Question about Ricoh Aficio 2027 All-In-One Laser Printer
Continuous paper jamming in c section of Ricoh aficio 2045
Sensor is not working
Posted on May 27, 2011
Ricoh Aficio 2045 paper jamming c section
check there is a small paper or there is dust at the laser unit so try take out the laser unit and clean it nicely
May 17, 2011 | Ricoh Aficio 2027 All-In-One Laser Printer
I have a Ricoh Aficio 2045 and whenever i try to copy double sided the paper jams in the copier but is fine when copying single sided. It always Jams at Point C in the photocopier?? Can anyone help me??
This jam problems are always very difficult to solve without seeing the machine!
Because i need to see the jam location or take a report to see where the paper jams.
you say that it is on the Point C, but that just helps a little.
I can tell you that you have a problem in the duplex door (but you already know that). It could be several things like; transport rollers, gates, solenoids... well, the best help i can give you is to advise you to call your technical support.
See you!
Apr 30, 2011 | Ricoh Aficio 450 Copier
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Jan 27, 2011 | Ricoh Aficio 450 Copier
I need to know the part number for the toner replacement bottle for the Ricoh Aficio 2045 PCL 6
Ricoh Aficio 2045 copier/printers take the Ricoh Type 3110D Toner Cartridge. Go with OEM toner on these machines. The generic version tends to make them run dirty.
Sep 09, 2010 | Office Equipment & Supplies
Ricoh Aficio 2045, FAX delivery Report
Try pressing the USER TOOLS button and look for a reports menu.
Jan 21, 2010 | Office Equipment & Supplies
Paper jam indication, but cannot find the paper that is jammed
I would check to see if the paper is even making it out of the tray. A lot of times, the feed rollers can get dirty, and the printer will display a jam if it doesn't feed in time. If the feed rollers look ok, then I would check and see if the feed rollers are even turning. Sometimes the motor that turns the feed rollers wears out.
Nov 11, 2008 | Ricoh Aficio CL7200 Laser Printer
Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Sep 25, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 2027 All-In-One Laser Printer Logo
196 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
