SOURCE: Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
SOURCE: Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
SOURCE: De Dietrich oven not working!
I suspect that it is the oven lock that needs replacing. I bought a De Deitrich oven (pyroclean) in Sept 2007. The oven failed to heat in Aug 2009. The oven lock needed replacing which meant the unit had to be removed from the wall. It was replaced under guarantee but failed again in June 2010 and was replaced at a cost of €140 by enginneer. I am very dissappoined in the oven and expected to have no problems with it considering the DeDeitrich name. I would not recommend it to a friend. By the way the clock is easy to use if you follow the instructions exactly. Oven used by two careful owners only.
SOURCE: my cooker won't heat up
remove the rear panel covering the fan (4 screws) from inside oven. The element is round the fan. you may see where the element has burnt through or split or distorted the element.
SOURCE: I have a Belling 652BL
ISOLATE MAINS POWER BEFORE OPENING SIDE AND REAR PANELS.
The grill and top oven have as discribed in the manual a temp regulator it is mounted on the side or rear chassis, this is probabily blown, they are normaly connected, when the devise goes faulty it stays open circuit, there are letters and numbers on this, take a note of them if you can read it. go to a local electrical store with the component, you should get a replacement, if however you have a multimeter, measure across the terminals with the meter on resistance, if no continuity, or contiunity to the case, the component is faulty. If however the component checks out working go to timers and remove the time on the auto timer for the top oven, visualy check the elements if the element have Black Grey spot, replace as it has blown, you can get spares at relativly low price you will need model and serial number of the appliance, from whitegoods.co.uk
hope this has been helpful
johnf1
Testimonial: "Had a chance to investigate yesterday, and it does indeed appear to be the temperature regulator at the rear of the cooker which is faulty. Thanks fo"
