Question about MSI PM8M-V Motherboard
SATA's compatibility , motherboard update?
My 320GB SATA's not working on the motherboard , how do i make it work?
I heard that i need a motherboard update , where and how do i get it ?
If i got the update , how can i install it ?
I've checked the SATA with the shopkeepers and it's working fine , however even with the harddisk connected , it doesn't detect it . They've already partitioned the harddisk so it works on theirs . When connected to mine , the MB does not detect but the harddisk is spinning and it produces heat . Pls help , i really want to make that 320gb worth
    President:
  • 2,351 Answers
Hi k439,
Keep in mind that all serial ATA SATA hard disk drives are seen in the main bios menu as a Primary Master drive. When you load the bios you should see the SATA 320GB drive in the main menu, Standard CMOS Features. If you do not than the onboard SATA controller is defective. This can not be repaired. Only a motherboard replacement will fix this issue. You can go to MSI's web site below & allow MSI to check you're system for the latest bios upgrade. Follow their online instructions & update you're bios file but this will not fix you're onboard SATA controller. Click this link to MSI Live Update link: http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=1&prod_no=205
Sorry k439
Mike
Posted on Aug 16, 2008
HD322HJ, 320GB, 7200RPM/16M SATA Hard Drive is not detecting in Bios My system configuration is quad-core 9650 processor, 9400gt nvidia graphics card, 2gb ram kingstone,M2N68AM+ motherboard pls give me...
Did you try to connect it to another PC, different port in the same PC? Are all SATA ports enabled on the motherboard? It may be problem with fault motherboard, sata/power cables or the hard drive itself.
If it's a second drive for you can you try connecting it through USB bridge to see will it work that way.
Aug 20, 2013 | Samsung HD322HJ 320GB 7200RPM 3.5" SATA...
I am using K8S MX Motherboard with OS-Windows XP. but my hard disk is not working. i want to purchase a new 160gb IDE hard drive. please tell me if it supports 160gb hard drive or not
The specs for this motherboard say it has a Utra-DMA 133, and 2 SATA 3Gbs ports.
You can connect any IDE HD, and any SATA 3 or lower HD. These standards are backwards compatible. When it comes to size, there is a 2TB MBR limit.
I would skip IDE and go directly with a SATA 3 drive.
http://www.asus.com/Motherboards/AMD_Socket_754/K8SMX/#specifications
GL
Dec 11, 2012 | ASUS K8S-MX Motherboard
My laptop needs the driver of this hard drive.
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
hope this helps you
Aug 11, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
NOT DETECTING SOME TME,NOT SUPPORTNG FOR SOFTWARE WILL BE CURRUPT P/N 487731IS322881 MODEL :HD322HJ 320GB/7200/16M
Hi Igra,
If your motherboard is latest, go to BIOS or CMOS Set up and look for HDD properties and if you can find the Enhanced or Compatible mode..please change it to Compatible so your computer can detect the SATA Harddrive.
regards,
mastergani
Dec 04, 2010 | Samsung SpinPoint T166 320 GB SATA Hard...
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
Is a 320gb HD compatible with the Inspiron Dell laptop?
Hi, I think its compatible with Dell Inspiron as long as the 320GB uses the same cable like IDE or SATA with that dell inspiron, and I think if ever your machine right now uses on the IDE cable it can still handel a 320GB capacity because an IDE cable can accomodate up to 500GB size Harddrive. Also I would suggest that if this would work on your machine try partioning your 320GB to one 60GB for your operating system and the other space is for your data storage. Hope this helps
Jun 03, 2010 | Dell Inspiron 6000 Notebook
Bios not detecting 320gb sata drive
Double check the jumper configuration, You might also want to check the cables and ports incase that's the problem because a properly jumpered SATA drive shouldn't have any compatibility issues. Also check if *********** board supports the SATA ? Let me know if this works..thanks. Mike
Mar 04, 2010 | PC Chips M955G Motherboard
Does this have a SATA connection for a SATA HDD
I cant find specs or a good big pic so I can see it, the sata jacks are similar in appearance to usb potrs, on the Motherboard they are usually clumped together (If there's more than one), If it doesn't have them you can get a PCI card with SATA potrs and put that in.
May 11, 2009 | Matsonic MS8147C+ (N82E16813184008)...
775Dual-880 Pro cannot detect SATA HDD 320gb
if you bought this board brand new, take it back and tell them the sata controllers in the bois are not sufficent and get one that is. If you got it second hand then you will need to update or flash the bios to the latest version. see if that works and the drive is recognised. if it is recognised via flash/update you may still run into problems if you try to install XP
good luck and regards
Nov 22, 2008 | Asrock 775Dual-880 Pro Motherboard
SATA drive stops or hangs . . .
Hi fadetoal, it's not you or you're drives. It's the onboard SATA controller. When a board is SATA compatible & the bios does not see the SATA drive (List the SATA drive), the fault is the board. You're board goes one farther than normal. Bios see's the drive but can't run. All you're going to do is pull you're hair out trying to get the board stable. Hope its still in warranty.
RMA time: http://www.ecsusa.com/ECSWebSite/Support/rmamb.aspx?MenuID=25&LanID=9
Best of luck!
Mike
May 03, 2008 | EliteGroup NFORCE 570 SLIT-A Motherboard
MSI PM8M-V Motherboard Logo
192 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
