Question about Candy Washing Machines
Candy eclypsa alice ce10 washing machine manual , i cant find one anywere
dazmaraz
  • 67 Answers
SOURCE: Buttons on CE124 candy eclypsa not working
the on/off switch sounds faulty they can get hot and jam, with the button stuck in you cant open the door, the switch will have to be replaced
Posted on Jun 25, 2007
  • 1462 Answers
SOURCE: candy washer dryer not drying
there is a safety feature which advances the timer to a stop position if it overheats on dry. this is caused by poor air flow.
to cure, take the dryer duct off mand clean of lint. this especially accumulates at the bend where the duct enters the tub.
Posted on Sep 05, 2008
SOURCE: Candy washing machine C514 manual
my machine does not start the light works on the panel.
Posted on Oct 02, 2008
SOURCE: my candy eclypsa CE1400 the
I need a operation manual for Candy Eclyps CG544T, please send me .
Posted on Oct 11, 2008
mumma_1
  • 903 Answers
SOURCE: Candy Model CE10 won't spin
It sound like the carbon brushes in the motor may need changing. It sohuld still be okay to get repaired, as most machines have generic brushes for all of thier models. It's worth calling an engineer and suggesting that the brushes have gone in the motor to get a quote on the repair job. Some engineers will come out and give you a free quote anyway.
Posted on Oct 30, 2008
My washing machine motor not rotating in washing cycle. Motor works well in Spinning cycles, but not working agitatewashing movement in any cycle. It's water filling, stopping and draining all works
Would help to have the model and type...but typically if the tub is not agitating the coupling between the motor and the tub is worn out or broken. However, if it is spinning properly, it probably indicates a problem with the transmission. Really need to know what type of washer it is to help pin down the problem. Any "burnt" smells coming from the washer? Give a little more information and maybe we can figure it out. Top load...side load, make and model preferred. You can locate that information on a plate usually attached inside the door on most models.
Apr 17, 2016 | Candy Washing Machines
Candy eclypsa ce104
it will need replacing the valve is at the top right on the rear
Jan 12, 2014 | Candy Washing Machines
My washing machine Candy CE10 does not spin and drain water
HI. firstly have you checked that all dirty water outlet pipe is clean and not blocked. or the cycle circuit could be broken.
Jan 13, 2012 | Candy Washing Machines
Hi my candy eclypsa washing machin cj534. ihave heater element in rear side but icant dryer after washing please can you expline me how to oparate and make dryer thank you your customer
I think a manual would help you ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Mar 20, 2011 | Washing Machines
Candy Eclypsa CE124/1 drum does not move on any cycle, even spin cycle.
It sounds like the motor brushes have failed. Quite a common fault and not too complicated to fix.
Oct 25, 2010 | Washing Machines
Washer Dryer overfills and pours out through front door
The pressure switch tube is only about 5mm in diameter so is easy to find, to be certain it is not blocked you need to remove it and check to see it is clear, and that the lower end where it is fixed is also clear, also make sure it is not punctured as this will result in loss of air pressure and stop the switch from working..
I assume it stops filling when you turn m/c off.
If it does not then you have a sticking water inlet valve.
plz rate my solution. Thanks.
Dec 17, 2008 | Candy CNW156 Front Load Washer / Dryer
Oct 30, 2008 | Candy AQW130 Front Load Washer / Dryer
Candy washer dryer not drying
Sep 05, 2008 | Washing Machines
Jan 18, 2007 | Candy CN126 Front Load Washer
Washing Machines Logo
290 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
