this. Don't panic, it will be fine :-)
Posted on May 27, 2011
We have just purchased a brand new w6444 and when on spin it moves all over the place and is very loud
sounds like you have not removed the transit bolts at rear of machine. get your instruction manual and carefully read instalation instructions.
Mar 17, 2011 | Asko Washing Machines
I have just purchased a candy washing machine. After removing the transit bolts etc it says to fit the corrugated insulation sheet but there isn't one. Am I overlooking something obvious?
The corrugate sheet is with the packaging It looks like a piece of black cardboard. It is not essential The purpose is to assist with sound reduction. Check the packaging and fit the sheet to the bottom if you are concerned.
Feb 15, 2011 | Washing Machines
Brand new washing machine - have only used once and it moves and jumps around ALOT !!! Is there something I need to remove from the machine before I use it.
If you have not already done so, then you must remove the transit bolts located at the rear of the washer.
There is usually 2 or 4, and they are clearly visible, it should tell you in your user instructions.
Dec 18, 2010 | Bosch Classixx WFL 2066 Front Load Washer
New Simpson Top loader washer very noisy/rocking
sounds like you havent undone the transit bolts- theyre on the back of the machine, 2,3 4 maybe five quite large obvious bolts, around the drum but on the back. they are to keep the drum steady while in transit to stop the machine bouncing around in the van - you are unlikely to have damaged it - Undo these bolts - they should be mentioned in the manual-
Jan 20, 2010 | Washing Machines
I left the transit bolts in our "brand new" zanussi washing machine and am afraid to use it as I do not know what damage might have been done.
Highly unlikely any damage will have been done so long as it hasnt been in use for a long time (weeks).
In a front loading washing machine, most of the mechanicals inside are held between springs at the top and dampers at the bottom. The transit bolts are used to minimse how much movement can ocour whilst the machine is in transit as excessive movement could damage the springs/dampers. When they are removed, normal movement of the mechanicals helps keep the machine stable and minmises vibration.
So, the worst that happens when the machine is used with the transit bolts in place is it vibrates alot, and possible moves about.
Remove the bolts as soon as possible and it should be fine.
Oct 04, 2009 | Zanussi ZWF12070 Front Load Washer
Forgot to remove shippping bolts before using machine.
I would take out the shipping bolts and then run a prgram such as Spin.with no clothes in
If that sounds ok, wet a few towels and spin them dry
If that works put a full load in and go for it
Unless your machine was way out of balance you should not really have damaged anything.
The transit bolts are there to stop the drum from banging around during transit and unless they have torn free or have bent you should be ok
Jul 11, 2009 | Amana Washing Machines
AEG OKO LAVAMAT - BROKEN BOLT - WHAT DOES IT DO?
The bolt you described is indeed a transit bolt and should be removed. I believe that the current UK agents for aeg are service force. Check their website for your nearest branch.
Hope this helps & thanks for using Fixya
Dec 23, 2008 | Washing Machines
Transit brackets
Hiya .. the transit bolts are located under the lid at either side ..or at the rear... they are fairly long bolts which hold the drum and balance in place.. until installation. they will be sheathed in fairly hefty rubber grommets.
Screws for removal of lid located at the rear..2- or 4.. remove these slide lid front to back.. remove bolts if they are they are present... refit lid... note uneven siting of an appliance can cause excessive vibration as well!
Let me know if this sorts your prob
Regards Faggly
Mar 20, 2008 | Washing Machines
Hotpoint Aquarius WMA42 Front Load Washer Logo
231 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
