Question about EPoX EP-8K9A2+ Motherboard
Hi I have a machine with an EP-8K9A2+ board which has failed. The PSU is fine so it must be on the rectification stage of the board. I have heard that the rectifier caps and regulators are a weak point with these products. I don't really want to trash the PC so any help would be appreciated. Thanks Paul
    Sergeant:
  • 207 Answers
'It doesn't mean that when the power is present and all of your system fans is moving is that your power supply is OK. If your PSU is a generic one i will give a second thought that you should test your PSU in another working unit or if you simply have a multitester you can check the terminals while the system in on and could get readings accurately without any drop in voltages.
If you are really sure that your mobo is the problem then do the following if it will work for you:
Most motherboards nowadays don't work at all if the CMOS (Complementary Metal Oxide Semiconductor) battery has emptied out or weak, remove the battery and test it with multitester, a good battery is about 3V or slightly higher, a 2V reading or below would post a serious problem on the CMOS program of the motherboard which may post a problem in booting. If you find the battery is weak replace it with a new one. If these steps doesn't work at all then you should look for other problems. Observed any bulged capacitor where the upper cover is slightly push upward and remove them if you find one using soldering iron and replace it with a new one with the same rating, but if you can't find one just try removing the motherboard from the main system unit, remove the CMOS battery and clear the CMOS for about a minute or more. You should drain any power left from the motherboard's capacitors that keep supplying the CMOS chipset. You could use an aluminum foil to shorten out all the circuits under the motherboard to drain the circuits out. Draining the circuit simply putting the system on all default position. After doing this you can now put on the CMOS battery, put back the CMOS jumper setting to default and inserting all the components for testing.
Hope it helps because most of the time it works except when the regulator IC is really a problem.
Posted on May 27, 2011
Testimonial: "Thanks melndream! You guys have been great. I'll work thru your list and let everyone know if it was successful. Tx again."
  • EPoX Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
  • Brian Sullivan
    Brian Sullivan May 27, 2011
    even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
    a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty graphics card clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap hope this helps
  • maveric483 May 27, 2011
    Thanks bronk50. I gave every thing a quick once-over but will go thru the box item for item now and check it all out. Thanks a stack for the input. I'll post the ut come as well.
Hi my LG50 pk590 keeps overheating and switching to standby,ive stuck a fan behind and all seems fine so how do I fix this heating issue??? thx
CHECK THE PSU BOARD
Switching to standby might not be an overheating issue it might be a failing y-sus board.
Sep 15, 2013 | Televison & Video
M-cube sub wont power.getting 220v ac to psu board and 8v dc from psu board
check your bridge rectifier if no short,audio stage is blown
Dec 19, 2010 | Mission M-CUBE System
My computer won't turn on. I cleaned the Air spinner thing, checked the mother board, and everything was fine. The computer is an Emachines T2824. Can i have some assistance on how to get it to turn on?
If the machine is doing nothing at all when you press the power button, chances are your Power Supply Unit (PSU) has failed. If this is the case, the only way to fix it, is to get a new PSU.
Nov 03, 2010 | Computers & Internet
Epox 8K9A2 motherboard ? hangs @ POST CODE "26"
Gday mate , you will have to start with BIOS settings on boot when it detects the drives at the bottom of the screen will be a press ( this button) to enter setup probably delete or F8 go to there and probably set standard defaults would be the best option in the list do tha and follow the prompts back to startup screen, unless it comes up with NTLDR missing which is in the OS files
Apr 07, 2010 | EPoX EP-8K9A Motherboard
My new eMachine keeps crashing. I walk away with items open and when I come back, it has done an unscheduled reboot - like someone walked by and pulled the plug except it does come back on on its own. ...
Open Control panel (switch to classic view). Double click on "Power Options" (green cell in Vista) and select 'High Performance'.
If its already set to High Performance settings, inspect the cables especially at the jacks as they may be loose.
You have to make sure the electricity does not cut randomly and if it does, use a UPS (with adequate rating eg 400 Watt PSU needs 400/06=650VA UPS) or an inverter.
When the PSU (power supply unit) is failing it can cause the system to restart randomly until it fails completely taking away the motherboard with it.
At this stage you should not open the case but try the steps I have suggested.
Note that in addition to the above a software conflict may be forcing the system to reboot. If the problem persists, contact E-machines as you are within the official 1 year warranty period.
Mar 31, 2010 | E-Machines eMachines Desktop PC
Ibm netvista x41 wont power up
measuring 12v at the psu is not enough. the psu have several voltage outputs ranging from 12volts to 3.3 volts and maybe even 2.2 volts.. firstly, check all onboard USB ports, a bent or shorted pin in a USB port will prevent the psu from operating. next, the psu has a safety connection to the mainboard, this is called the power good signal ( pwrgd) and it is a signal from the psu to the mainboard and tells the mainboard that everything in the psu is functioning correctly. If the powergood signal is lost ( drops from 5volts to zero volts) the mainboard will issue an interuppt to the cpu and the cpu will shut down, this will also shut the board down to prevent damage and data loss. mainboards all use pretty much the same connectors so your board will have either a 20 pin power connector or a 24 pin one. It may also have an additional 4 pin connector to power the cpu and northbridge functions. use a known good psu and plug this into your board along with the 4 pin connector and attempt a switch on. If the system begins to boot, replace the psu. if not, try unplugging or removing everything connected to the board, pay special attention to expansion cards and usb ports. remove the ram sticks and video cards if fitted, then attempt to boot again. if the system does not respond, replace the main board. if it now begins to boot, refit everything one item at a time and try starting the machine. turn off before refitting the next item and start the machine up again. when you get to the problem item, the machine will stop starting. If all else fails, replace the mainboard or take the machine to a reputable repairer..
Oct 30, 2009 | IBM NetVista X41 PC Desktop
I have an ep-8kta3+pro m/board. Occasionally it fails to start up and the LEDs are stuck on FF. What does the code FF mean?
FF mean kind for computer geeks Fatal Failure meaning the only solution is geting a new one thanks and good luck
Oct 20, 2009 | EPoX EP-8KTA3+ Pro Motherboard
Mobo does not power up Dead cpu dead mobo?
A dead CPU will not hinder a board from powering up. The board is unlikely to POST. However, you should heard attempts at powering up and immediate shutdown. Or, you will see the PSU comes on but system not boot.
No mobo, but, CPU.
If no failed attempts at boot, no indicator lights, then you have either a failed power supply or DEAD motherboard.
Good luck
Sep 27, 2009 | Fujitsu Siemens Computers & Internet
Emachines D845GVSR motherboard repair
your i/o controller ic {SMSC} fail or rtc circuit fail there is two most possibility
Apr 01, 2008 | E-Machines eMachines Desktop PC
EPoX EP-8K9A2+ Motherboard Logo
125 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
