Question about NetGear FS605 (FS605SE) Networking Switch
NetGear Switch FS605 v3 (5ports) Please advice what is a color code for LED's lights I have connected 3 cables into switch and only 1 has green LED light,(as should be) but others have orange color is it ok?
dugiehowsa
  • 114 Answers
SOURCE: Netgear JGS524 appears to be dead...
This is an un-mamaged switch, so it is very difficult to get any kind of diagnostic information out of it. Some times, this may mean that the switch is on and active, but at those times, there is some times a mode button to switch through the different types of indicators on the switch. This switch doesn't even have that. There is almost no documentation on this device. The only thing I could find was this install guide, and it doesn't mention anything about the lights indicating some type of diagnostic code. If you connect two machines to the switch, and both these machines have Static IP addresses (do not use DHCP), can they ping each other? If the can, then I say the switch is fine and its just a cosmetic problem. If they cannot, then I am afraid you will have to return this one as well.
Posted on Sep 18, 2006
SOURCE: link led blinking
WIRE AS U ARE USING WILL WORK FINE TILL 80- 85 METER. AND THERE IS DIFFERENT COLOR CODING EITHER U USE 10 METER OF WIRE OR 25 METER OF WIRE THERE IS A STANDARD COLOR CODE WHICH IS PROVIDED BY IEEE. I THINK THERE IS ANY PROBLEM IN YOUR SWITCH. IF YOUR WIRE IS OK AND PC ETHERNET CARD IS PERFECT THEN OBVIOUSLY ANY PROBLEM IS IN YOUR SWITCH. U CHECK IT PROPERLY EACH AND EVERY PORT. B'COZ SOMETIMES SOME PORTS PROBLEM CREATE HIS TYPE OF DISTRUCTION. GOOD LUCK PURUSHOTAM
Posted on Oct 04, 2007
  • 22 Answers
SOURCE: Only 1 computer getting internet with FS605
Sorry to say, you have the wrong part. Whoever told you you could hook it up to both your PCs and your cable modem didn't know what they were talking about.
Your FS605 is just a switch; hooked up directly to a cable modem, you will only see one IP address as that's all the cable modem will allocate.
What you need is a router, to allocate multiple local IP addresses and share the connection up to the cable modem.
Linksys BEFSR41 routers are ridiculously cheap these days and highly reliable, or if you like Netgear, you'll need the RP614.
Posted on Nov 09, 2007
  • 31 Answers
SOURCE: I bought a netgear FS605 swtich and it doesn't work on the ps3.
Yes you must by a router my friend.
The problem is your ISP will not give out extra Ip addresses for additional clients. The router will have a dhcp server built in and that will fix the problems at hand.
Posted on Apr 09, 2009
  • 5 Answers
SOURCE: Netgear JFS524 network cable unplugged error on all pc'c
Hi Ewan,
How is the modem/router connected to the switch?
Have you tried changing the patch cable that connects them together, or the port they are connected from?
When troubleshooting this type of issue, it is always best to check each layer of connectivity (1-Physical,2-Data Link, 3-Network Addressing, etc.) in order from bottom to top, due to each layer being dependent on the layers before it.
DNS is important but wont be available until you have a physical connection and a IP address.
If you can achieve a stable connection while the PC is connected directly to the modem/router, but not via the switch then work your way from one end of the link between the working component (in this case the modem/router) to the other (PC) - testing each part along the link.
If the switch is faulty after you have performed some testing, it is best to change it out and test with another switch (if avalible), before purchasing or sending the JFS524 away for repair (if still under warranty).
Let us know how you go with the testing.
Posted on Aug 15, 2009
Testimonial: "Thank you for the feedback. I did test everything and it was a faulty switch. Replaced it and everything is working again. Regards"
FS605 V2 5-port Fast Ethernet Switch 10/100 Mbps setup
Try repairing second by right clicking on network icon. Make sure drivers are ok in Device Manager. To verify IP's on machines use ipconfig /all from the command prompt. Get there from Start > Run > type cmd.
Aug 04, 2012 | NetGear Computers & Internet
My Netgear FS605 stopped working. All lights flashing about 1x/sec. No change in cabling or configuration in past year. Upstream Linksys N wireless router working fine. Tried disconnectring ethernet...
Are you able to ping between systems connected to the same Netgear FS605 switch and in same VLAN.
I suspect either switch port or Uplink cable issue.
Please try changing a new cable and if no improvement then please try with a different switch port.
Jan 08, 2011 | NetGear FS605 (FS605SE) Networking Switch
Lookig for a manual for an fic au13 motherboard
Front Panel Block Cable Connections
f_Panel
1 3 5 7 9
2 4 6 8
1] HDD-LED (+)
2] Dual Power-LED* (+)
3] HDD-LED (+)
4] Dual Power-LED* (-)
5] Reset Switch
6] Power Switch
7] Reset Switch
8] Power Switch
9] Dual Power-LED* (**)
* Single Color Power-LED 2 or 3 pins:
1 2 3
1]Power-LED (+)
2] GND
3] GND
** Dual Power-LED:
if useing dual power LED,
Green: pin2
Yellow: pin4
otherwise, Pin2 is positive (+) Pin4 is negative (-
For future Reference you can download your manual directly from the manufacturer's website HERE
Or directly from HERE
May 30, 2009 | FIC AU13 Chameleon Motherboard
Feb 20, 2009 | NetGear FS605 - 5-Port 10/100 Network...
Switch to switch connection
in the 1st end of your cat5 cable the color codes are: white orange, orange,white green,blue,white blue,green,white brown,brown and in other end codes are: white green, green, white orange, blue, white blue,orange,white brown,brown....gud luck
Jan 16, 2009 | PC Connection Cross-Over Cable (363003X)
Connection issue
put the blue cable connection with the router and cable modem first.configure wireless setup.put the desktop rj45 connection to a free router rj45port.As u are getting internet on wireless check the desktop ip configuration.obtain auto ip configuration should be clicked.
Jun 28, 2008 | NetGear FS605 - 5-Port 10/100 Network...
Wont connect and software cd
To connect a router or a dsl modem to a switch you either have to use port 4 or use a utp crossover cable. As you can see on the Netgear FS605 the modem/router has to be connected to port 4.
The correct way to connect these devices is:
Modem > Router > Switch > Computers
Jan 14, 2008 | NetGear FS605 (FS605SE) Networking Switch
Is my FS605 broken
The FS06 switch is probably defective and needs to be replaced...especially if the status of the lights does not change after you cycle the power on and off with no network cables plugged in. These switches are sensitive to overheating and can easily be damaged if used next to other warm network equipment or with air vents blocked by papers, etc.
Turn-on order is not critical in this scenario, but ideally you should plug in all network cables, turn on the switch first, then turn on the computer.
Jan 10, 2008 | NetGear FS605 (FS605SE) Networking Switch
Nov 07, 2007 | NetGear FS605 (FS605SE) Networking Switch
Link led blinking
Oct 01, 2007 | NetGear FS608 Networking Switch
NetGear FS605 (FS605SE) Networking Switch Logo
346 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
