Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Right mandrel assembly for craftsman model 917.273020 does the stripper, mower round attach on top of or under housing of mandrel?
  • 110 Answers
The part called the stripper goes between the mandrel housing and the mower deck.
Hope this helps, if so please vote yes! Thanks!!
Posted on May 28, 2011
My sears model 917.2737 What is causing a spring popping noise in the mandrel assembly area on one side?.
I don't think you're using the right word "mandrel". I will need a little better explanation of what's going on and where exactly.
Aug 04, 2014 | Craftsman Garden
Replacing housing mandrel
usually just 3 bolts from the underside. may be a couple of screws holding the plastic cover on the top. for more specifics, need model #.
Jun 28, 2014 | Craftsman 48" Cut Riding Lawn Mower Deck...
The pullley mandrel and ball barings have fell off my craftsman riding lawn mower, how to fix it?
replace the entire mandrel assembly. Not too expensive if you get them from amazon or ebay. If you dont have number or ownersmanual, search your model number and it should come up.
May 29, 2014 | Craftsman Garden
42 in. deck cuts even on right side, cut uneven on inside left. Mandrel is good and no bent blades, have checked and no problem with uneven deck but it will not level, I have tried repeatedly for 3 or 4...
Well if you are breaking mandrel housings you are hitting more than grass with your mower. They are not intended to be used as brush cutters or mole hill graders. Also, if you have broken a mandrel then you may have slightly bent the top of the mow deck where the mandrel housing bolts up. In order to see it you will need to remove the mandrel housing and use a straight edge to ensure the mounting surface is straight. Quite often you don't need a straight edge; the damage is visible. Typically it will look like a dimple where the bolt head was sitting on the top of the mower deck. With the mandrel off you can use a hammer to pound the surface even. Sears also sells a reinforcement kit to make the mandrel mounting surface more sturdy or you could use fender washers to sturdy up the surface, but the kit is best as it gives support around the entire rim of the deck housing.
Jun 07, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I get the bolt off the top of the housing assembly in order to replace the mandrel #137646? Besides a wrench what other tool do I need to accomplish this? RIght now the bolt won't loosen because I...
If your blade will secure on the star, just jam the blade with a block of wood and proceed. If you have ruined your star, remove the three bolts that secure the mandrel housing, allowing the pulley to drop down to the deck (this requires some room beneath the deck, so get the whole thing off the ground first) and secure the pulley with heavy wire to the deck. There are a couple holes in the pulley and those bolt holes in the deck. Twist tight. The nut is threaded normally (counter clockwise to remove). A socket with a long handle does the trick after you use a few drops of break free oil.
Sep 06, 2010 | Craftsman Garden
Have 54 inch Craftsman mower deck that I am rebuilding - how do I remove the spindle from the Mandrel housing? Appears to be stuck but will spin.
Depends on how old the deck is. Some of the older spindles and mandrels were not made to came apart. The newer ones you can put the nut on the top threade to protect the threads and a couple of taps it should come out. If you have a model number you can got to sears web site aa they will have an exploded view. http://www.searspartsdirect.com/partsdirect/index.action
Mar 21, 2010 | Craftsman Garden
Mandrel where blade attaches the slotted piece is gone
i'm guessing that you're referring to the aluminum mandrel housing: yes you can get the housing separately, better get some new bolts too, because the old ones will likely break off - use some anti-seize compound on them and it'll go alot easier
Aug 26, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Need image, assembled craftsman model 917.276813 lawn mower deck
Go to www.sears.com and on the tool bar click on parts direct. On the opening page click on model # and enter your model number. Then on the page that opens there will be a list of components. Click on the deck and it will give you an image of the deck with part numbers.
Hope this helps. Let me know.
Thanks
roundo4
Aug 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Needing to replace the mandrell housing
I assume you're refering to the round aluminum housing with bearings in it? It's a pretty common part. #492574. The problem you may be having is that they show the part # to be 492474 on the breakdown, but that is incorrect.
Jun 06, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Do mandrels on 48'' deck come threaded for mount or not?
Most of the time you get self tapping screws with them or if you want you could get bolts nuts and washers (,lock) make sure the shafts and height are right.
May 12, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
256 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
