Question about Radio Communications
I have a Walkie-Talkie-2-Way-Radio-WT-419 which is on lock. how do i unlock please?
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
eradiostore
  • 1654 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
SOURCE: binatone MR 250 walkie talkie is locked how do i unlock it?
Try holding down the ENTER button
Posted on Jan 13, 2009
eradiostore
  • 1654 Answers
SOURCE: walkie talkie symbol stuck on cannot remove it
The symbol you are describing indicates you have the radio on HI power. It will not go away unless you reprogram the radio to LOW power, or change to a low power channel. Here is a link to the user guide: http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTNiD/Static%20Files/XTNiD%20Manual%20EN.pdf?localeId=252
Best regards.
Posted on Feb 06, 2010
  • 35 Answers
SOURCE: need a manual for radio shack 21-1936 walkie
The 21-1936 was made for Radio Shack by Uniden and is identical to the Uniden GMR-1038-2
The Uniden version of the manual is available HERE
Posted on Nov 12, 2010
I need a manual for this
http://www.upzone.com/downloads/summary/7-manual/1254-the-manual-of-walkie-talkie-atomatic-battery-save-walkie-talkie-88006651.html
May 21, 2014 | BellSouth Auto multi-channels 2-way radio...
My Uniden walkie talkie keeps saying L very time I push a button
You've set the keylock feature on your walkie talkie. From the Uniden manual...
KEYLOCK
ON/OFF Press and hold the call/lock key until the "L" appears. After 1 second, the LCD will return to the channel display. To exit Keylock on mode, press and hold call/lock again. Note: While in keylock on mode, it will still receive transmissions.
Feb 10, 2014 | Uniden GMR-1035-2 2-Way Radio
Unlock walkie talkie
Press and hold the call button until the "L" goes away.
Jan 18, 2014 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
How to unlock dse commicator
To turn lock on or off, Hold Confirm/Power then immediately press Up arrow, release both buttons.
May 04, 2013 | Radio Communications
Spy gear walkie talkie
Spy Gear walkie talkie????
You've not given me any other info, so how can I help you?
Please reply with the following info:
1. Make & Model of your radio.
2. Your question in regard to the radio, i.e,. THE PROBLEM WITH IT.
Unless I receive as much info regarding your radio, I am unable to give you an answer.
Cheers,
Peter
Mar 05, 2013 | Wild Planet Spy Gear Long Range Walkie...
I cannot get my bellsouth walkie talkie model 2290 to unlock from a channel
The manual says to press and hold the MODE button for 5 seconds turn on or to turn off the LOCK mode. When locked, it prevents you from accidentally changing channels.
Jan 05, 2013 | BellSouth 2290 Walkie Talkie FRS/GMRS...
When I place the walkie talkie in the charger base, the light indicator does not come on. I've put new batteries in the walkie talkies. Also, on another walkie talkie, it constantly shuts off when I...
Generally when a radio shuts off when you press the PTT button it is a sign of a bad or poorly charged battery. It takes more energy to transmit than to receive. The fact you have a charge which the light does not come on indicates you have a bad charger or bad connection between the radio and/or battery and the charger. Clean your battery contacts (on both radio and charger) with a pencil eraser and see if it clears up the problem. If not, you have either a battery or charger problem.
Best regards.
May 25, 2011 | Motorola Walkie Talkie 2-Way Radio
Put batteries in and walkie talkie does not work
either the batterys are duds or the walkie talkie doesnt work- junk or have repaired :)
WE love to help :) and its FREE! so please be kind and thoughtful in your ratings. THANK YOU!
Mar 30, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
