Question about Panasonic DMR-EZ17 DVD Recorder
Movie stuck in player. Won't reset or turn on. Six number 0s keep nothing on and off. I unplugged and tried everything. Now what? Thank you.
  • Panasonic Master
  • 467 Answers
000000 indicates a self-check display; in the manual it is mentioned as a recovery process. However, if this is taking longer than expected, and the unit is still inoperative, there is no other option (assuming you tried the reset procedures mentioned in your manual) but to submit the unit to an authorised Panasonic service centre for a quote and a second opinion, since this is clearly not going to work properly, and there is a disc or tape still in it. (Make sure if you do decide to go ahead with the repair quote, that when they service the unit, they retrieve the disc/tape, and ensure that you get that back when you pick up the fixed unit, and pay whatever repair costs are necessary) The cause is probably within the power supply, such as an IC regulator short-circuit and/or microprocessor malfunction on the main board, preventing normal startup operation.
All you can do at this stage is take the unit to a repair centre, get a quote, and go from there (trapped DVDs and/or tapes should be retrieved and returned to you - the technician can get those out without damage - don't attempt it yourself unless you know how).
Be warned: a workshop repair on this model could be expensive, but it is up to you.
Posted on May 27, 2011
3 cd's are stuck in player and the 5th changer won't open
Unplug it from the wall and give it time to power down. When you plug it back in it will reset itself and the changer will open. Pretty much the way a computer resets itself when you unlug it completely. Also works on my DVD player when it jams up
Sep 12, 2012 | Panasonic Audio Players & Recorders
Dvd won't play my dvd's. keep saying no disc or wrong disc. what is the problem
  • Hi, Sounds like the lens is just really dirty. Go buy a leans cleaner disk and run it through the DVD player two or three times to get the lens good and clean. Repeat about once a month to keep the lens clean and running properly. Sometimes you need to run it through 3 or 4 times to get the lens to read again.
  • These disks I speak of have little bristles on it that "sweep" the lens clean. I use them on all my disk players and they work real well.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 26, 2011 | Memorex MVD2016 DVD Player
I have a Toshiba BDX2100 Blu Ray player. I've owned it since October 2010. I've not had any problems with it until a couple of days ago. It won't turn off unless I unplug it, and it only opens...
Do you have the Blu Ray player plugged into a surge protector, sometimes surge protectors can cause odd feedback in certain electronics and cause them to be buggy. If this is the case, take it off the surge protector and plug it straight into the wall and see if that fixes the problem. If this isn't the case or doesn't solve the problem there could be a number of reasons this is happening, there could have been a surge that fried some internal components causing the player to not function correctly, or it could have just had a hardware malfunction. If this doesn't help I would recommend calling the manufacturer of the player to see if they can provide you with additional info
Jul 18, 2011 | Video Game Consoles & Games
I was wondering if you could give me some things to check on my van won't start and we tried jumping it. The lights all come on with full charge . So I was wanting to know if there is a reset button...
if u unplug your battery for acouple hours it will reset youre ecu/cpu. (everything) does it turn over? or absolutly nothing? if nothing sometimes ur battery loses so many electrolytes it can't retain a charge therefore jumping won't help. new battery first step! local junkyards probably have a good battery for $20. Let me know if this helps.
May 15, 2011 | 2009 Volkswagen Routan
I have a Badger 5 (5-81A). The motor is humming when it's turned on, however, the blade does not turn. The blade does seem to move freely. Tried reset and hex key but still nothing.
you have something stuck in it more than likely,, use the key ( unplug it first) and turn it backwards,, keep looking inside with a flashlight for the lodged object once you see it,, remove it,, sometimes the key won't work if its something caught in the blades themselves, so use the handle end of a broom or plunger with a wooden handle to push on the blade itself to turn the unit over
May 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Jensen VM9410 - Stopped Operating All Of A Sudden
Sound like to me you got a problem with the capcitor inside the unit, if its under warrenty it will need to be serviced. If its not I ould be checking capcitors inside to make sure there not bulging leaking or otherwisen ot wroking correctly.
Jun 24, 2009 | Jensen VM9410 Car DVD Player
CD Error on Stereo (Not a code issue)
I have seen this a bunch of times always with the same result, take it to a audio repair facility, the sterio has a bad internal circut. No external "quick fix" that i know of
Nov 11, 2008 | 2005 Honda Civic
Stuck in recovery mode and firmware problems
My Creative Zen mp3 player is stuck on Recovery mode , and keeps on saying filmware problem. I have tried to reset, push power button down and push play button at the same time. I also tried Clean-Up Format and reload filmware.
Nothing has worked, and I am about to throw it out the window.
Please if you can help me.
Thank You
Oct 15, 2008 | Toshiba Gigabeat S30 MP3 Player
Panasonic DMR-EZ17 DVD Recorder Logo
132 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
