Question about Car Audio & Video
I am looking for a wiring diagram for Sansui 6502 car amp. Please help
3 Suggested Answers
SOURCE: Please help.... I need a wiring diagram or pinout for my Jensen xa1120 amp, thanks
xa 1120 amp pin out 123
456
1 left neg
2 ground to radio
3 left positive
4 right neg
5 blank-not used
6 right positive
Posted on Oct 10, 2008
jturcotte
  • 8743 Answers
SOURCE: Please I need crysler car
go to the below website, page down, select your car on the right.
http://www.modifiedlife.com/request-a-chrysler-car-radio-stereo-wiring-diagram/
Page down again, and see color code for your factory wiring
Posted on Oct 08, 2010
On my Sansui sw-100 sub, I have 2 speakers connected to the high level output, that dont operate
Yes in order to have audio going to your spare speakers from the sub .You would need to use the hi level inputs comming from the reciever outputs connected to these hi level inputs..The sub will then crossover the audio to their proper outputs..Hope this helps you
Jan 15, 2014 | Audio Players & Recorders
Error 6502 came up on my viewing box and I cant get it to clear. I dont know what caused it exactly. I had a paper jam and I pulled the paper out of the rollers to clear it now I have error 6502 and I dont...
Pls do the following :-
Error code 6502 The Error code 6502 can occur in the printer as a result of ink tubes caught under housing and jammed the print head against the right hand side of the printer. The printer is unable to do anything now and it will give an alarm light only. To fix this issue, you need to unplug the printer and then plug it back. You need to press and hold the power button of the printer and click the Stop button twice. You can then release the Power button and press Stop button for four times. The issue will be fixed and you can start your print jobs.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | Canon MX700 Office All-In-One InkJet...
I have cannon IP3680, but from today it's making problem (Service error 6502), would u please tell me a easy way to solve the problem...
The error 6502 is an "Ink tank position sensor error". It may be that the sensor is dirty and needs cleaning. Make sure you haven't got any bright lights shining into the printer.
Mar 01, 2011 | Canon Office Equipment & Supplies
ERROR 6502
Error 6502 (Ink tank position sensor error) the sensor is receiving too much light. Possible causes are:
1. The printer cover is open and the sensor is exposed to the light
2. The ink tank LEDs are busted
3. Sensor or its wire connection to the logic board is busted or disconnected
Solution:
1. Close the printer cover
2. Possible ink tank replacement
3. Change sensor or repair disconnected wires
Sep 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Adding line out inputs for RCA cables to amp
Hello ssmotorcity,
Here's a link to modifiedlife's Durango page showing the wire colors.
http://www.modifiedlife.com/2005-dodge-durango-car-radio-stereo-audio-wiring-diagram/
If you are adding a LOC for an amp to drive a sub, you are probably better off using the rear speaker wires, the last four wires shown on the listing. If you are adding an amp to drive all 4 channels, then of course, you need to convert both fronts and rears. The simple method is to tap directly into the appropriate wires and connect them to the line converter. If you do not want to tap the wires, you can purchase aftermarket wiring harnesses that are made to plug directly into your vehicle radio and/or the vehicle wiring harness. The Metra part number for a stock radio harness is 71-6502. It plugs into the radio and provides pigtail connections for power and speakers. There is, of course, a harness that plugs into the vehicle harness itself, allowing you to make the connections without any cutting or tapping of the original wiring.
Hope this helps.
Apr 16, 2009 | Car Audio & Video
Amp dosnt work right
your amp cant handle the impedance of your subs i.e your running a 2ohm sub on a 4ohm amp!
Change the wiring on the sub so instead of running at 2ohm your run at 4
if you need to know how to wire up your sub to run at 4 then take a look at this wiring diagram
take a look at option 2
Click here
Hope this helps if so please dont forget to rate :)
Upfront Audio
Apr 13, 2009 | Pioneer GM-5100T Car Audio Amplifier
I am looking for Internal diagram - Service Manual for Sansui TV
I AM LOOKING FOR A CIRCUIT DIAGRAM OF A TV MODEL E2999 .THE COMPLETE BOARD OUTLAY AND DIAGRAM
Apr 08, 2009 | Televison & Video
Canon ip3500
I have Printer Canon Pixma IP3500 has been error 6502.
What is solution? Please help me.
Jun 09, 2008 | Canon I990 InkJet Photo Printer
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
