How do i fix this
You already gave me a solution for the problem with ntldr missing and you suggested i have to fix something but how do i do this i dont have any disks
  • 1,800 Answers
If ur system not boot till windows desktop
am sorry to tell u that u just have to start a new windows installation!!
rate me fix u!!
Posted on Aug 16, 2008
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
Windows 7 with Gigabyte motherboard says "ntldr is missing"
Check if UEFI is disabled after flash with newer BIOS version. If you flash BIOS the default settings gets loaded again. Check hard disk settings and boot settings.
Mar 03, 2013 | Gigabyte Computers & Internet
17HEWLET-PACKARD NTLDR IS MISSING
See the following web site for help on fixing this problem or alternatively, download a copy of Hiren's Boot CD and burn this CD image file (ISO) to a blank CD, then boot your computer from the CD and take the option on the boot menu to Fix NTLDR is Missing.
Jan 12, 2012 | Compaq Computers & Internet
Hi, i have a thinkpad 600e with corrupted os (missing ntldr for sp2). i tried repairing with cd but cd wont boot (cd is bootable though). it keeps restarting. my boot sequence is already set to cd first....
Try to reinstall only the service pack.
What OS are you using?
visit Microsoft's downloads center and download service pack 2 for your OS i.e, Windows XP or Windows 7, then reinstall.
That should fix the problem
Thank you for using Fixya,
Kenneth
Jul 26, 2011 | IBM Computers & Internet
Acer aspire one error in oxf0000005 / NTLDR is missing
That is a windows error. You can try booting off the original installation CD and choose option for fix current installation, but chances are 50.50 if it will work or not. NTLDR is the bootmanager for Windows NT based systems (Windows NT, 2000, XP, etc). Critical system file, typically protected against altering.
The error code you gave is usually associated with windows having issues seeing / using a SATA drive. You will likely have to find the driver for our particular SATA controller, and load it when prompted as you startup off the recovery disk.
Jun 22, 2010 | Acer Aspire 5102WLMi Notebook
I tried d2d recovery but it said the ntldr is missing hit any key to cont. but nothing is happening
i suggest u do a fresh windows installation already... for i believe ur system is not working anymore... use a bootable windows to fix that problem...
Nov 19, 2009 | Acer Aspire 5610-4648 Notebook
CANT BOOT FOR REINSTALLATION OF XP, IT SEZ "NTLDR" IS MISSING, ALSO MENTIONS SOMETHING ABOUT THE HARD DRIVE NOT WORKING
If you have the OS disks try a repair first. Run the OS disk and choose the repair option rather than reformatting. That usually fixes ntldr issues.
Apr 30, 2009 | Computers & Internet
Ntldr is missing
Hi 30jspecial, well you already tried one of the ways to fix NTLDR.
The better way is for you to click this link I have posted & follow these instructions. Please leave the bios alone.
http://tinyempire.com/notes/ntldrismissing.htm
(I have used this at least a dozen times my self).
Good Luck & Kind Regards.
If I can be of more service, just ask.
Mike
Apr 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Ntldr
First check your bios & make sure it see's your hard drive & it's setup correctly. If it is there could can be other reasons for the missing NTLDR.
Suggest you take you Windows CD and boot to it. If your CD does not boot. Re-start the PC & start pressing the F8 key every two seconds. This will bring up a boot menue. Choose your cdrom drive.
Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy these two files to you Hd. copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Replace the drive letter listed above for your cdrom's drive letter.
Once copy has been complete re-boot your Pc.
If you still get missing NTLDR. Do a complete reinstall of windows. Your personal data should stay intact.
Please post back if this has not fixed missing NTLDR, there are more fix's that can be applied. I only listed the most common.
Feb 12, 2008 | AOpen Motherboards: AX4SG-UN (AAX4SGUN)
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
