Question about Dimplex Compact Electric Flame Stove Heater
Flame effect has stopped but fans still working. Can it be repaired. I am in Christchurch.
    Brigadier General:
  • 4,736 Answers
More than likely, the bulbs that produce the fame effect have burned out and need to be replaced.
Robyn, you can access the bulbs by removing the rectangular cover on the back of the stove. It's located just above the bottom edge on of the back cover. The bulbs are 60 watt, small base chandelier bulbs. They simply unscrew to remove. Be sure to unplug the unit, before attempting any maintenance.
Hope this helped you. Please let me know. Thanks.
Posted on May 27, 2011
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I replace or repair the flame effect?
Typically the flame effect is accomplished when a motor turns a rod with polished metal strips on it. The strips then reflect the light onto the back of the glass. The the rod rotates, the reflection moves giving the effect of the flames moving. If the lights work on your unit then the motor has most likely stopped. It would need to be replaced. A quick internet search turned up nothing for that company so you may need to go back to the store where you purchased the unit to get the part. Once you have the part, you will need to disassemble the unit. Some units are simple (like removing the fake logs) and some units are more involved (like removing access panels from the back or bottom).
Mar 10, 2014 | Vendor Development Group Inc Borgen...
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I get a replacement flame effect?
Fire was working fine, then flame effect stopped. Heater still works on both settings, but no flame effect. Tried new bulbs, but still no flame effects, any ideas?
If it is not the bulbs, it is often a melted switch or circuit board.
You can obtain technical support for your stove here:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Jan 05, 2013 | Dimplex Compact Electric Flame Stove...
My Acer computer monitor has stopped working is there a place in christchurch that it can be repaired
The problem might cause by faulty Capacitors in the power circuit. You need an electrician or a Computer shop in your Town. Thanks. Please Rate my Help.
May 05, 2011 | Acer X193WBD Monitor
Flame does not flicke in my electric fireplace
if flame not flickering and you can see the globes lighting flame its the fan that moves the ribbons is faulty unless it has fuse to it which may have blown, but how the flame works is by globes lighting through ribbons that are moved by a fan to give a flicker effect unless its rotating glass wheel like some, that turn with the globes behind that give you a flickering effect its always better with electrical to have an electrician look if it was the globes yes that is an easy replace but to change a fan or rotating glass wheels
Nov 28, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
I have a wall mounted electric fire with flame option,I have changed the bulb but cannot get the flame effect to work. The falme wheel is turning but no light effect.
have you checked fuse to bulb some electric heaters have a fuse for bulbs and fans so it might be a small inline fuse that you need to change
Nov 22, 2010 | Heating & Cooling
Charmglow electric fireplace . no light for flame effect
the fan is working. I do not have the flame effect fixed. I find this web site difficult to get any help from.... seems to go around in a circle. Just tell me if it can be fixed.. I want to know about the bulb (?) or whatever makes the flame effect. Nothing seems to be able to take apart , if not do you have a website I can get to for a new one.....thanks....
Mar 25, 2009 | Fire Sense Georgetown Electric Fireplace
Dimplex SHB20 Sherbourne Electric Stove -Flame Effect not working
Call Dimplex : 1-800-668-6663 ext: 358 they are kind and very helpful, they will send you arts to repair.
Jan 10, 2009 | Dimplex Compact Electric Flame Stove...
Dimplex Compact Electric Flame Stove Heater Logo
364 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
