Question about Toshiba Televison & Video
Remote will not function - Toshiba Televison & Video
    Sergeant:
  • 207 Answers
Most of the time when the remote control doesn't work we forgot to replace the battery, but if you replaced the battery already and it never get to work it could be that some parts on the remote control most of the time components that are cold soldered. It means that due to its function we sometimes slip and accidentally drop the remote causing the components inside to absorb the shock that made the solder on the control to be weak and lose its solder. So, opening and soldering or maybe cleaning the pad connections may solved the problem. Servicing this to a technician is just a waste of money just buy a Universal Remote if you can fix it yourself. Hope this helps.
Posted on May 27, 2011
We have a Model un40eh5300fxza tv, where on the remote is the OK button
    images for where on the remote is the OK button
    More images for where on the remote is the OK button
    RC: Tv code so i can use ok/select button on comcast remote
    www.remotecentral.com > ... > Consumer > Original Equipment Remotes
    Mar 3, 2010 - 13 posts - ‎7 authors
    I have the comcast dark grey remote and a vizio lcd tv .when i press the tv button i then can press the menu button it brings up my tv menu and ...
    Button Functions by Remote ' MyDISH ' DISH Customer ...
    https://www.mydish.com/support/.../remotes/button-functions-by-remote
    Register, Button, Button Sub-Category, Function, Condition ... on screen menu/pop-up, -. 2, Color Buttons, -, -, Function varies by screen and customer selection.
    Select/OK button doesn't work when Using Comcast remote with ...
    www.avsforum.com/...remote.../1533595-select-ok-button-doesn-t-work...
Jan 07, 2016 | Samsung Televison & Video
Will my system still function without the remote?
A replacement remote could solve the melted remote problem
Oct 31, 2015 | Audio Players & Recorders
ML 320 Remote Control doesn't function
Have you tried replacing the battery in it?
Jan 16, 2015 | 2001 Mercedes-Benz ML 320
Need codes for ht3916 to chage remotes
Description=Durabrand Home Theater System (HT-3916)
Remote.name=URC-6131nwB00 PVR Remote 2K
Remote.signature=PVR0PVR0
DeviceType=Amp
DeviceIndex=3
SetupCode=1568
Protocol=00 5a
Protocol.name=NEC2
ProtocolParms=24 null null
FixedData=01 e7 e7
Function.0.name=Power
Function.0.hex=c7
Function.1.name=Mute
Function.1.hex=e7
Function.2.name=Source
Function.2.hex=d7
Function.3.name=Channels
Function.3.hex=67
Function.4.name=Reset
Function.4.hex=cf
Function.5.name=Front (-)
Function.5.hex=6f
Function.6.name=Front (+)
Function.6.hex=5f
Function.7.name=Center (-)
Function.7.hex=57
Function.8.name=Center (+)
Function.8.hex=df
Function.9.name=Rear (-)
Function.9.hex=47
Function.10.name=Rear (+)
Function.10.hex=ef
Function.11.name=Subwoofer (-)
Function.11.hex=77
Function.12.name=Subwoofer (+)
Function.12.hex=ff
Function.13.name=Master Volume Down
Function.13.hex=4f
Function.14.name=Master Volume Up
Function.14.hex=f7
Button.8=Mute'null'null
Button.3=Power'null'null
Jul 23, 2011 | Durabrand HT-3915 System
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
I have lost he remote for my Philips LX600 sound surround system . I need a code to . Can I use one for all remote to replace lost remote ?
For basic and advanced functions,I've had REALLY good luck with Philips Universal MULTI-FUNCTION remotes- Particularly the long slender silver multi-function models,and they will come with Philips functions pre-enabled-just be sure to get one w/the CORRESPONDING button for amp/receiver/stereo/stereo in-a-box,and check back of remote package to see if it operates Home Theater In a Box [HTIB] However,w/OneForAll remote,you would need to give the model # of the remote. Good Luck!
Dec 21, 2009 | Philips Home Cinema Amp + Speaker system...
MWD2205 remote stopped working for DVD functions
not sure but it sounds like you need to push the dvd button itself before dvd functions will work-it's to the left of the pause button. same thing happened to me and when i try that it works. remote seems to default to vcr i guess ....
Mar 23, 2009 | Philips MWD2205 DVD Player/VCR
Sky remote code for soyo onyx
I have this tv too. I just bought a remote control with a 'learn' function, (from a pound shop), You use the Tv's remote and copy the button functions onto the new remote, It works great, actually better than origional remote, also functions other equiptment too, sky, freeview, dvd, etc. Try that instead.
Jul 14, 2008 | Soyo Onyx DYLTO32D 32 in. LCD HDTV
Have a philips tv and a home theatre system but the remote off the surround system just changes the tv settings. Its kind of frustrating when I want to watch a dvd! Do I have to assign a freq?
When you press a function key on the remote control, not only does it change the function on the system (eg DISC, TUNER, TV etc) but it also changes the function on the remote.
However, if you change the function or source on the system, then only the system changes.
It sounds like you have changed the function on the system to DVD, but the remote is still set to TV. When in TV mode the remote will send Philips TV codes.
Press the DVD or DISC button on the remote.
May 10, 2008 | Televison & Video
Can't control DVD functions from remote
absolutely ridiculous. i ran into this problem too.
Mar 01, 2008 | RCA L26WD26D 26 in. LCD TV
Televison & Video Logo
49 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
