Question about Lexmark Office Equipment & Supplies
Lexmark C500 showing fault Replace Belt CG - Lexmark Office Equipment & Supplies
5 Suggested Answers
  • 169 Answers
SOURCE: Error Message ('replace belt CG')
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  1. Power the printer on while holding down MENU/ENTER key
  2. Release the key when the display shows "Utility Menu Clear FC Roll"
  3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
  5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
  6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Posted on Mar 31, 2008
SOURCE: Lexmark C500 Error light showing,with
Remove the cartridge, take a flashlight and check the right side inside the printer for a RED LED (in the place where the cartidge stays). Take a tape and patch that LED. That's all ! Enjoy
Posted on Apr 03, 2009
  • 6 Answers
SOURCE: replace belt CG
Set Belt CG The OPC belt cartridge needs replacement.
Replacing the Optical Photoconductor (OPC)
Belt Cartridge
Replace the OPC belt cartridge at least once every 12 months, or when
the control panel display indicates that replacement is necessary. The life
of the OPC belt cartridge for the T8106 is about 60,000 images (15,000
color pages), at a 5% toner coverage rate on letter-size paper.
1. Turn the power switch off.
2. Unlock the lever to open the front
cover. This releases the pressure on the
toner cartridges.
3. Unlock the lever to open the top cover
fully.
4. Pull the green OPC belt cartridge lock
levers up until they unlock.
5. Pull the used OPC belt cartridge
upward and out of the printer carefully
to avoid spilling toner.
6. Discard the used OPC belt cartridge
Caution! Do not touch or wipe off any powder that is on the OPC belt, nor expose
the OPC belt to light.
7. Remove the two shipping pins from the
new OPC belt cartridge.
8. Remove the protective sheet that covers
the photosensitive belt.
9. Slide the new OPC belt cartridge downward
into both green lock-lever guides
and into the printer carefully.
10. Push the green OPC belt cartridge lock
levers down until they lock.
11. Close the top and front covers carefully
until they both lock.
Posted on May 28, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: error msg appear set belt
    The error can either be caused by the OPC/OPC Marker assembly or the Main Motor assembly. Please follow the recommended troubleshooting steps:
    1. Power the printer off, remove and reseat the OPC unit, and power the machine back on. Print a test page. If error continues, proceed to step 2.
    2. Power the printer off and remove the OPC unit. Check the OPC Marker Sensor. If it is unsnapped or unplugged, reseat or replug it, and power the printer back on. Print a test page. If error continues, proceed to step 3.
    3. Remove the OPC unit and check it for scratches or defects. Also check the the markers on the OPC to make sure they are not damaged. Is the belt scratched or damaged? If the OPC is at or near the end of its life, OPC unit must be replaced. If the belt is in good condition, contact Lexmark technical support (if printer is under warranty) or your local authorized service provider for assistance.
    Posted on Sep 30, 2010
    I need to change fuser rollers on my c500
    http://www.provantage.com/lexmark-c500x28g~7LEXA1HU.htm
    This is a complete part the above link shows what it looks like. Remove in one piece and replace it.
    Jan 03, 2011 | Office Equipment & Supplies
    Error msg appear set belt cg dont know what to do.. am i have to replace the photodeveloper cg?
    Sep 30, 2010 | Lexmark C500n Laser Printer
    Can't install Lexmark C500 printer on my macbook pro. my O is snow leopard (10.6.3)
    Unfortunately, the Lexmark C500 printer's support ends up to Mac 10.5 operating system only. There's no available driver for Mac 10.6.3. That would explain why you can't install the printer in your computer. Hope I can assist you more on this.
    Apr 14, 2010 | Lexmark C500n Laser Printer
    Menu screen comes up with (Replace Belt CG)
    The 'Replace Belt CG' message on the 8008 indicates the OPC Belt (Green Reflective Belt which is located in the top of the printer) has reached the end of its life and needs to be replaced to ensure the print quality is maintained.
    If you are happy with the print quality you can clear the message via the control pannel on the printer, you will however need to remember you have cleared the error in the future when print quality is reduced you will then need to replace the OPC Belt.
    The ‘Replace Belt CG’ message can be cleared in the following way;
    With the printer OFFLINE hold down the MENU button for 2-3 seconds until the display changes UTILITY MENU and then release the MENU button
    Press the MENU button once more
    The display will read "Utility Menu Clear Belt CG", press the MENU button once more
    The display will change to "Clear Belt CG Not Execute" by pressing MEDIA/> key again the display will change to "Execute"
    Press the MENU/ENTER key again after 10 seconds the display will change to "Completed Clear belt CG"
    Press the UP ARROW button twice to exit the Utility Menu
    Press the ONLINE button to return the printer to the ONLINE state
    The ‘Replace Belt CG’ message will now be cleared.
    Jan 28, 2010 | TallyGenicom 8008 Laser Printer
    What does Replace Belt CG mean?
    When the Replace Belt CG message appears, the photodeveloper cartridge has been exhausted and will need to be
    replaced. Order Lexmark part number C500X26G.After a new photodeveloper cartridge is installed, reset the
    photodeveloper count.
    1 Make sure the printer is on and the Ready message appears.
    2 Press .
    4 Press and hold for 3 seconds until you see Utility Menu, and then press .
    5 Press until you see Clear Belt CG, and then press .
    6 Press until you see Execute, and then press .The photodeveloper belt count is now reset.
    7 Press to return to Ready.
    Jan 12, 2010 | Lexmark C500n Laser Printer
    Replace belt CG
    Belt Cartridge
    toner cartridges.
    fully.
    May 28, 2009 | Tally T8106 Laser Printer
    COLOR LASER PRINTER LEXMARK C500 PROBLEM
    Unstable transfer belt rotation–color matching cannot be secured.
    Check the transfer belt
    Aug 11, 2008 | Lexmark C500n Laser Printer
    Lexmark C500 Error light showing,with New ink cartrige inserted showing toner low replace cartrige on machines display? Help!! thanks
    Jul 02, 2008 | Lexmark Office Equipment & Supplies
    Jul 12, 2007 | Tally T8006 Laser Printer
    215 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
