I do not have a browser or email client connected to the internet. Yet, when I open my network connection in windows task manager, I see a lot of data being received. how do I find out where that data is coming from?
  • 27,725 Answers
Scroll to bottom of screen (task bar)right click select task manager applications you will see whats running if you see anything you dont need running select end now also under processes you will see whats running the data
hope this helps
Posted on May 27, 2011
I have windows 7 home prem and cannot connect says detects strong signal but limited access
Most likely, the access point is not connected to an internet gateway whatever that is at your place.
and since access points does not provide DHCP service by default (handing out IP information to connected clients), you get the limited access message.
In short, make sure the access point is connected to the router because the router is the once responsible for providing the DHCP service.
Feb 18, 2012 | ASUS WL-330 802.11b Wireless Access Point
I'm using a 1mbps broadband connection to play youtube videos but still it keeps buffering. On checking, I found out that youtube was utilizing only about 400kbps of bandwidth.. Whats the problem??? I...
Close Internet Explorer (Chrome, too).
Press CTRL and ALT and DELETE at the same time, and open "Task Manager".
Click on the "Networking" tab to show the flow through your computer's network-adapter.
It should be "zero" usage, since your web-browsers are not open.
Leave Task Manager open (and maybe minimize it).
Open Internet Explorer, and start viewing a YouTube video.
Restore the Task Manager window, and see the usage of the network adapter.
Tell us what level of usage that you see.
Dec 17, 2010 | YouTube Videos
My browser will not connect to the internet
Do you have any other internet enabled applications that are connecting properly? If you do have other internet enabled apps and they too are having problems than I would suggest trouble shooting your network connections.
If you are running Windows XP go "Control Panel" and under "PIck a Category" select "Network and Internet Connections". Next select "Network Connections". Right click your network connection and select "Repair". Windows will attempt to repair your network drivers, settings, and reestablish your network connection. If unsuccessful it will attempt provide an error message describing the problem.
If you don't see that option start checking connections along your network cable wiring. A plug may have come out or a cable damaged.
If it is not your network connection or your wiring it is your browser software. Reset your browser back to default settings to repair any changes made by accident by yourself or perhaps a website attempting a browser hijack:
Reset Internet Explorer to the default settings To reset Internet Explorer to the default settings
  1. Close any Internet Explorer or Windows Explorer windows that are currently open.
  2. Open Internet Explorer.
  3. Click the Tools button, and then click Internet Options.
  4. Click the Advanced tab, and then click Reset.
  5. Select the Delete personal settings check box if you would like to remove browsing history, search providers, Accelerators, home pages, and InPrivate Filtering data.
  6. In the Reset Internet Explorer Settings dialog box, click Reset.
  7. When Internet Explorer finishes restoring the settings, click Close, and then click OK.
  8. Close Internet Explorer. Your changes will take effect the next time you open Internet Explorer.
Hope this helped.
Feb 05, 2010 | Acer Computers & Internet
My 8330 does not let me browse the internet on my
Hi BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
To set up a tethered modem, complete the following tasks from A to D
A) Install BlackBerry Desktop Software 4.1 or later on your computer.
B) To set up an Internet APN, complete the following steps:
1) Click Start > Settings > Control Panel.
2) Double-click Phone and Modem Options.
3) In the Phone and Modem Options window, click the Modems tab.
4) Select Standard Modem and click Properties.
5) Click Change Settings.
6) In the Standard Modem Properties window, click the Advanced tab.
7) In the Extra initialization commands field, type the following:
+cgdcont=1,"IP","<your Internet APN>"
The extra initialization command is: +cgdcont=1,"IP","wap.voicestream.com"
8) Click OK.
9) In the Phone and Modem Options window, click OK.
C) To configure dial-up networking, complete the procedure that is appropriate for Windows Vista
1) Click Start.
2) Select Connect To.
3) Click Setup a connection or network.
4) Click Setup a dialup connection.
5) In the Dial-up phone number field type *99#.
6) Type the user name and password provided by your wireless service provider.
7) In the Connection Name field type BlackBerry.
8) Click Dialing Rules.
9) Make sure the profile created in Task 2 has been selected, and then click OK.
10) Select Connect to establish an Internet.
D) To connect to the Internet using dial-up networking, complete the following steps:
During this procedure, do not operate the BlackBerry Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
1) Connect the BlackBerry smartphone to the computer.
2) Open BlackBerry Desktop Manager.
3) Click Start > Settings > Network Connections > <name of your new connection>.
4) Type the user name and password provided by your wireless service provider.
5) Click Dial.I hope this information will help you
Nov 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Sitecom WL-330 range extender with dlink dir-615- unable to use
I am guessing you have XP or vista. here are the instructions for both.
XP 1. Click ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Double-click Network and Dial-up Connections icon, double click Local Area Connection, and Local Area Connection Properties window will appear. Select ‘Internet Protocol (TCP/IP)’, then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Vista 1. Click the ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Click View Network Status and Tasks, then click Manage Network Connections. Right-click Local Area Network, then select ‘Properties’. The Local Area Connection Properties window will appear, select ‘Internet Protocol Version 4 (TCP / IPv4)’, and then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Next step for both All functions and settings of this access point must be configured via the web management interface. Please start your web browser, and input ‘192.168.0.234’ in the address bar, and press the ‘Enter’ key. The following dialog should be shown: Please input user name and password in the field respectively. The default user name is ‘admin’, and the default password is ‘admin’. Press the ‘OK’ button to see the web management interface of this access point: NOTE: If you can’t see the web management interface, and you’re being prompted to input user name and password again, it means you didn’t input username and password correctly. Please retype user name and password again. After you connected to the access point by web browser, the first thing you see is ‘Status and Information’ page. All system and network related information of this access point will be displayed here. The information is very helpful when you want to know the detailed information of your access point, and when you try to fix the communication problem between this access point and other wired / wireless computer / devices. You can click ‘Home’ on the left, This access point can be operated in different modes; you can click ‘Basic Setting’ to select an operating mode you want to meet for different needs: You can click ‘Mode’ dropdown menu to select operating mode, and there are 3 operating modes available: AP Access point mode, allows wireless clients to connect to access point and exchange data with the devices connected to the wired network. Station- Infrastructure Enable the Ethernet device such us TV and Game player connected to the access point to a wireless client. Universal Repeater This product can act as a wireless range extender that will help you to extend the networking wirelessly. The access point can act as Station and AP at the same time. It can use Station function to connect to a Root AP and use AP function to service all wireless clients within its coverage. You can hopefully figure it out from there.
Sep 13, 2009 | D-Link DIR-615 Wireless Router
Modem
Found this after some deep looking from blackberry itself: Good Luck
A BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
Summary of Tasks To set up a tethered modem, complete the following tasks:
  1. Install BlackBerry Desktop Software 4.1 or later (one time only).
  2. Set up the Internet access point name (APN) (one time only).
  3. Configure dial-up networking (one time only).
  4. Connect to the Internet using dial-up networking.
Task 1
When you install BlackBerry Desktop Software, the drivers that allow the BlackBerry smartphone to communicate through the Universal Serial Bus (USB) port and virtual communications port are installed. The standard modem, which is used by dial-up networking, is also installed.
Note: If upgrading your BlackBerry Desktop Software from version 4.0 to 4.1, the required virtual communications port and standard modem might be removed during the upgrade process. If this is the case, re-install the BlackBerry Desktop Software 4.1 or later and choose the Repair option to re-install these components.
Task 2
Set up an Internet APN.
  1. Click Start > Settings > Control Panel.
  2. Double-click Phone and Modem Options.
  3. In the Phone and Modem Options window, click the Modems tab.
  4. Select Standard Modem and click Properties.
  5. Click Change Settings.
  6. In the Standard Modem Properties window, click the Advanced tab.
  7. In the Extra initialization commands field, type the following: +cgdcont=1,"IP","<your Internet APN>"
    Note: The following is applicable for T-Mobile® customers only:
    Note: If you do not know your Internet APN, or if you do not have an Internet APN, contact your service provider.
  8. Click OK.
  9. In the Phone and Modem Options window, click OK.
Task 3
To configure dial-up networking, complete the procedure that is appropriate to the operating system you are using:
Windows Vista
  1. Click Start.
  2. Select Connect To.
  3. Click Setup a connection or network.
  4. Click Setup a dialup connection.
  5. In the Dial-up phone number field type *99#.
  6. Type the user name and password provided by your service provider.
  7. In the Connection Name field type BlackBerry.
  8. Click Dialing Rules.
  9. Make sure the profile created in Task 2 has been selected, and then click OK.
  10. Select Connect to establish an internet.
Note: For instructions on connecting a computer to the Internet using a BlackBerry smartphone with CDMA as a tethered modem, see KB04664.
Windows XP operating system
  1. Click Start > Settings > Network Connections.
  2. Double-click New Connection Wizard. The New Connection Wizard opens.
  3. Click Next.
  4. Select the Connect to the Internet option. Click Next.
  5. Select Set up my connection manually. Click Next.
  6. Select Connect using a dial-up modem. Click Next.
  7. If the Select a Device screen appears, select the Modem - Standard Modem check box. Click Next.
  8. In the ISP Name field, type a name for your connection. Click Next.
  9. In the Phone number field, type *99#. Click Next.
  10. Indicate which users will have access to the connection. Click Next.
  11. Type the user name and password provided by your service provider. Click Next.
  12. Click Finish.
  13. In the Connect window, click Properties.
  14. In the Properties window, verify that Modem - Standard Modem appears beneath the Connect using heading, and then click Configure.
  15. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK. In the Properties window, click OK.
Windows 2000 operating system
  2. Double-click Network and Dial-up Connections. Note: The following is applicable for T-Mobile customers only:
    Under the networking tab in the properties window for the dial-up connection, clear the Enable LCP Extensions check box, as well as all check boxes beneath the PPP Settings window.
  3. Double-click Make New Connection. The Network Connection Wizard opens.
  4. Click Next.
  5. Choose Dial-up to private network. Click Next.
  6. In the Phone number field, type *99#. Click Next.
  7. Indicate which users will have access to the connection. Click Next.
  8. Type a name for your connection. Click Finish.
  9. In the Connect window, click Properties.
  10. In the Properties window, verify that Modem - Standard Modem is selected, then click Configure.
  11. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK.
  12. In the Properties window, click OK.
Task 4
Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
  1. Connect the BlackBerry smartphone to the computer.
  2. Open BlackBerry Desktop Manager.
  3. Click Start > Settings > Network Connections > <name of your new connection>.
  4. Type the user name and password provided by your service provider.
  5. Click Dial.
Apr 07, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
I cannot connect to the internet using wifi
1. Go to START
2. select MY COMPUTER
3. Once in the new window, click MY NETWORK PLACES under the "OTHER PLACES" section
4. select the VIEW NETWORK CONNECTIONS link under the NETWORK TASKS section
5. RIGHT CLICK on your wireless network connection and choose PROPERTIES
6. click the WIRELESS NETWORKS tab.
7. make sure the "USER WINDOWS TO CONFIGURE MY WIRELESS NETWORK SETTINGS" box is checked
8. Click OK and close the window
9. RIGHT CLICK on your wireless network connection (the name of it) and choose REPAIR
10. if windows detects the wireless connection, you should see a bubble near the task bar
11. in order to begin using the wireless connection, open your web browser then enter your username and password (if required)
Dec 01, 2008 | Computers & Internet
Can't receive my E-Mail
Depends on the (client) program you are using, but...
1) Test your WEB Browser (Internet Explorer or Firefox),
to make sure you can get MSN or Google.
This tell you if the network and the TCP/IP stack are
working properly.
2) If the network is fine, open you email client and check
your server setting for: POP-3, and SMTP.
These setting must match those specified by your
IP service provider.
Also make sure that the email login and server password
are correct.
3) Pay particular attention to the error messages you
get inside you email client, when it fails to access the
server. These should give you a clue:
a) Can't find server / invalid domain name ... etc...
b) Can't login ... user not authorized...
c) No network connection ... denied...
etc...
4) Server and domain name problems indicate a typo or
error in your POP3/ SMTP settings. These are sometimes
changed by the IP provider, so please check with them.
Also check the port numbers:
Port 110 = POP3 = Incoming mail server
Port 25 = SMTP = Outgoing mail server
are typical, but it really depends on th provider.
5) If you can't login, the login ID or password are wrong,
or your provider has closed you account, which they tend
do to with a nasty deliberation if you owe them money.
6) If the email program cannot connect to the internet at
all, but you WEB browser can, then you have a fire wall
problem.
Check these firewall, and disable them temporarily,
to see if it fixes the email problem:
The Windows Firewall: Control Panel === Windows Firewall
(disable it)
Any software firewall you may have installed, such as
Norton's, AVG antivirus...etc. Disable them too.
If you use an external router or residential gateway
to connect to the internet, such as SISCO, CVG, SMC
Log into the router using your WEB browser, and disable the
firewall.
7) Once you identify a firewall problem, you need to setup
exceptions for your email client.
8) If you cannot get any Internet, including the WEB,
then you have a different problem.
a) run the Windows Network setup wizard again,
from the control panel.
b) If you connect directly to the Internet through your cable
or DSL this should fix it.
c) If you still use a telephone modem, that has to be
setup as well.
d) If you use a residential gateway, barricade or router
to connect to DSL or CABLE, then you need to set
that up next using you WEB browser. Typical router
address is: 192.168.1.1
e) In the case of DSL you router may also need to be
programmed with you login/password info, because in
this case it is the router that connects and logs into
your internet provider's server, not your computer.
(your computer sees the router, not the provider.)
Anyway, not knowing what your exact problem is,
I think that I have covered the waterfront here,
hope it helps.
Please rate my answers.
Martin
Jun 14, 2008 | Computers & Internet
Error code 80072745
open the following file in notepad
C:\WINDOWS\system32\drivers\etc\hosts
add the following two lines to the bottom of the file
65.54.239.80 messenger.hotmail.com
65.54.239.80 dp.msnmessenger.skadns.net
align them with tab so they match any other entries and save the file.
go to a command prompt and type
ipconfig /flushdns
hope this helps,
trin
Nov 16, 2007 | Microsoft Office Outlook 2003 for PC
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
