How can I make the cartridge holder move so I can put a new cartridge in pls
    Sergeant:
  • 207 Answers
That depends on what brand and model your printer is. But i believe that you have an EPSON one. The first thing to do is open up the cover and turn on the printer the cartridge unit will start to move and if it goes at least near the middle simply unplug the printer's power plug. Now you can move the main cartridge the position where you can replace it's cartridges. Hope this helps.
Posted on May 27, 2011
    Novelist:
  • 111 Answers
Hello -- assuming your printer is connected into a PC via USB or some means - open up the software and find the Ink level supply option or replace cartridge option, this will move the printer head into the correct position.
If it's an Epson there is also a small lever that moves between sheets & envelopes , this also moves the printer head.
Last resort is to UN-PLUG while holding the top open , this moves the printer head -- hope that helps - Ray
How do i reset ink cartridge cl511for my canon ip2700
1. Make sure that the power is turned on.
2. Open the Front Cover.
The FINE Cartridge Holder moves to the replacement position.
3. Remove the empty FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape (C) gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be installed into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
6. Close the Front Cover.
Sep 20, 2011 | Canon Office Equipment & Supplies
Horizontal bands across image
plz check in the printing properties you are using the correct paper.
you can also try by printing in draft mode, if the problem is not solved then you can try by changing the paper.
If every thing fails then try by reloading the printer drivers and clean the cartridge contact point with the printer.
Still problem is not solved then try with another cartridge
Jul 03, 2008 | HP PSC 2355 All-In-One InkJet Printer
Cyan toner missing message. on magicolor 330
Firstly - remove and reseat the cartridge. If problem remains: Replace the cartridge with a new one. It is possible the new cart is faulty. If problem remains: Cart Sensor unit should be replaced as follows (If you need a copy of the service manual, contact http://www.TheServiceManualShop.com) Removal 1. Remove the Fuser Assembly (RRP 9.80). 2. Reach inside the empty Fuser cavity and slide the Cartridge Sensor Holder forward to unlatch the Holder from the printer frame (Figure 1). 3. Move the Holder around until the side latches on the Holder line up with the cutouts in the frame and the Holder is free of the frame. 4. Disconnect P/J 87 from the Cartridge Sensor. 5. Remove the screw securing the Cartridge Sensor to the Cartridge Sensor Holder and remove the Sensor (Figure 2). Replacement 1. Position the Cartridge Sensor onto the Sensor Holder so the LEDs face out. 2. Line up the position tab and screw hole on the Sensor with the two holes in the Holder. 3. Use one screw to secure the Cartridge Sensor to the Sensor Holder. 4. Reconnect P/J 87 to the Cartridge Sensor. 5. Position the Holder against the Holder cutout in the printer frame. 6. Move the Sensor wire harness so it exit through the cutout at the rear of the Holder. 7. Move the Holder around until the side latches on the Holder line up with the cutouts in the frame. 8. Push the Holder forward until the front latch secures the Holder to the frame. 9. Reinstall the Fuser Assembly (RRP 9.80). If the problem remains, then the MCU PWB will need replacing. This could put the machine Beyond Economical Repair.
Jun 12, 2007 | Minolta magicolor 330 EX Laser Printer
I have just installed a new BX3 Ink Cartridge in my CANON B640 FAXPHONE. I am getting an error message 'Put In Cartridge'. I am not able to receive faxes. I can however send them. Please help.
Remove the new cartridge and check that the holder has not broken. When the lever is moved it should squeeze the holder together. If this is all ok then clean the gold contacts in the holder with a damp cotton bud. If this all fails then its just possible the new cartridge is a bad one and needs exchanging for a good one.
Jul 20, 2011 | Canon FAXPHONE B640 Plain Paper Bubblejet
How do I get the cartridge out to replace with new one???
The steps of replacing cartridge with a new one.
1) First You keep the printer power on. Open the printer cover - you will find the cartridges holder will come in proper place (the position varies printer to printer) so that you can easily remove the old cartridge.
2) Press gently the upper front portion of the cartridge you want to remove out of the printer holder - you will find it will be unlocked - just remove the cartridge carefully. (in some printer there is a cover on top of the cartridge holder which you can open to perform the step 2.
3) Unpack the new cartridge.
4) Don't forget to remove the plastic tape from the cartridge head (Ex.in HP, Lexmark cartridges etc).
5) Look the printer holder and look to the cartridge - you can easily decide the position of the cartridge in the holder.
6) Gently and carefully  put the cartridge in the holder - press the upper portion of the cartridge from front side - the cartridge will be locked autometically in the holder.
7) Put the printer cover in proper place.
8) Print Now - it will print test page first. Now print as usual.
I hope the solution is helpful to you. Thanks for using fixya.com.
Jun 23, 2010 | Office Equipment & Supplies
Shows black ink empty after new cartridge inserted
Replacing the cartridge should resolve this problem: Follow these steps to replace the cartridge:
Installing / Replacing the BJ Cartridge Follow this procedure to replace the BJ cartridge:
1. Make sure the MultiPASS is plugged in.
2. Open the document tray.
3. Lift the document guides to open the ADF (Automatic Document Feeder).
If the ADF (Automatic Document Feeder) does not open easily, slide the document guides outward and then open the ADF (Automatic Document Feeder).
Or slide the Document Feed Lever to either the automatic or manual setting.
4. Pressthingtopress.gif. If installing the BJ Cartridge for the first time, skip to step 6.
Caution: Do not try to manually move or stop the cartridge holder since this may damage the unit. Do not touch the components shown or any metal parts since this may adversely affect operation of the unit and/or affect print quality.
The MultiPASS has an automatic protection feature that helps keep it from overheating. If the cartridge holder does not move, unplug the MultiPASS and let it cool for several minutes. Then plug it in again.
Press thingtopress.gifto move the cartridge holder.
5. Raise the blue cartridge lock lever on the cartridge holder and remove the BJ cartridge.
Caution: Discard the old BJ cartridge immediately according to the local laws and regulations for disposal of consumables.You may want to place it in a plastic bag to keep any residual ink from spilling. Spilled ink can stain any surface; protect yourself and your work area. If removing a BJ cartridge to use one of the optional BJ cartridges, be sure to store the BJ cartridge in the container provided with your MultiPASS. Otherwise the ink will dry and affect print quality.
container.gif 6. Remove the new BJ cartridge from its package, then remove the orange protective cap (1) and tape (2).
Caution: Discard the cap and tape. Never attempt to reattach them to the BJ cartridge print head. Install the BJ cartridge immediately after removing the cap and tape. Spilled ink can stain any surface; protect yourself and your work area.
7. With the label facing outward, insert the BJ cartridge into the cartridge holder. Lower the blue cartridge lock lever until it locks into position.
lockinpos.gif 8. Press thingtopress.gif.
The cartridge holder moves to its home position on the right side of the unit and begins cleaning the BJ cartridge print head. This process takes about 55 seconds.
9. Close the ADF (Automatic Document Feeder).
10. Close the document tray.
Note: If you need to unplug the MultiPASS, wait until the unit is in standby mode (date and receive mode displayed in the LCD). Otherwise the cartridge holder may not be in its home position causing the BJ cartridge to remain uncapped and dry out.
Apr 11, 2009 | Canon MultiPASS C530 InkJet Printer
Loading the ink cartridge
Please remember to rate other users who assist you for free :)
How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Ink cartrige placment
Make sure that the unit is powered on. Open the top and wait for the cartridge holder to move over to the left side. If it won't move, check to see if there is anything blocking it. Once the cartridge holder has moved over to the left, then put the cartridge in and lift up on the edge closest to you to lock it into place.
May 22, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Can't put cartridge into printer
If your replacing the fine cartridge follow these steps. Sorry for jumping in but it looks like your in a hurry. If you already solved it, great.
1 Make sure that the printer is on, and then open the Front Cover.
The FINE Cartridge Holder moves to the left.
i_expl.gif Caution
bullet_s.gif Do not hold the FINE Cartridge Holder to stop or move it.
bullet_s.gif Do not touch the metallic parts inside the printer.
i_important.gif Important
If the Front Cover is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. Close and reopen the Front Cover to return the holder to the left.
2 Remove the empty FINE Cartridge.
(1) Push down the FINE Cartridge.
bullet_s.gif Handle FINE Cartridges carefully to avoid staining your clothes or surrounding work area.
bullet_s.gif Discard empty FINE Cartridges according to the local laws and regulations regarding disposal of consumables.
3 Prepare the replacement cartridge.
(1) Unpack a new FINE Cartridge and remove the orange protective tape (A) gently.
*1 To the FINE Cartridge Holder
bullet_s.gif Do not re-attach the protective tape once you have removed it. Discard it according to the local laws and regulations regarding disposal of consumables.
bullet_s.gif Once the protective tape is removed, do not touch the electrical contacts or Print Head Nozzles on a FINE Cartridge. The printer may not print out properly if you touch it.
bullet_s.gif Be careful not to stain your clothes and hands with ink on the removed protective tape.
4 Install the FINE Cartridge.
(1) Insert a new FINE Cartridge all the way into the appropriate slot.
The Black FINE Cartridge should be installed into the left slot (ug_maintenance37.jpg) and the Color FINE Cartridge should be into the right slot (ug_maintenance38.jpg).
(2) Push up the FINE Cartridge until it clicks into place.
The printer cannot be used unless both the FINE Cartridges are installed.
5 Close the Front Cover.
Hope this does it. I'll check on you later. If this fixes you up just rate it a 4 fix ya and I'll know you're ok.
Mar 26, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cannot remove ink cartridge
usually there are are buttons on the printer on has a drop of inkt benath it one is for the paper and one is on and off
open the plastic cover of the printer
turn printer on and press the ink button for 2 -7 seconds (depending of the model) than release it , wait for the cartridge holder to "park" open the holder and remove the cartridge wich was empty by a new one and put the cartridge in the correct place, than close the cartridge holder, than close the cover, press the inkt button once and wait until it is ready
Nov 26, 2007 | Epson Stylus C42UX InkJet Printer
182 people viewed this question
jasbo
jasbo
