Acoustic Solutions 32in LCD32761HDF TV Headphone socket entry in the audio menu not hightlighted so cannot use my headphones!! Also aspect ratio settings in HD channels are not right. i.e. 720 on the V box leaves black lines on the tv display and 1080 wide makes objects look too tall! What are the settings for Virgin V Box (HDMI) and your TV? andd how do I change them in the picture menu? Carole
legna
  • 53 Answers
SOURCE: NO TV PICTURE
The best way is to contact your service provider and ask them to trouble shoot guide you, there should be a way to reset or diagnose the receiver or if you prefer go back to the place you bought it and ask for a replacement, You should still have the manufacturer's warranty, check that as well.
Posted on Dec 14, 2007
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
Nickstar19
  • 417 Answers
SOURCE: 720 and 1080 resolution
depend if your TV dos 720 & 1080 ill look into this more for ill get back 2 u soon
Posted on Aug 16, 2008
  • 46 Answers
SOURCE: No HDMI input socket on Toshiba 'HD Ready' TV
There is an easy way to adapt the cable.
Any good computer shop will have the adaptor.
Take the HDMI cable to them, and tell them you want an adaptor to go to composite signal.
(I know that they're made, many of the graphics cards I use to build computers come with that cable adaptor)
You also might try Best Buy or Radio Shack, but you might not have much luck with them.
Posted on Jan 16, 2009
maatmartin7
  • 1213 Answers
SOURCE: CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Posted on Aug 12, 2009
I have a 37” Acoustic solutions tv mode LCD3761F1080P . the language is not English when I go onto menu to change colour , brightness picture etc.. How do I change it back to English, I can’t find the...
The manual for your TV can be found here: https://www.manualslib.com/download/619005/Acoustic-Solutions-Lcd32761hdf.html
Page 30 talks about Navigating the Analogue TV
Menu System and Page 33 leading through that section has information on language selection.
Hopefully you will be able to follow the manual and button presses to find the setting you need.
Jan 20, 2018 | Televison & Video
How do i connect my nexus 7 2nd generation to my acoustic solutions tv model LCD32761HDF, I want to watch filmon on a large screen?
Hi, Your Nexus has RCA connections on the back and so does the TV. You only need the audio connections to work. Another way to go is HDMI cable. Your TV may already have them. Good luck.
May 01, 2014 | LG Televison & Video
No sound on my technika 42" 3dtv
If the headphone jack socket works the audio output for the set is good, I suspect a dvd etc will also work if connected to the rear input audio and video jacks.
This does not leave too much, headphone jack dirty or defective, speakers for whatever reason are switched to off in the main menu.
the sound for the headphone socket if it is built into the set is the same audio going to the speakers.
Dec 05, 2012 | Televison & Video
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Jun 10, 2011 | Acoustic Research AW-772 Headphones
How do i access hdmi 2 on my lcd32761hdf tv. i have cable (virgin) in hdmi1, dvd in ext 1 & the wii in ext 2. i now have a ps3 i would like to set up.
You can't access it simply because it doesn't exist - your tv has only one HDMI jack.
Your only option is to use a HDMI switch, one like
http://www.amazon.com/HM-501-5-PORT-HDMI-control-cable/dp/B000FHQMFK
Jun 05, 2010 | Acoustic Solutions M 100 Main / Stereo...
Need headphone solution for Panasonic c12lcd tv
I have a Panasonic viera 32in lcd hd tv. I'm trying to hook up headphones but there's is no apparent audio output jacks. But there's is only one digtal output jack! is this the jack ? and if it is, what cables do I need to make the headphones work? or am I forced into by an amplifier
Sep 30, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
How to connect headphones without a headphone socket
if there is differentiation between the sockets you will need the manual..
Mar 09, 2009 | Insignia 37" LCD Flat-Panel HDTV
Unable to connect headphones to Tv.
You TV have no headphone port.
You can download the user guide for your reference from:
https://docs.sony.com/release/KDF55WF655.pdf
Apr 24, 2017 | Sennheiser RS130 Headset
Tv sound
The headphones work fine, but the sound on the tv won't turn off. Any solutions to this problem. I have a SonyWEGA tv.
Jan 26, 2008 | Sony MDR-RF970RK Headphones
Acoustic research aw722
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
Dec 29, 2007 | Acoustic Research AW-721 Consumer...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
