Question about SanDisk 2GB microSD Memory Card
My micro sd card is detected in my system and when i open it ,it shows there is no drive found............
    New Friend:
Well. That is to say, your files may have lost. But don't be nervous, you can get it back by using recovery tool. Try 4Card Recovery.
Step 1. Download 4Card Recovery on the internet and install 4Card Recovery on your computer.
Step 2. Run it and select the files that you want to recover on your micro SD card.
Step 3. Scan it by clicking the 'next' button and just need to wait for about ten minutes.
Step 4. Save the recovered files on other section.
How to Recover Photos Videos off SD Card after Formatting Unformat SD...
Posted on Apr 04, 2014
    New Friend:
This is quite complex because many reasons can cause this problem. Mistaken operation, sudden power off when the card is working, accidentally format or delete. Anyway it was, you can try 4Card Recovery to restore data first. Be careful, don't let your old data covered by other things.
    Novelist:
  • 132 Answers
1. Try to verify if the SD card is still working by plug it in on another known good source (example computer, camera... etc.)
2. If it not working you have to replace the card itself
3. If it is working on another source. try to go to device manager and uninstall / reinstall the drivers for SD card. by doing this right click on the SD driver itself and left click on uninstall. Right click on the "computer name" under device manager and then Click on "Scan for Hardware Changes"
4. If you have a cd for the sd card slot well and good
5. got to safe mode see if the SD card is detected on safe mode
6. Also you might want to scan the computer for any viruses
Posted on May 27, 2011
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have a 2GB micro sd card,but when i check it into my cellphone,my memory card is error.What is the problem of my memory?
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
Step Two:
Using the HP Drive Key Boot Utility, the first way
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | SanDisk 2GB microSD Memory Card
When I enter my memord card in nokia 311 it say the operation is failed and the memory card is not formatted.how to remove virus from my memory card and replace my music and Image.
Step One (save data)
When do the data recovery process, you can find the cause of damage to the micro SD.
Cause of the damage the virus infected (solutions: see method 1)
When saving data, be careful, do not recover the virus file. You must choose the proper file for the recovery.
Cause of the damage bad sectors (solutions: see method 2)
Damage to the partition table (solutions: see method 1)
Micro SD write protect. Characteristics: (solutions: see method 3)
1. Micro SD can be opened, the data can not copy and paste (from the micro SD into a computer, or from computer to the micro SD). When the format, the message "Removable media write protect".
2. Micro SD can not be opened, and when the format of the message "Removable media write protect".
Step two (repair micro SD)
Method
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
Method 2
Method 3
To write protect a micro SD cases, 40% probability of success.
Oct 02, 2011 | SanDisk 2GB microSD Memory Card
How do I transfer pictures from my cell phone to my laptop
You can transfer pictures to your laptop by using a Micro SD card reader like the one in the image:
Insert the Micro SD to the slot which says "Micro SD" and then plug it in the USB port of your laptop. The laptop will soon detect the Micro SD. Open "My Computer" and then choose the removable drive which is usually E: or F: or G:. Thanks.
Sep 16, 2011 | SanDisk 2GB microSD Memory Card
When i try to format my micro sd card system shows remove write protect how can i format it
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
2GB MICRO SD CARD NOT DETECTING IN MY FORME MOBILE
Check the SD card on the laptop or PC using the card reader. If the card is detected then format the card and see if the properties show full storage.
now try and insert on the mobile and if this is not seen there is support for the card from the phone.
Jun 14, 2011 | SanDisk 2GB microSD Memory Card
Its 2gb micro sd card and on that some serial no. described............... the problem is:- when i put my card in mobile phone and if i will open its galry then it shows unformated and when i connect...
I had the same problem with my micro SD card . To solve the problem, I used my phone's software to format my card. FY I : make sure your card is unlocked before you try to format it with your phone . If your card has a lock it will be a small sliding plastic switch on the site of the card .
Oct 05, 2010 | SanDisk 2GB microSD Memory Card
How do i download music from windows media player to my micro sd card
hello there are two way u can do that, get a usb card reader and follow any of this process
1. put the micro sd card into the card reader and plug it to your computer then your system will see the card automatically, then open your window media player and the player will detect the card and you will synchronise musics from your windows media player libery to the card.
2. you can copy the music direct from your music folder in your computer and paste it on the micro sd card.
take care
rate this
Jun 04, 2010 | PNY 4GB microSD High Capacity Mobile Media...
Sd card is detected but cant open
I find that the easiest place to find files on a HDD or SD card that i connect but the drive comes up is by going right click on computer and going to the manage option.
I then go down to disk management and look for the storage that I have added.
Then right click on "change drive letter and path" and add give the storage a drive letter
For some reason the computer sometimes does not complete this part which leaves the drive unreadable
It is always a good thing to do to go to device drivers to check that you can see the drivers for the device being installed. This can be achieved by removing and replacing the storage device while device manager is open
May 26, 2010 | SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD Memory Card Logo
138 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
