Question about Microwave Ovens
Iwant timer for my sharp microwave model r206sl
  • Microwave Ovens Master
  • 9,086 Answers
Are you having trouble with its display?
We repair these for customers nationwide with our guaranteed $39.95 service.
Otherwise, what problem do you have?
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 18, 2008
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    When I set the timer and close the door, the door latches fine. When I push the start button the timer starts to countdown but the microwave doesn't start. If I push the door release in about 1/8 " ,...
    If your model number is in the Sharp R-1500 series, then that's a problem with the bottom door switch or its mount.
    See these files:
    http://207.234.249.73/mwd/safety.txt
    http://207.234.249.73/mwd/disassembly.txt
    http://207.234.249.73/mwd/doorsw.txt
    Jan 14, 2011 | Sharp R-1511 Microwave Oven
    I need a microwave timer knob for a sharp carosuel II model number R2M52B where can I find one or a replacement part that is compatable? Chris
    You can go to www.applincepros.com and enter your model number and order the part you need, they also have a 800 number that costs you nothing to call and they have free shipping. You won't find the part in any local repair shops. Hope this helps you find what your looking for. Marry Xmas.
    Dec 08, 2010 | Sharp Microwave Timer Knob 80QBP1089
    Sharp Carousel Model R-1440 won't shut off
    Take it immediately to a local Microwave repair shop...looks like one of the circuits may have gone...otherwise switch off from mains
    Sep 28, 2009 | Sharp R-1480 Microwave Oven
    My sharp mivrowave model # r-1875 shuts off every 59 seconds how do i fix it
    Therre is a timer that has to be replaced by a qualified technician, either A & E appliance repair or Sears Home Central. I had the same problem with that model Sharp. Good luck.
    Sep 18, 2009 | Sharp Microwave Ovens
    My Sharp Model R-520LW microwave will not cook. The timer, light, clock all work. The turntable, fan and microwave do not.
    Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
    Sep 15, 2009 | Sharp R-520LW Microwave Oven
    Unlocking child lock on the sharp microwave model R316FSC
    The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
    Or just unplug it, wait 1 minute, and plug in.
    Jan 06, 2009 | Sharp R-308J Microwave Oven
    Sharp model number: R-320HQ (1200 watts)
    the electronic circuit are corroded timer does not function / the IC program was lost of memory such as function / if you have some old look a like Sharp Model you may transfer control panel.
    Jan 05, 2008 | Sharp R-510HW Microwave Oven
    Sharp R-1505 microwave
    The power fuse open , if open replace it don't make jumper it b
    cause fire .
    the power transformer builtin fuse open/
    The door micro switch open /need to replace.
    Jan 03, 2008 | Sharp R-1505 Microwave Oven
    Microwave Ovens Logo
    19 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
