Question about Kitchen Ranges
Removing the gearbox and motor on the 6801 meat saw
  • James Groover May 27, 2011
    I have the parts diagram and you do need tools. So no your answer did not help. does anyone else know or have an instructional video
    Guru:
  • 1,833 Answers
It seems like you want to remove the gearbox and motor on the 6801 meat saw. To do this you do not need any tools. Follow this link "https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F-39903.pdf" - have some diagram. Hope this will help you.
Posted on May 27, 2011
  • Aloke Das May 27, 2011
    Sorry that it's not helpful for you. I will try to find some suitable instructions.
Where can I find a replacement blade for a central machinery meat saw with a 76 3/4" blade
harbor freight has there own parts department , they sell parts for everything they sell , I just got new brushes for my electric drill from them , give them a call !!! ask for parts !!
Apr 09, 2016 | Blade Saws
How do I get the motor shaft out of the gearbox
You didn't say what type of saw you have.
Mostly portable power tools of standard construction the motor armature can be removed from the gearbox quite easily. Once the other motor components have been removed, generally it is only the resistance of the drive end bearing of the armature in the gearbox housing that must be overcome. Sometimes the bearing is an easy push fit and sometimes quite a lot of force is needed and the casing should be expanded a little using heat.
Jan 23, 2016 | Saws
CAN I USE A SEARS 12 INCH BAND SAW TO CUT MEAT. WHAT TYPE OF BLADE DO I NEED. DO I CUT THE MEAT FROZEN OR NOT?
That will work with the meat frozen or thawed, but the problem will be that the band saw will be very difficult to clean adequately afterwards. That won't be a big problem until a week after you have cut meat with it the first time. Once it stinks you won't want to use it cut anything! A meat-saw is made to be easier to clean than a wood or metal cutting bandsaw.
Dec 10, 2012 | Saws
Chain stops when it touchs log
A gas engined saw has a clutch that can slip if overly oiled internally, but electric saws don't use a clutch. Most however, have a safety disconnect to the drive sprocket that shears or otherwise removes power to the chain while the motor runs. The worst problem can be a broken gear within the gearbox and requires dis-assembly to discover. Many modern saws use plastic gears in place of metal ones and are prone to failure. The fact that the chain turns when not under load would seem to eliminate the gearbox, but don't discount that until proven. Hope this helps!
Jun 23, 2010 | McCulloch 10" Electric Pole / Chain Saw
Start procedure for chainsaw ncr 4550
The header says that this is an electric saw which doesn't have a start procedure--just push the button and it runs. Electrics also don't have a clutch because the motor doesn't need to continue running when not cutting like a fueled engine does. Most electrics, however, have a safety device that uncouples the chain drive sprocket from the drive shaft to protect the gearbox. Remove the bar and chain, then look for a broken/disconnected drive link or spring connected with the sprocket. If the shaft itself does not turn, then there is likely problems in the gearbox. Hope this helps!
Jun 03, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Hobart model 5801 meat saw conversion from 3 phase to single phase can it be rewired or need a new motor ?
No, you need a new motor or a converter, but in the case of one saw, it wouldn't be worth the conversion. Just find an old single phase motor that will fit height wise and you should be all set. The speed is the same, the direction can be switched and the HP should not matter much, 1/2 , 1, depends on what you find out there. They all should cut wood no problem. Hope this helps.
Mar 15, 2010 | Saws
I need grinder parts for rdq250 meat saw
I NEED PARTS OF MEAT SAW RDQ 250, WHERE CAN I FIND IT IN MEXICO PLEASE?
MAIL tremosa4@yahoo.com.mx
thanks.
Dec 11, 2009 | Northern Industrial Tools Electric Meat...
Kitchen Ranges Logo
55 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
