Need to find a manual for a candy eclypsa alice ce10 washing machine as i dont know how to operate machine
dazmaraz
  • 67 Answers
SOURCE: Buttons on CE124 candy eclypsa not working
the on/off switch sounds faulty they can get hot and jam, with the button stuck in you cant open the door, the switch will have to be replaced
Posted on Jun 25, 2007
SOURCE: operation manual for GE washing machine
http://genet.geappliances.com/DocSearch/Dispatcher
try here
Posted on Mar 06, 2008
SOURCE: Candy washing machine C514 manual
my machine does not start the light works on the panel.
Posted on Oct 02, 2008
SOURCE: my candy eclypsa CE1400 the
I need a operation manual for Candy Eclyps CG544T, please send me .
Posted on Oct 11, 2008
  • 19 Answers
SOURCE: i have a venus vw600b front loading washing
NOTHING TO WORRY PUT YOUR WASHABLES INTO IT AND CLOSE THE DOOR AND SET TIMER ACCORDING UR NEED
Posted on Aug 05, 2009
My washing machine motor not rotating in washing cycle. Motor works well in Spinning cycles, but not working agitatewashing movement in any cycle. It's water filling, stopping and draining all works
Would help to have the model and type...but typically if the tub is not agitating the coupling between the motor and the tub is worn out or broken. However, if it is spinning properly, it probably indicates a problem with the transmission. Really need to know what type of washer it is to help pin down the problem. Any "burnt" smells coming from the washer? Give a little more information and maybe we can figure it out. Top load...side load, make and model preferred. You can locate that information on a plate usually attached inside the door on most models.
Apr 17, 2016 | Candy Washing Machines
Candy eclypsa ce104
it will need replacing the valve is at the top right on the rear
Jan 12, 2014 | Candy Washing Machines
My washing machine Candy CE10 does not spin and drain water
HI. firstly have you checked that all dirty water outlet pipe is clean and not blocked. or the cycle circuit could be broken.
Jan 13, 2012 | Candy Washing Machines
I need to know how to use my candy eclypsa ce84 combiwasher. just the basic controls. thank you
Unfortunately FixYa cannot provide that direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 06, 2011 | Washing Machines
Hi my candy eclypsa washing machin cj534. ihave heater element in rear side but icant dryer after washing please can you expline me how to oparate and make dryer thank you your customer
I think a manual would help you ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Mar 20, 2011 | Washing Machines
Washer Dryer overfills and pours out through front door
The pressure switch tube is only about 5mm in diameter so is easy to find, to be certain it is not blocked you need to remove it and check to see it is clear, and that the lower end where it is fixed is also clear, also make sure it is not punctured as this will result in loss of air pressure and stop the switch from working..
I assume it stops filling when you turn m/c off.
If it does not then you have a sticking water inlet valve.
plz rate my solution. Thanks.
Dec 17, 2008 | Candy CNW156 Front Load Washer / Dryer
Candy Model CE10 won't spin
It sound like the carbon brushes in the motor may need changing. It sohuld still be okay to get repaired, as most machines have generic brushes for all of thier models. It's worth calling an engineer and suggesting that the brushes have gone in the motor to get a quote on the repair job. Some engineers will come out and give you a free quote anyway.
Oct 30, 2008 | Candy AQW130 Front Load Washer / Dryer
Candy washer dryer not drying
there is a safety feature which advances the timer to a stop position if it overheats on dry. this is caused by poor air flow.
to cure, take the dryer duct off mand clean of lint. this especially accumulates at the bend where the duct enters the tub.
Sep 05, 2008 | Washing Machines
Jan 18, 2007 | Candy CN126 Front Load Washer
Washing Machines Logo
235 people viewed this question
Top Washing Machines Experts
