The HDD makes a tic tic sound when connected to the computer but doesn't appear in the explorer.....
  • 32,281 Answers
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Posted on May 27, 2011
It dosen't works it make a sound like(tic tic tic about 5 second and will shut down)
HDD , if the power is good, is it? full spec voltage.
most FAST 1tb drives need a power pack,
has a 7 year warranty their home page states, so why not use that.
no HDD should make load noises, only ear close whiling sound.
soft ear close tics very very quiet is normal, load , NEVER.
if it makes noise say at arms distances that is bad.
2 causes:
1: the power pack is not plugged in, or missing or wrong pack used? (never run HDD with missing pack or wrong one.
2: drive bad. (bad drives click, when bad)
it can be the drive bad, or the power regulator toasted.
7 years. is a very long time. read the rules on your warr, card.
do not ever block the cooling slots of any HDD, case. ever.
or it will overheat, all fast drives can overheat, easy.
make sure that dont happen.
Oct 02, 2013 | Verbatim Sns1tb Store n Save 1 Terabyte...
The display of my laptop is not working when i switch it on the backlight glows but nothing appears on the screen it doesn't even boot.
It would be helpful if we knew the Make, Model of Laptop and the OS you are using? Try a hard restart , remove ALL media, DVD, CD, USB, etc., unplug , remove battery, leave battery out, plug in , reboot. Describe what happens, Fan spins? LED's blink? HDD spins up? Sound? Anything on screen? Have you tried a System Restore/Recovery? You can start by removing the HDD and testing it, if you done have a USB to sata/ide adapter take it to a Qualified Computer Tech.
May 04, 2013 | Computers & Internet
Computer doesn't recognices HDD how can i reconfigure it
Either your HDD died or the connecting cable came loose. Open the HDD enclosure and check to make sure it's connected properly. Maybe reseat the drive.
Jun 29, 2012 | Toshiba Satellite 2545CDS Notebook
For last 2 weeks, whenever I tried to open my PC (Clone PC), HDD became start to make a noise, Tik-Tik-Tik. Windows cannot be loaded. I tried with a bootable CD, but it also fails to load any Drive. I
The tic tic tic noise is known as the tic of death. This hard drive is faulty especially when you go into the BIOS and the hard disk is not detected. This is why when you try to install Windows it cannot detect a hard disk.
The hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Jun 12, 2012 | Computers & Internet
Toshiba fell once and it doesn't work
To access the important files, you can remove the HDD, and connect it to another computer where you can move the files to the new computer, and then to a USB thumbdrive:
The needed adapter is under $20.00
https://www.google.com/search?q=usb+hdd+adapter&ie=utf-8&oe=utf-8&client=firefox-b-1-ab
Jan 29, 2018 | Toshiba Canvio Plus 320 GB 2.0 Portable...
My hitachi hard drive Hitachi HDT721064SLA380 isn't detected by computer and i can here a sound "tic tic" in the HDD ,Thanks .
Hi Welcome to Fixya!
Your hdd is making that sound mainly because it could already be damaged inside. That is also the reason why it is not being detected by the computer.
Same thing happened to me with my 120gb Seagate Barracuda.
Consider in replacing the hard drive on your computer.
Hope this could help!
Have a great day!
Jun 30, 2011 | Hitachi Deskstar 7K1000.B HDT721064SLA380...
The car is starting 1/10.. Firts i turn ignition key and the light in the dash are lighting up good,i turn the key and nothing happen.I take the off the ignition and it make a tic-tic-tic on the...
We have to assume the battery is usable, if not, anything else doesn't help. A couple of possibilities- First, get a simple, cheap device that uses a 9V battery and the car's cigarette lighter to prevent losing anti-theft codes. Once this is plugged in, remove the negative battery cable first, then the positive. CLEAN the battery connectors and terminals. Try to start the engine. If it still does the same thing, remove the negative battery cable again and follow it to its next connection and clean that point. While it is off, remove the other end of the positive cable which goes to the starter terminal and clean both points.
While under the hood, look for the cable connecting the engine block to the body of the car and clean both ends of that cable.
If the problem is still there, it can be related to one of these; the ignition switch, the starter solenoid or a corroded fuse connection. The starter is not protected by a fuse but the solenoid may be.
Good luck-
May 28, 2011 | Nissan 300ZX Cars & Trucks
Dell 1545 not detecting my harddrive
this problem to an i/o device happens mostly when itz defective/faulty..
check the following:
(to take data backups u gotta connect the hdd to another pc/laptop, for such cases a hdd-case is available in the local spare market, it'll make behave ur hdd to act as an external removable drive)....
1)if ur hdd is making any humming noise (like 'tic tic' or 'kirr kirr')..if so it is likely to be replaced..
2)check for bad connections..
3)update/flash the bios..
4)check for firmware update and or raid drivers (as applicable)..
if u r not a professional, try contacting ur system admin/vendor....
Nov 12, 2009 | Dell Inspiron 1525 Notebook
Tic tic tic sound
Check for other problems. You might need to buy another FET as well. But this time don't put the FET back in until you make sure nothing can blow it.
May 15, 2009 | LG L1915S 19" LCD Monitor
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
