Question about Bosch 24 in. SGE09A25 Built-in Dishwasher
My Bosch SGV43A13EU is not draining properly. The filters are clean. Any ideas about what to do? Thanks.
3 Suggested Answers
daddy1264
  • 76 Answers
SOURCE: Not Sanitizing or heating and draining properly
bosch dishwashers run the cycle through the heating element, you may get a 2H displayed. when you wee that it means the heating element is bad, or the board is bad, i will tell you in my 15 years of repair its almost always the board,. if you know someone who is solder literate, the you can remove the board and resolder the connection. you need to remove the screws on the inside top of the door to remove the display panel, after doing so you will see the control board(fisrt turn off the electrical) then remove the wiring harnesses from the control board, the harneses only go in a certain slot so they will be easy to remember where to put back into.open the case of the board, look on the back and you will see where the bad solder joint id...clean, resolder, reinstall......good luck
Posted on Jan 08, 2009
ginko
  • 19396 Answers
SOURCE: Bosch shv56c03uc/114 Water is not draining
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Posted on May 21, 2009
Bosch dishwasher stopped working after few minutes. And LED displayed E:24. What is the problem?
Fault Code E24
Symptom: Dishwasher not draining properly.
Cause: Drain filters blocked.
Action: Clean the filters.
Go to:Why is My Bosch Dishwasher Not Draining?
For more detailed codes see ...
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Sep 05, 2016 | Bosch Dishwashers
Bosch exxcel maxx freedom washer dryer filter will not open
You will need to keep working it. It will open.
Nov 02, 2012 | Washing Machines
Bosch wwf1201 won't drain.
Probably a blocked filter that needs cleaning.
You should find this located at the bottom front right of washer behind drop down flap/cover.
Unscrew anti-clockwise to remove and clean.
Mar 30, 2010 | Bosch Washing Machines
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch washer wont drain wvf 2401
You need to locate and clean the pump filter, usually found at the bottom right front of washer, sometimes behind a removeable plastic cover at the bottom.
Please rate my solution.
Thanks.
Nov 20, 2009 | Bosch Washing Machines
Doesnt spin on spincylce and just makes a rattling noisewff1475 bosch
The rattling noise is probably something in the pump.
If it is not draining properly, this will stop it spinning.
Check pump filter, if clean, then I would suggest you check the brushes in the motor for wear, as badly worn brushes will also stop it spinning.
Thanks.
Nov 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFF1201 Washing Machine, wont drain
To access the pump filter, remove lower plastic panel at front of washer, there you will see the filter, unscrew filter cover anti clockwise, remove and clean filter.
You will probably find that whatever was causing the clicking noise is something in the filter.
If you can't see anything in it , then have a look inside the pump housing before you replace filter.
Plz rate my solution .
Thanks.
Jan 26, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
I have a BOSCH 8280 dishwasher which at the end of its cycle still has soapy water in the bottom of the machine. The dishes, and especially the cutlery, are left smeared and looking unfinished. I lifted...
There is a float, which controls water level, that caused this draining problem.
Lift out the main filter assembly in the floor of the dishwasher.
You can now see a small cover, positioned at the front right of the area normally covered by the filter assembly.
Click this small cover off. You should now be able to push the small float out (upwards) with your finger.
Clean the float, removing any scale or other gunge which is on it,
Refit (reverse of the remove instructions) and all should now be functioning correctly.
Apr 23, 2008 | Bosch Dishwashers
Open Questions:
Bosch 24 in. SGE09A25 Built-in Dishwasher Logo
130 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
