Problem is when i power on the machine J code is coming what is J
  • 31 Answers
Please browse the below site.
www.buzzle.com/.../printer-error-codes-what-you-must-know.html - Cached - Similar
Posted on May 27, 2011
How do i fix my copier konica code f-35-3
Power off the machine. Then holding down the 2 and the 5. Power on the machine. When the screen comes on your in Mode 25. Locate soft switch. In the first box you will put a 3, second box put 1, change the third box from 1 to 0. Then power off. Power on if the code comes back your fusing unit (The Hot Part has issues) Do not reset again your resetting the fuser code. The fuser could catch on fire, that would ruin a perfectly good day.
Mar 06, 2015 | Konica Minolta Office Equipment & Supplies
C0500 error code DI151 machine
Sir/Mam to reset power off the machine. Wait ten seconds, then turn on the machine with the clear/stop Button held down. Power off the machine, wait ten seconds and then power on the machine. If the code comes back you need a new fusing unit.
Jan 19, 2015 | Minolta Di151 All-In-One Laser Printer
Minolta DI-151 trouble code c0500
Sir/Mam Power off the machine. Wait ten seconds then holding down the Stop/Cancel button power on the machine. Clear the code then power off the machine. Wait 10 seconds and power on. If the code comes back you need to look for a new fusing unit (Hot Part) DO not reset the fuser cold catch on fire. That would ruin a perfectly good day!:).
Jan 19, 2015 | Minolta Office Equipment & Supplies
How to reset the C0500 code on a Di1610 machine
power off the machine, then hold down the stop button and power on. if the code comes back DO NOT RESET the Fuser (HOT PART BACK OF MACHINE) is bad it can catch on fire REPLACE IT.
Jul 02, 2014 | Konica Minolta DiALTA Di200 Copier
How to reset error code c-3803
Sir/Mam,
POWER off the machine Main power switch is inside the machine. Keep the sub power switch on one located on the side of the control panel. Now hold down Utility/Counter button and turn on main power close cabinet then wait for trouble reset Touch it get OK then power off WAIT TEN SECONDS then power up IF IT COMES BACK DO NOT RESET IT. IT IS BROKE AND MACHINE IS TELLING YOU THAT. THIS CODE deal with the FUSER (Hot part) Can catch fire!!!!!!!!!!!!!!!!!!!!!
Apr 30, 2013 | Konica Minolta Bizhub 600 750 Image...
Changed board fault 9 comes up
The error code #9 is a machine size error code. The error code can come up if the board was recently replaced. Programing the washers control board wrong could also cause this error.
May 14, 2012 | Fisher and Paykel Washing Machines
Error code c0070
Power off the machine and gentlly take out the toner bottle. Then with the bottle out turn on the machine let the machine go thur its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
Apr 17, 2010 | Konica Minolta DiALTA Di183F Copier
My konica copier 7020 is displaying an error code F-35-1. What does it mean and can I fix it myself?
First will require to power off the machine then holding down the 2 and 5 buttton turn on the macine your in 25 Mode go to soft switch setting, punch in 3 then 1 set the bit to 1 to 0 or 0 to 1. return to fist screen power off machine wait 10 secs then on again. the Code is indicating that the Fuser/Fixing unit is not getting hot enough if the code comes back do not reset but have a technician come look at the machine. The Fuser is the Hot Section (Which fuses the toner to the paper so it will not smear when it come out the machine) It gets very hot you lamp/thermosat, or themistors may gone. So get a tech to look at it.
Mar 01, 2010 | Konica Minolta Office Equipment & Supplies
Power problem code sc552 lanier
What is the error code? Many of the codes refer to a general electrical problem, and often turning the machine off, resetting the circuit board connectors and harnesses and memory sticks, and turning the machine back on will clear the error code and allow the machine to boot up normally.
Oct 27, 2008 | Lanier 1205 Copier
DYSON washine machine fault
To Clear F11 Code after a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
Sep 05, 2008 | Dyson Flowcheck CRO1 Front Load Washer
53 people viewed this question
jasbo
jasbo
