We need the SMPS pwer supply module or service manual for a fujitsu seimens TFT ,LCD , Model No: T32134 the SMD componenets are burnt can not be identyfide
    Genius:
  • 1,112 Answers
Hi:
You can download the service manual at this link the price for the manual is $12.99 us dollars
http://service-manuals-schematics.com/purchase.php?id=Funai+T32134-AC+Service+Manual+/+Schematics
you may be able to get it free at this site just by downloading their PDF reader.
http://www.sonicdownloads.net/download/Utilities/Nuance-PDF-Reader/?a=11393&adid=4522990226&adtype=elektrotanya.com&f=hxUGueEHC
Posted on May 27, 2011
I was given an ilive dvd player boom box, model IBPD882B and the display screen doesn't work. Can I get another screen for player?
yes, but check connections
7inch TFT LCD Display HSD070I651 480×234 Resolution 7"Analog ...
https://www.ebay.com > ... > LEDs, LCDs & Display Modules > LCD Display Modules
7" HSD070I651 480X234 LCD Screen Signal Interface 26 pins TFT Specific Analog RGB, FPC. Resolution 480 ( RGB)×234. Viewing Angle 60/60/40/60 (Typ.). (CR?10) [Left / Right / Up / Down]. Display Mode TN, Normally White, Transmissive. ' eBay!
7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button ...
https://www.amazon.co.uk/234-Resolution-Button-Monitor-420-TV.../B013FVEJP2 7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button Leg Monitor with 420 TV Lines Night Vision Camera: Amazon.co.uk: Car & Motorbike.
7-inch TFT LCD Module with 480 x 234 (RGB) Resolution, Available in ...
www.globalsources.com > All Categories > Electronic Components Number of the colors: 65KModule dimensions: 164.9 x 100.0 x 5.5mmVA size: 7 inchesAA size: 154.08 x 86.58mmResolution: 480 x 234 (RGB)LCD type: TFT and transmissiveViewing direction: 12:00IC: HX8227-A01 and HX8655-ABacklight: CCFL backlightOperating temperature: -10 to 60 degrees CStorage temperature: ...
Feb 06, 2018 | iLive Televison & Video
The LCD power supply board is in failure.
Hi Giuseppe,
Better go for a new power supply board. Burnt SMDs are hard to get. Good Luck
Apr 12, 2015 | Televison & Video
When we turn on the TV, either by the remote or the button on the side of the TV, the little light in the bottom right corner changes from red to blue and the Polaroid logo comes on the screen - just like...
Inspect the power supply module first for any sign of bad caps, burnt componenets, etc.
Service manual: http://www.polaroidsupport.com
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 21, 2011 | Polaroid TLX-02311B 23 in. LCD TV
Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
May 18, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
NO POWER ON INDICATOR LIGHT AND NO Screen Raster on Monitor
Initially, pls check D854 on the Power Supply/Logic board. It is a dual diode. If you would prefer board replacement rather than component level repair, this might be of help. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
This is of course in addition to checking the usual, power cord, fuse, outlet etc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
27' magnavox tv model 25e503
you need to check the primary input ac connection e.g fuse and then measure if you have 330 volts across the filtering capacitor..if this is ok or the fuse blows then disconnect ac-line and check pwer supply eg smps swiching transistor...probably gone to heaven..and replace it and optcoupler..i.e. refere to eventual kit from philips they have repair kits for your tv!...it may be a "standard" problem..if you can get a copy of servicing the smps...in technical manual for your tv it is best...ron
Mar 03, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
